GET option.inc
GET memcfg.inc
GET 2440addr.inc
BIT_SELFREFRESH EQU (1<<22)
;Pre-defined constants
USERMODE EQU 0x10
FIQMODE EQU 0x11
IRQMODE EQU 0x12
SVCMODE EQU 0x13
ABORTMODE EQU 0x17
UNDEFMODE EQU 0x1b
MODEMASK EQU 0x1f
NOINT EQU 0xc0
;The location of stacks
UserStack EQU (_STACK_BASEADDRESS-0x3800) ;0x33ff4800 ~
SVCStack EQU (_STACK_BASEADDRESS-0x2800) ;0x33ff5800 ~
UndefStack EQU (_STACK_BASEADDRESS-0x2400) ;0x33ff5c00 ~
AbortStack EQU (_STACK_BASEADDRESS-0x2000) ;0x33ff6000 ~
IRQStack EQU (_STACK_BASEADDRESS-0x1000) ;0x33ff7000 ~
FIQStack EQU (_STACK_BASEADDRESS-0x0) ;0x33ff8000 ~
;Check if tasm.exe(armasm -16 ...@ADS 1.0) is used.
GBLL THUMBCODE
[ {CONFIG} = 16
THUMBCODE SETL {TRUE}
CODE32
THUMBCODE SETL {FALSE}
MACRO
MOV_PC_LR
[ THUMBCODE
bx lr
mov pc,lr
MEND
MACRO
MOVEQ_PC_LR
[ THUMBCODE
bxeq lr
moveq pc,lr
MEND
MACRO
$HandlerLabel HANDLER $HandleLabel
$HandlerLabel
sub sp,sp,#4 ;decrement sp(to store jump address)
stmfd sp!,{r0} ;PUSH the work register to stack(lr does't push because it return to original address)
ldr r0,=$HandleLabel;load the address of HandleXXX to r0
ldr r0,[r0] ;load the contents(service routine start address) of HandleXXX
str r0,[sp,#4] ;store the contents(ISR) of HandleXXX to stack
ldmfd sp!,{r0,pc} ;POP the work register and pc(jump to ISR)
MEND
IMPORT |Image$$RO$$Limit| ; End of ROM code (=start of ROM data)
IMPORT |Image$$RW$$Base| ; Base of RAM to initialise
IMPORT |Image$$ZI$$Base| ; Base and limit of area
IMPORT |Image$$ZI$$Limit| ; to zero initialise
IMPORT Main
AREA Init,CODE,READONLY
ENTRY
;1)The code, which converts to Big-endian, should be in little endian code.
;2)The following little endian code will be compiled in Big-Endian mode.
; The code byte order should be changed as the memory bus width.
;3)The pseudo instruction,DCD can't be used here because the linker generates error.
ASSERT :DEF:ENDIAN_CHANGE
[ ENDIAN_CHANGE
ASSERT :DEF:ENTRY_BUS_WIDTH
[ ENTRY_BUS_WIDTH=32
b ChangeBigEndian ;DCD 0xea000007
[ ENTRY_BUS_WIDTH=16
andeq r14,r7,r0,lsl #20 ;DCD 0x0007ea00
[ ENTRY_BUS_WIDTH=8
streq r0,[r0,-r10,ror #1] ;DCD 0x070000ea
b ResetHandler
b HandlerUndef ;handler for Undefined mode
b HandlerSWI ;handler for SWI interrupt
b HandlerPabort ;handler for PAbort
b HandlerDabort ;handler for DAbort
b . ;reserved
b HandlerIRQ ;handler for IRQ interrupt
b HandlerFIQ ;handler for FIQ interrupt
;@0x20
b EnterPWDN ; Must be @0x20.
ChangeBigEndian
;@0x24
DCD 0xee110f10 ;0xee110f10 => mrc p15,0,r0,c1,c0,0
DCD 0xe3800080 ;0xe3800080 => orr r0,r0,#0x80; //Big-endian
DCD 0xee010f10 ;0xee010f10 => mcr p15,0,r0,c1,c0,0
DCD 0x0f10ee11
DCD 0x0080e380
DCD 0x0f10ee01
[ ENTRY_BUS_WIDTH=8
DCD 0x100f11ee
DCD 0x800080e3
DCD 0x100f01ee
DCD 0xffffffff ;swinv 0xffffff is similar with NOP and run well in both endian mode.
