【解析新特性】300W单路输出工业电源>>
电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 数码管计数
数码管计数
2013-08-06 21:37:58    评分
数码管60计数的程序:
module clock(clk_50m,rstc,sm_seg_out,sm_bit_out);
input         clk_50m;
input         rstc;
output [7:0]  sm_seg_out;
output [7:0]  sm_bit_out;
reg    [7:0]  sm_seg_out;
reg    [7:0]  sm_bit_out;
reg    [4:0]  dis_dat;
reg    [2:0]  dis_loca;
reg    [3:0]  sec11;
reg    [2:0]  sec12;
parameter     width = 15;
reg           flags,flag1ms;
reg [width:0] cntms;
reg   [24:0]  cnt;
wire          clk_s;
parameter     fre = 2499_9999;
/////////////////DivFrequen//////////////////
always @(posedge clk_50m or negedge rstc)
    begin
    if(!rstc)
           cnt<=1'b0;
    else
       if(cnt == fre)
           begin
           cnt <= 1'b0;
           flags <= ~flags;
           end
       else
           cnt <= cnt + 1'b1;
    end
assign clk_s = flags;
/*******************1ms*****************************/
    begin
        if(!rstc)
           cntms<=16'd0;
        else
            begin
                  if(cntms == 16'd49999)
                      cntms <= 16'd0;
                else cntms <= cntms + 1'b1;
             end
    end
/*******************second*****************************/
always @(posedge clk_s or negedge rstc)
    begin
    if(!rstc)
           begin
           sec11 <= 1'b0;
           sec12 <= 1'b0;
           end
    else
        begin
       if((sec11 == 4'b1001)&&(sec12 ==3'b101))
            begin
            sec11 <= 1'b0;
            sec12 <= 1'b0;
            end
       else
            begin
            if(sec11 == 4'b1001)
                begin
                sec11 <= 1'b0;
                sec12 <= sec12 + 1'b1;
                end
            else
                begin
                sec12 <= sec12;
                sec11 <= sec11 + 1'b1;
                end
            end
        end
    end
//////////////display/////////////////
    begin
        if(!rstc)
           dis_loca <= 3'd0;
        else
            begin
                  if(cntms == 49999)
                      dis_loca <= dis_loca + 1'b1;
                  else dis_loca <= dis_loca;
            end
    end
always @(dis_loca)
    case(dis_loca)
        3'b000 : sm_bit_out = 8'b1111_1110;       //第一位数码管
        3'b001 : sm_bit_out = 8'b1111_1101;       //第一位数码管
        3'b010 : sm_bit_out = 8'b1111_1011;
        3'b011 : sm_bit_out = 8'b1111_0111;
        3'b100 : sm_bit_out = 8'b1110_1111;
        3'b101 : sm_bit_out = 8'b1101_1111;
        3'b110 : sm_bit_out = 8'b1011_1111;
        3'b111 : sm_bit_out = 8'b0111_1111;    //第8位
        default : sm_bit_out = 8'b1111_1111;
    endcase
always @(sm_bit_out or sec11 or sec12)
    case(sm_bit_out)
        8'b1111_1110 : dis_dat = sec11;
        8'b1111_1101 : dis_dat = sec12;
        8'b1111_1011 : dis_dat = 4'b1010;
        8'b1111_0111 : dis_dat = sec11;
        8'b1110_1111 : dis_dat = sec12;
        8'b1101_1111 : dis_dat = 4'b1010;
        8'b1011_1111 : dis_dat = sec11;     // 问题行
        8'b0111_1111 : dis_dat = sec12;
        default      : dis_dat = 4'b1011;
    endcase
always @(dis_dat)
    case(dis_dat)
        4'b0000 : sm_seg_out = 8'hc0;  //0
        4'b0001 : sm_seg_out = 8'hf9;  //1
        4'b0010 : sm_seg_out = 8'ha4;  //2
        4'b0011 : sm_seg_out = 8'hb0;   //3
