电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » FPGA实验连载(八、键盘显示)
共3条 1/1 1 跳转至页
FPGA实验连载(八、键盘显示)
2012-10-13 00:04:45     打赏
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity ps2_1 is
 Port ( CLK, RST, KD, KC: in std_logic;
    an: out std_logic_vector (3 downto 0);
    sseg: out std_logic_vector (6 downto 0));
end ps2_1;
architecture Behavioral of ps2_1 is
 -- Component Declarations
 -- Signal Declarations
 signal clkDiv : std_logic_vector (12 downto 0);
 signal sclk, pclk : std_logic;
 signal KDI, KCI : std_logic;
 signal DFF1, DFF2 : std_logic;
 signal shiftRegSig1: std_logic_vector(10 downto 0);
 signal shiftRegSig2: std_logic_vector(10 downto 1);
 signal MUXOUT: std_logic_vector (3 downto 0);
 signal WaitReg: std_logic_vector (7 downto 0);
 -- Module Implementation
 begin
 --Divide the master clock down to a lower frequency--
 CLKDivider: Process (CLK)
 begin
  if (CLK = '1' and CLK'Event) then
   clkDiv <= clkDiv +1;
  end if;
 end Process;
 sclk <= clkDiv(12);
 pclk <= clkDiv(3);
 --Flip Flops used to condition siglans coming from PS2--
 Process (pclk, RST, KC, KD)
 begin
  if(RST = '0') then
   DFF1 <= '0'; DFF2 <= '0'; KDI <= '0'; KCI <= '0';
  else
   if (pclk = '1' and pclk'Event) then
    DFF1 <= KD; KDI <= DFF1; DFF2 <= KC; KCI <= DFF2;
   end if;
  end if;
 end process;
 --Shift Registers used to clock in scan codes from PS2--
 Process(KDI, KCI, RST) --DFF2 carries KD and DFF4, and DFF4 carries KC
 begin
  if (RST = '0') then
   ShiftRegSig1 <= "00000000000";
   ShiftRegSig2 <= "0000000000";
  else
   if (KCI = '0' and KCI'Event) then
    ShiftRegSig1(10 downto 0) <= KDI & ShiftRegSig1(10 downto 1);
    ShiftRegSig2(10 downto 1) <= ShiftRegSig1(0) & ShiftRegSig2(10 downto 2);
   end if;
  end if;
 end process;
 --Wait Register
 process(ShiftRegSig1, ShiftRegSig2, RST, KCI)
 begin
  if(RST = '0')then
   WaitReg <= "00000000";
  else
   if(KCI'event and KCI = '1' and ShiftRegSig2(8 downto 1) = "11110000")then
    WaitReg <= ShiftRegSig1(8 downto 1);
   end if;
  end if;
 end Process;
 --Multiplexer
 MUXOUT <=  WaitReg(7 downto 4) when sclk = '1' else
      WaitReg(3 downto 0);
 --Seven Segment Decoder--
 sseg <= "1000000" when MUXOUT = "0000" else
   "1111001" when MUXOUT = "0001" else
   "0100100" when MUXOUT = "0010" else
   "0110000" when MUXOUT = "0011" else
   "0011001" when MUXOUT = "0100" else
   "0010010" when MUXOUT = "0101" else
   "0000010" when MUXOUT = "0110" else
   "1111000" when MUXOUT = "0111" else
   "0000000" when MUXOUT = "1000" else
   "0010000" when MUXOUT = "1001" else
   "0001000" when MUXOUT = "1010" else
   "0000011" when MUXOUT = "1011" else
   "1000110" when MUXOUT = "1100" else
   "0100001" when MUXOUT = "1101" else
   "0000110" when MUXOUT = "1110" else
   "0001110" when MUXOUT = "1111" else
   "1111111";
 --Anode Driver--
 an(3) <= '1'; an(2) <= '1'; --disable first two seven-segment decoders.
 an(1 downto 0) <= "10" when sclk = '1' else "01";
end Behavioral;
关键词: 实验     连载     键盘     显示     logic     downto
2012-10-13 16:10:11     打赏
按下键盘,数码管会显示相应的十六进制数值!
2012-11-03 10:37:13     打赏
jayjayclub
有点做广告的嫌疑啊
共3条 1/1 1 跳转至页
