大功率高频场效应管
型号 功率 增益 电压 频率 用途 封装 管脚123
MRF134 5W 14dB 28V 30-225MHz FM/AM/SSB
MRF136 15W 16dB 28V 30-225MHz FM/AM/SSB
MRF148A 30W 18dB 50V 2-225MHz FM/AM/SSB
MRF171A 45W 19,5dB 28V 30-225MHz FM/AM/SSB
MRF173 80W 13dB 28V 30-225MHz FM/AM/SSB
MRF174 125W 11,8dB 28V 30-225MHz FM/AM/SSB
MS1307 25W dB 13,5V 30MHz FM/AM/SSB TO-220 G D S 常用发射管参数型号 功率 增益 电压 频率 工作状态 封装 123脚
2N3375 10W 5dB 28V 400MHz FM/AM/SSB TO-60
2N3553 2,5W 10dB 28V 175MHz FM/AM TO-39 C B E
2N3632 20W 7dB 28V 175MHz FM TO-60
2N3866 5W 10dB 28V 400MHz WINTransceiver TO-39 C B E
2N3924 4W 6dB 13,6V 175MHz WINTransceiver TO-39
2N4427 2W 10dB 12V 175MHz WINTransceiver TO-39
2N5108 1W 5dB 24V 1200MHz WINTransceiver TO-39
2N5109 3,5W 11dB 15V 200MHz WINTransceiver TO-39
2N5421 3W 9dB 13,5V 175MHz WINTransceiver TO-39
2N5913 2W 7dB 12,5V 175MHz WINTransceiver TO-39
2N5943 1W 8dB 15V 400MHz FM TO-39
2SC730 0,8W 10dB 13,5V 175MHz FM TO-39 C B E
2SC1096 10W 60MHz FM TO-220
2SC1173 10W 100MHz FM/AM/SSB TO-220
2SC1306 16W 30MHz FM/AM/SSB TO-220 B C E
2SC1307 16W 12dB 12V 30MHz FM/AM/SSB TO-220 B C E
2SC1590 5W 10dB 12,5V 136-174MHz FM TO-220 B E C
2SC1591 14W 7,5dB 12,5V 136-174MHz FM TO-220 B E C
2SC1678 5W 30MHz WINTransceiver TO-220 B C E
2SC1728 8W 80MHz WINTransceiver TO-202 E B C
2SC1729 14W 10dB 13,5V 175MHz FM T-31E
2SC1909 10W 14,5dB 13,5V 50MHz FM/AM/SSB TO-220 B C E
2SC1944 13W 11,1dB 12V 30MHz WINTransceiver TO-220 B C E
2SC1945 16W 14,5dB 12V 30MHz FM/AM/SSB TO-220 B E C
2SC1946 25W 6,7dB 13,5V 175MHz FM T-31E
2SC1946A 30W 10dB 13,5V 175MHz FM T-31E
2SC1947 3W 10dB 13,5V 175MHz FM TO-39 C B E
2SC1957 1,8W 17dB 12V 30MHz WINTransceiver TO-126 E C B
2SC1966 3W 7,8dB 13,5V 470MHz FM T-31E
2SC1967 7W 6,7dB 13,5V 470MHz FM T-31E
2SC1968 14W 3,7dB 13,5V 470MHz FM T-31E
2SC1968A 14W 5,4dB 13,5V 470MHz FM T-31E
2SC1969 18W 12dB 12V 30MHz FM/AM/SSB TO-220 B C E
2SC1970 1,5W 10dB 13,5V 175MHz WINTransceiver TO-220 B E C
2SC1971 7W 10dB 13,5V 175MHz WINTransceiver TO-220 B E C
2SC1972 14W 10dB 13,5V 175MHz WINTransceiver TO-220 B E C
2SC1973 1W 50MHz WINTransceiver TO-92L B C E
2SC1974 13W 10dB 13,5V 30MHz WINTransceiver TO-220 B C E
2SC1975 4W 10dB 13,5V 30MHz WINTransceiver TO-220 B C E
2SC2028 1,8W 30MHz WINTransceiver TO-126 E C B