DCD 0xffffffff
DCD 0xffffffff
DCD 0xffffffff
DCD 0xffffffff
b ResetHandler
;Function for entering power down mode
; 1. SDRAM should be in self-refresh mode.
; 2. All interrupt should be maksked for SDRAM/DRAM self-refresh.
; 3. LCD controller should be disabled for SDRAM/DRAM self-refresh.
; 4. The I-cache may have to be turned on.
; 5. The location of the following code may have not to be changed.
;void EnterPWDN(int CLKCON);
EnterPWDN
mov r2,r0 ;r2=rCLKCON
tst r0,#0x8 ;SLEEP mode?
bne ENTER_SLEEP
ENTER_STOP
ldr r0,=REFRESH
ldr r3,[r0] ;r3=rREFRESH
mov r1, r3
orr r1, r1, #BIT_SELFREFRESH
str r1, [r0] ;Enable SDRAM self-refresh
mov r1,#16 ;wait until self-refresh is issued. may not be needed.
0 subs r1,r1,#1
bne %B0
ldr r0,=CLKCON ;enter STOP mode.
str r2,[r0]
mov r1,#32
0 subs r1,r1,#1 ;1) wait until the STOP mode is in effect.
bne %B0 ;2) Or wait here until the CPU&Peripherals will be turned-off
; Entering SLEEP mode, only the reset by wake-up is available.
ldr r0,=REFRESH ;exit from SDRAM self refresh mode.
str r3,[r0]
MOV_PC_LR
ENTER_SLEEP
;NOTE.
;1) rGSTATUS3 should have the return address after wake-up from SLEEP mode.
ldr r0,=REFRESH
ldr r1,[r0] ;r1=rREFRESH
mov r1,#16 ;Wait until self-refresh is issued,which may not be needed.
0 subs r1,r1,#1
bne %B0
ldr r1,=MISCCR
ldr r0,[r1]
orr r0,r0,#(7<<17) ;Set SCLK0=0, SCLK1=0, SCKE=0.
str r0,[r1]
ldr r0,=CLKCON ; Enter sleep mode
str r2,[r0]
b . ;CPU will die here.
WAKEUP_SLEEP
;Release SCLKn after wake-up from the SLEEP mode.
ldr r1,=MISCCR
ldr r0,[r1]
bic r0,r0,#(7<<17) ;SCLK0:0->SCLK, SCLK1:0->SCLK, SCKE:0->=SCKE.
str r0,[r1]
;Set memory control registers
ldr r0,=SMRDATA
ldr r1,=BWSCON ;BWSCON Address
add r2, r0, #52 ;End address of SMRDATA
0
ldr r3, [r0], #4
str r3, [r1], #4
cmp r2, r0
bne %B0
mov r1,#256
0 subs r1,r1,#1 ;1) wait until the SelfRefresh is released.
bne %B0
ldr r1,=GSTATUS3 ;GSTATUS3 has the start address just after SLEEP wake-up
ldr r0,[r1]
mov pc,r0
LTORG
HandlerFIQ HANDLER HandleFIQ
HandlerIRQ HANDLER HandleIRQ
HandlerUndef HANDLER HandleUndef
HandlerSWI HANDLER HandleSWI
HandlerDabort HANDLER HandleDabort
HandlerPabort HANDLER HandlePabort
IsrIRQ
sub sp,sp,#4 ;reserved for PC
stmfd sp!,{r8-r9}
ldr r9,=INTOFFSET
ldr r9,[r9]
ldr r8,=HandleEINT0
add r8,r8,r9,lsl #2
ldr r8,[r8]
str r8,[sp,#8]
ldmfd sp!,{r8-r9,pc}
; ENTRY
ResetHandler
ldr r0,=WTCON ;watch dog disable
ldr r1,=0x0
str r1,[r0]
ldr r0,=INTMSK
ldr r1,=0xffffffff ;all interrupt disable
str r1,[r0]
ldr r0,=INTSUBMSK
ldr r1,=0x3ff ;all sub interrupt disable
str r1,[r0]
[ {FALSE}
; rGPFDAT = (rGPFDAT & ~(0xf<<4)) | ((~data & 0xf)<<4);
; Led_Display
ldr r0,=GPFCON
ldr r1,=0x5500
str r1,[r0]
ldr r0,=GPFDAT
ldr r1,=0x10
str r1,[r0]
;To reduce PLL lock time, adjust the LOCKTIME register.