        4'b0100 : sm_seg_out = 8'h99;   //4
        4'b0101 : sm_seg_out = 8'h92;   //5
        4'b0110 : sm_seg_out = 8'h82;   //6
        4'b0111 : sm_seg_out = 8'hf8;   //7
        4'b1000 : sm_seg_out = 8'h80;  //8
        4'b1001 : sm_seg_out = 8'h90;  //9
        4'b1010 : sm_seg_out = 8'hbf;    //-
        4'b1011 : sm_seg_out = 8'hff;     //消除残影
        default : sm_seg_out = 8'hff;   //消除残影
    endcase
endmodule
为毛第7位总是不显示,图传了半天喘不上来,而《手把手教你学CPLD》中的数码动态显示管例程第7位却可以显示,代码如下:
module scan_led (sys_clk              ,
                 sys_rstn             ,
                 sm_seg               ,
                 sm_bit
input               sys_clk           ;
input               sys_rstn          ;
output     [7:0]    sm_seg            ;
output     [7:0]    sm_bit            ;
reg        [7:0]    sm_seg            ;
reg        [7:0]    sm_bit            ;
reg           [4:0]    dataout_buf       ;
reg        [2:0]    disp_dat          ;
reg        [15:0]   delay_cnt         ;
always@(posedge sys_clk or negedge sys_rstn)
    begin
        if(!sys_rstn)
            delay_cnt<=16'd0;
        else
            begin
                if(delay_cnt==16'd49999)
                    delay_cnt<=16'd0;
                else
                    delay_cnt<=delay_cnt+1'b1;
            end
    end
    begin
        if(!sys_rstn)
            disp_dat<=4'd0;
        else
            begin
                    disp_dat<=disp_dat+1'b1;
                else
                    disp_dat<=disp_dat;
            end
    end
always @(disp_dat)
begin
   case(disp_dat)
       3'b000 :
          sm_bit = 8'b1111_1110;
       3'b001 :
          sm_bit = 8'b1111_1101;
       3'b010 :
          sm_bit = 8'b1111_1011;
       3'b011 :
          sm_bit = 8'b1111_0111;
       3'b100 :
         sm_bit = 8'b1110_1111;
       3'b101 :
         sm_bit = 8'b1101_1111;
       3'b110 :
          sm_bit = 8'b1011_1111;
       3'b111 :
         sm_bit = 8'b0111_1111;
       default :
    endcase
end
always@(sm_bit)
begin
    case(sm_bit)
        8'b1111_1110:
            dataout_buf=0;
        8'b1111_1101:
            dataout_buf=1;
        8'b1111_1011:
            dataout_buf=2;
        8'b1111_0111:
            dataout_buf=3;
        8'b1110_1111:
            dataout_buf=4;
        8'b1101_1111:
            dataout_buf=5;
        8'b1011_1111:
            dataout_buf=6;
        8'b0111_1111:
            dataout_buf=7;
        default:
            dataout_buf=8;
     endcase
end
always@(dataout_buf)
begin
    case(dataout_buf)
            4'h0 : sm_seg = 8'hc0;   // "0"
            4'h1 : sm_seg = 8'hf9;   // "1"
            4'h2 : sm_seg = 8'ha4;   // "2"
            4'h3 : sm_seg = 8'hb0;   // "3"
            4'h4 : sm_seg = 8'h99;   // "4"
            4'h5 : sm_seg = 8'h92;   // "5"
            4'h6 : sm_seg = 8'h82;   // "6"
            4'h7 : sm_seg = 8'hf8;   // "7"
            4'h8 : sm_seg = 8'h80;   // "8"
            4'h9 : sm_seg = 8'h90;   // "9"
            4'ha : sm_seg = 8'h88;   // "a"
            4'hb : sm_seg = 8'h83;   // "b"
            4'hc : sm_seg = 8'hc6;   // "c"
            4'hd : sm_seg = 8'ha1;   // "d"
            4'he : sm_seg = 8'h86;   // "e"
            4'hf : sm_seg = 8'h8e;   // "f"
            default :
     endcase
end
endmodule
这是为嘛?感觉两个差不多啊,求指教
关键词: Verilog     CPLD     数码管     计数
