16 16点阵显示程序
以下是程序.
#include"config.h"
#defineDOTLED_LINE_PORTPORTB
#defineDOTLED_LINE_DDRDDRB
#defineDOTLED_LINE_PINPINB
#defineDOTLED_LINE_SCKTPB1
#defineDOTLED_LINE_SCKHPB5
#defineDOTLED_LINE_SDAPB3
#defineDOTLED_ROW_PORTPORTC
#defineDOTLED_ROW_DDRDDRC
#defineDOTLED_ROW_PINPINC
#defineDOTLED_ROW_A0PC0
#defineDOTLED_ROW_A1PC1
#defineDOTLED_ROW_A2PC2
#defineDOTLED_ROW_A3PC3
#defineDOTLED_ROW_EPC4
uint8font[]=
/*--调入了一幅图像:这是您新建的图像--*/
/*--宽度x高度=16x16--*/
0x00,0x00,0x00,0x00,0x08,0x38,0x18,0x44,0x08,0x44,0x08,0x04,0x08,0x08,0x08,0x10,
0x08,0x20,0x08,0x40,0x08,0x40,0x08,0x40,0x3E,0x7C,0x00,0x00,0x00,0x00,0x00,0x00
staticvoidTransmitByte(uint8byte);
staticvoidSelectRow(uint8row);
staticvoidFlipLatchLine(void);
uint8i;
for(i=0;i8;i++)
if(byte(1i))
DOTLED_LINE_PORT|=_BV(DOTLED_LINE_SDA);
else
DOTLED_LINE_PORT=~_BV(DOTLED_LINE_SDA);
//__delay_cycles(100);
DOTLED_LINE_PORT|=_BV(DOTLED_LINE_SCKH);
DOTLED_LINE_PORT=~_BV(DOTLED_LINE_SCKH);
//row-=1;
row|=DOTLED_ROW_PIN0xe0;
DOTLED_ROW_PORT=row;
DOTLED_LINE_PORT|=_BV(DOTLED_LINE_SCKT);
DOTLED_LINE_PORT=~_BV(DOTLED_LINE_SCKT);
voidInitDotLedPort(void)
DOTLED_LINE_PORT=~(_BV(DOTLED_LINE_SCKT)|_BV(DOTLED_LINE_SCKH));
DOTLED_LINE_DDR|=_BV(DOTLED_LINE_SCKT)|_BV(DOTLED_LINE_SCKH)|_BV(DOTLED_LINE_SDA);
DOTLED_ROW_PORT|=0x1f;
DOTLED_ROW_PORT=0xf0;
DOTLED_ROW_DDR|=0x1f;
voidEnableRow(booleanIsEnable)
if(IsEnable)
DOTLED_ROW_PORT=~_BV(DOTLED_ROW_E);
else
DOTLED_ROW_PORT|=_BV(DOTLED_ROW_E);
voidPrintDotLed(uint8*buffer)
uint8i,tmp;
for(i=0;i16;i++)
tmp=*buffer++;
TransmitByte(~tmp);
tmp=*buffer++;
TransmitByte(~tmp);
SelectRow(i);
FlipLatchLine();
voidmain(void)
InitDotLedPort();
EnableRow(TRUE);
while(1)
PrintDotLed(font);
__delay_cycles(5000);
config.h文件
#ifndef_CONFIG_H
#define_CONFIG_H
//#defineGCCAVR
#defineCPU_CYCLES7372800L
#ifndefGCCAVR
#define_BV(bit)(1(bit))
#endif
#defineMSB0x80
#defineLSB0x01
#defineFALSE0
#defineTRUE1
typedefunsignedcharuint8;
typedefunsignedintuint16;
typedefunsignedlonguint32;
typedefunsignedcharboolean;
#includeioavr.h>
#includeinavr.h>
#include"dotled.h"
#endif
16 16点阵显示电路