ldr r0,=LOCKTIME
ldr r1,=0xffffff
str r1,[r0]
[ PLL_ON_START
; Added for confirm clock divide. for 2440.
; Setting value Fclk:Hclk:Pclk
ldr r0,=CLKDIVN
ldr r1,=CLKDIV_VAL ; 0=1:1:1, 1=1:1:2, 2=1:2:2, 3=1:2:4, 4=1:4:4, 5=1:4:8, 6=1:3:3, 7=1:3:6.
str r1,[r0]
;Configure UPLL
ldr r0,=UPLLCON
ldr r1,=((U_MDIV<<12)+(U_PDIV<<4)+U_SDIV)
str r1,[r0]
nop ; Caution: After UPLL setting, at least 7-clocks delay must be inserted for setting hardware be completed.
nop
nop
nop
nop
nop
nop
;Configure MPLL
ldr r0,=MPLLCON
ldr r1,=((M_MDIV<<12)+(M_PDIV<<4)+M_SDIV)
str r1,[r0]
;Check if the boot is caused by the wake-up from SLEEP mode.
ldr r1,=GSTATUS2
ldr r0,[r1]
tst r0,#0x2
;In case of the wake-up from SLEEP mode, go to SLEEP_WAKEUP handler.
bne WAKEUP_SLEEP
EXPORT StartPointAfterSleepWakeUp
ldr r0,=SMRDATA
0
ldr r3, [r0], #4
str r3, [r1], #4
cmp r2, r0
bne %B0
;Initialize stacks
bl InitStacks
; Setup IRQ handler
ldr r0,=HandleIRQ ;This routine is needed
ldr r1,=IsrIRQ ;if there isn't 'subs pc,lr,#4' at 0x18, 0x1c
str r1,[r0]
;If main() is used, the variable initialization will be done in __main().
[ :LNOT:USE_MAIN
;Copy and paste RW data/zero initialized data
LDR r0, =|Image$$RO$$Limit| ; Get pointer to ROM data
LDR r1, =|Image$$RW$$Base| ; and RAM copy
LDR r3, =|Image$$ZI$$Base|
;Zero init base => top of initialised data
CMP r0, r1 ; Check that they are different
BEQ %F2
1
CMP r1, r3 ; Copy init data
LDRCC r2, [r0], #4 ;--> LDRCC r2, [r0] + ADD r0, r0, #4
STRCC r2, [r1], #4 ;--> STRCC r2, [r1] + ADD r1, r1, #4
BCC %B1
2
LDR r1, =|Image$$ZI$$Limit| ; Top of zero init segment
MOV r2, #0
3
CMP r3, r1 ; Zero init
STRCC r2, [r3], #4
BCC %B3
mrs r0, cpsr
and r0, r0, #0x52
msr cpsr_c, r0
[ :LNOT:THUMBCODE
bl Main ;Don't use main() because ......
b .
[ THUMBCODE ;for start-up code for Thumb mode
orr lr,pc,#1
bx lr
CODE16
b .
CODE32
;function initializing stacks
InitStacks
;Don't use DRAM,such as stmfd,ldmfd......
