电子产品世界 » 论坛首页 » DIY与开源设计 » 设计工具 » LCD1602的简单显示程序
LCD1602的简单显示程序
2013-10-25 15:33:59     打赏
1602液晶显示的实验例子
| DB4-----P0.4 | RW-------P2.1
| DB5-----P0.5 | RS-------P2.2
| DB6-----P0.6 | E--------P2.0
| DB7-----P0.7 |
LCD1602的简简单显示
#include
#include
#define LCM_RW P2_1 //定义引脚
#define LCM_RS P2_2
#define LCM_E P2_0
#define LCM_Data P0
#define Busy 0x80 //用于检测LCM状态字中的Busy标识
子函数声明
void Write_Data_LCM(unsigned char WDLCM);
void Write_Command_LCM(unsigned char WCLCM,BuysC);
void Read_Status_LCM(void);
void LCM_Init(void);
void Set_xy_LCM(unsigned char x, unsigned char y);
void Display_List_Char(unsigned char x, unsigned char y, unsigned char *s);
void main(void)
LCM_Init(); //LCM初始化
delay_nms(5);//延时片刻(可不要)
while(1)
Display_List_Char(0, 0, www.CSMZXY.COM);
Display_List_Char(1, 0, Robot-AT89S52);
函数名:Read_Status_LCM()
功 能: 忙检测函数
unsigned char read=0;
LCM_RW = 1;
LCM_RS = 0;
LCM_E = 1;
LCM_Data = 0xff;
do
read = LCM_Data;
while(read Busy);
LCM_E = 0;
函数名:Write_Data_LCM ( )
功 能: 对LCD 1602写数据
Read_Status_LCM(); //检测忙
LCM_RS = 1;
LCM_RW = 0;
LCM_Data = 0x0f;
LCM_Data |= WDLCM0xf0;
LCM_E = 1; //若晶振速度太高可以在这后加小的延时
LCM_E = 1; //延时
LCM_E = 0;
WDLCM = WDLCM4;
LCM_Data = 0x0f;
LCM_E = 1;
LCM_E = 1; //延时
LCM_E = 0;
函数名:Write_Command_ LCM ( )
功 能: 对LCD 1602写指令
void Write_Command_LCM(unsigned char WCLCM,BuysC) //BuysC为0时忽略忙检测
if (BuysC)
Read_Status_LCM(); //根据需要检测忙
LCM_RS = 0;
LCM_RW = 0;
LCM_Data = 0x0f;
LCM_Data |= WCLCM0xf0;//传输高四位
LCM_E = 1;
LCM_E = 1;
LCM_E = 0;
WCLCM = WCLCM4; //传输低四位
LCM_Data = 0x0f;
LCM_E = 1;
LCM_E = 1;
LCM_E = 0;
函数名:LCM_Init()
功 能: 对LCD 1602初始化
void LCM_Init(void) //LCM初始化
LCM_Data = 0;
Write_Command_LCM(0x28,0); //三次显示模式设置,不检测忙信号
delay_nms(15);
delay_nms(15);
delay_nms(15);
Write_Command_LCM(0x28,1); //显示模式设置,开始要求每次检测忙信号
Write_Command_LCM(0x08,1); //关闭显示
Write_Command_LCM(0x01,1); //显示清屏
Write_Command_LCM(0x06,1); //显示光标移动设置
Write_Command_LCM(0x0C,1); //显示开及光标设置
函数名:Set_xy_LCM ()
功 能:设定显示坐标位置
unsigned char address;
if( x == 0 )
address = 0x80+y;
else
address = 0xc0+y;
Write_Command_LCM(address,1);
函数名:Display_List_Char()
功 能:按指定位置显示一串字符
Set_xy_LCM(x,y);
while(*s)
LCM_Data = *s;
Write_Data_LCM(*s);
s++;
关键词: datasheet中文资料     datasheet p
