急求助啊!uC/OS-II的内存溢出
内存设置为RAM = READ_WRITE 0x0400 TO 0x0FFF;内存使用情况:Summary of section sizes per section type:
READ_ONLY (R): EE9 (dec: 3817)
READ_WRITE (R/W): 9B3 (dec: 2483)
NO_INIT (N/I): 160 (dec: 352);
堆栈大小TASK_STK_SIZE 为 64(这个值越大越溢出)。
这是堆栈初始化,其中0x2222,0x1111,0xBBAA不知道为什么这样设置???
OS_STK *OSTaskStkInit (void (*task)(void *pd), void *p_arg, OS_STK *ptos, INT16U opt)
INT16U *wstk;
INT8U *bstk;
opt = opt; /* 'opt' is not used, prevent warning */
wstk = (INT16U *)ptos; /* Load stack pointer */
*--wstk = (INT16U)p_arg; /* Simulate call to function with argument */
*--wstk = (INT16U)(((INT32U)task) >> 8); /* Return address. Format: PCH:PCL:PPAGE (cut out PPage) */
*--wstk = (INT16U)0x2222; /* Y Register */
*--wstk = (INT16U)0x1111; /* X Register */
*--wstk = (INT16U)0xBBAA; /* D Register */
bstk = (INT8U *)wstk; /* Convert WORD ptr to BYTE ptr to set CCR */
*--bstk = (0xC0); /* CCR Register (Disable STOP instruction and XIRQ) */
*--bstk = (INT8U)task; /* Save the PPAGE register */
return ((OS_STK *)bstk); /* Return pointer to new top-of-stack */
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