;SVCstack is initialized before
;Under toolkit ver 2.5, 'msr cpsr,r1' can be used instead of 'msr cpsr_cxsf,r1'
mrs r0,cpsr
bic r0,r0,#MODEMASK
orr r1,r0,#UNDEFMODE|NOINT
msr cpsr_cxsf,r1 ;UndefMode
ldr sp,=UndefStack ; UndefStack=0x33FF_5C00
orr r1,r0,#ABORTMODE|NOINT
msr cpsr_cxsf,r1 ;AbortMode
ldr sp,=AbortStack ; AbortStack=0x33FF_6000
orr r1,r0,#IRQMODE|NOINT
msr cpsr_cxsf,r1 ;IRQMode
ldr sp,=IRQStack ; IRQStack=0x33FF_7000
orr r1,r0,#FIQMODE|NOINT
msr cpsr_cxsf,r1 ;FIQMode
ldr sp,=FIQStack ; FIQStack=0x33FF_8000
bic r0,r0,#MODEMASK|NOINT
orr r1,r0,#SVCMODE
msr cpsr_cxsf,r1 ;SVCMode
ldr sp,=SVCStack ; SVCStack=0x33FF_5800
;USER mode has not be initialized.
mov pc,lr
;The LR register won't be valid if the current mode is not SVC mode.
; Clock division test
; Assemble code, because VSYNC time is very short
EXPORT CLKDIV124
EXPORT CLKDIV144
CLKDIV124
ldr r0, = CLKDIVN
ldr r1, = 0x3 ; 0x3 = 1:2:4
str r1, [r0]
; wait until clock is stable
nop
nop
nop
nop
nop
ldr r0, = REFRESH
ldr r1, [r0]
bic r1, r1, #0xff
bic r1, r1, #(0x7<<8)
orr r1, r1, #0x470 ; REFCNT135
str r1, [r0]
nop
nop
nop
nop
nop
mov pc, lr
CLKDIV144
ldr r0, = CLKDIVN
ldr r1, = 0x4 ; 0x4 = 1:4:4
str r1, [r0]
nop
nop
nop
nop
nop
ldr r0, = REFRESH
ldr r1, [r0]
bic r1, r1, #0xff
orr r1, r1, #0x630 ; REFCNT675 - 1520
str r1, [r0]
nop
nop
nop
nop
nop
mov pc, lr
LTORG
SMRDATA DATA
; Memory configuration should be optimized for best performance
; The following parameter is not optimized.
; Memory access cycle parameter strategy
; 1) The memory settings is safe parameters even at HCLK=75Mhz.
; 2) SDRAM refresh period is for HCLK<=75Mhz.
DCD (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28))
DCD ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC)) ;GCS0
DCD ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC)) ;GCS1
DCD ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC)) ;GCS2
DCD ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC)) ;GCS3
DCD ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC)) ;GCS4
DCD ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC)) ;GCS5
DCD ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN)) ;GCS6
DCD ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN)) ;GCS7
DCD ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT)
DCD 0x32 ;SCLK power saving mode, BANKSIZE 128M/128M
DCD 0x30 ;MRSR6 CL=3clk
DCD 0x30 ;MRSR7 CL=3clk
ALIGN
AREA RamData, DATA, READWRITE
^ _ISR_STARTADDRESS ; _ISR_STARTADDRESS=0x33FF_FF00
HandleReset # 4
HandleUndef # 4
HandleSWI # 4
HandlePabort # 4
HandleDabort # 4
HandleReserved # 4
HandleIRQ # 4
HandleFIQ # 4
;Don't use the label 'IntVectorTable',
;The value of IntVectorTable is different with the address you think it may be.
;IntVectorTable
;@0x33FF_FF20
HandleEINT0 # 4
HandleEINT1 # 4
HandleEINT2 # 4
HandleEINT3 # 4
HandleEINT4_7 # 4
HandleEINT8_23 # 4
HandleCAM # 4 ; Added for 2440.
HandleBATFLT # 4
HandleTICK # 4
HandleWDT # 4
HandleTIMER0 # 4
HandleTIMER1 # 4
HandleTIMER2 # 4
HandleTIMER3 # 4
HandleTIMER4 # 4
HandleUART2 # 4
;@0x33FF_FF60
HandleLCD # 4
HandleDMA0 # 4
HandleDMA1 # 4
HandleDMA2 # 4
HandleDMA3 # 4
HandleMMC # 4
HandleSPI0 # 4
HandleUART1 # 4
HandleNFCON # 4 ; Added for 2440.
HandleUSBD # 4
HandleUSBH # 4
HandleIIC # 4
HandleUART0 # 4
HandleSPI1 # 4
HandleRTC # 4
HandleADC # 4
;@0x33FF_FFA0
END
