电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » SL16系列射频同轴连接器参数介绍
SL16系列射频同轴连接器参数介绍
2014-06-12 10:32:17     打赏
SL16系列射频同轴连接器参数介绍
SL16系列射频同轴连接器 SERIES RF COAXIAL CONNECTORS (即俗称 M 头)
SL16 系列是一种对阻抗匹配无严格要求的,采用端齿啮合的连接器.一般装置设计用至300MHz时运作良好。该产品特别适用在所有民用波段通讯系统、闭路电视、车载无线电装置、船舰对岸通讯,登陆降落系统及地面控制装置等。其特点是抗振性好,连接可靠,性能稳定。
SL16 Radio frequency of the type coaxial joining machine UHF Series that each match and have adoption end tooth that require strictly nibble general devices design and it spends to be at 300MHz good operation the whole person who join to impedance. This very suitable at one civil wave band communication system closed-circuit TV train years radio device products, Ship warship the other bank communication, land and fall and ground control device, etc. system. Its characteristic that anti-vibration nature is good, join reliable, performance steadily.
主要技术特性 TECHNICAL CHARACTERISTICS
温度范围 Temp.range -40~+85°C
特性阻抗 Impedance 无恒定常数 Non-constant
频率范围 Frequency Range DC~300 MHz
工作电压 Working Voltage 750V max (有效值)
耐 压 Withstand Voltage 2000V rms (海平面有效值)
接触电阻 Contact resistance
内导体之间 Center Contact ≤ 5 mΩ
外导体之间 Outer Contact ≤ 5 mΩ
绝缘电阻 Insulation resistance ≥ 5000 MΩ
耐用性 Durability(mating) ≥500次(cycles)
材料与涂覆 MATERIAL PLATING
壳体 shell 黄铜 brass 镀亮镍 nickel plated
插针 contact pin 黄铜 brass 镀金或银 gold or silver plated
插孔 socket 铍青铜 beryllium 镀金或银 gold or silver plated
绝缘体 insulator 聚四氟乙烯或聚乙烯 PTFE or PE
压接套 crimp ferrule 铜合金 copper alloy 镀亮镍 nickel plated
o型密封件o-ring sealing 硅橡胶 6146 silastic
适用技术标准 APPLICABLE STANDARD
IEC 60169-12;
GB/T 15888.
关键词: 连接器