2SC2029 6W 30MHz WINTransceiver TO-220 B C E
2SC2036A 1,4W WINTransceiver TO-202 B C E
2SC2050 10W 12dB 13,5V 30MHz FM/AM/SSB TO-220 B C E
2SC2053 0,2W 15,7dB 12V 175MHz FM/AM TO-92L B C E
2SC2055 0,25W 15,3dB 12V 175MHz FM/AM TO-92L B C E
2SC2056 1,5W 9dB 12V 175MHz FM TO-39 C B E
2SC2075 4W 13,5V 27MHz WINTransceiver TO-220 B C E
2SC2078 4W 13dB 12V 100MHz FM/AM TO-220 B C E
2SC2086 0,45W 13dB 12V 175MHz FM/AM TO-92L B C E
2SC2092 4W 13dB 12V 100MHz FM/AM/SSB TO-220 B C E
2SC2094 15W 8,8dB 13,5V 175MHz FM/AM/SSB T-31E
2SC2166 6W 13,8dB 12V 30MHz FM/AM/SSB TO-220 B C E
2SC2207 16W WINTransceiver TO-220 B C E
2SC2237 6W 13,8dB 13,5V 175MHz FM T-31E
2SC2312 18,5W 27MHz FM/AM/SSB TO-220 B C E
2SC2314 1,8W 17dB 12V 180MHz FM/AM TO-126 E C B
2SC2509 13W 14dB 30MHz WINTransceiver TO-220 B C E
2SC2527 60W WINTransceiver TO-220
2SC2538 0,6W 10dB 12V 175MHz FM/AM TO-92L B C E
2SC2539 14W 14,5dB 13,5V 175MHz FM T-31E
2SC2660 30W 30MHz WINTransceiver TO-220
2SC2695 23W 1,9dB 13,5V 520MHz FM T-31E
2SC3001 6W 13dB 7,2V 175MHz FM T-31E
2SC3017 1W 11dB 13,5V 175MHz FM TO-39 C B E
2SC3018 3W 13dB 7,2V 175MHz FM T-31E
2SC3020 3W 10dB 12,5V 520MHz FM T-31E
2SC3021 7W 7,7dB 12,5V 520MHz FM T-31E
2SC3022 18W 4,8dB 12,5V 520MHz FM T-31E
2SC3103 2,8W 6,7dB 7,2V 520MHz FM T-31E
2SC3104 6W 4,8dB 7,2V 520MHz FM T-31E
2SC3133 13W 14dB 12V 1,5-30MHz FM/AM/SSB TO-220 B E C
2SC3297 15W 100MHz WINTransceiver TO-220
2SC3299 20W WINTransceiver TO-220
2SC3668 1W 100MHz WINTransceiver
2SC3807 15W 260MHz WINTransceiver TO-126
2SC4137 4W 400MHz WINTransceiver TO-126
2SC4693 FM/AM TO-92L B C E
KTC1006 1W 100MHz FM/AM TO-92L E C B
KTC1969 16W 12dB 12V 100MHz FM/AM TO-220 B C E
KTC2078 4W 11dB 12V 100MHz FM/AM TO-220 B C E
MRF161 5W 13,5dB 12,5V 225-500MHz FM/AM TO-220 B E C
MRF162 15W 13,5dB 12,5V 225-500MHz FM/AM TO-220 B E C
MRF163 25W 12dB 12,5V 225-500MHz FM/AM TO-220 B E C
MRF237 4W 12dB 18V 175MHz WINTransceiver TO-39
MRF260 5W 10dB 12,5V 136-174MHz FM TO-220 B E C
MRF261 10W 5,2dB 12,5V 136-174MHz FM TO-220 B E C
MRF262 14W 7,5dB 12,5V 136-174MHz FM TO-220 B E C
MRF264 30W 5,2dB 12,5V 136-174MHz WINTransceiver TO-220 B E C
MRF340 8W 13dB 28V 70MHz WINTransceiver TO-220 B E C
MRF342 24W 11dB 28V 70MHz WINTransceiver TO-220 B E C
MRF344 60W 6dB 28V 70MHz WINTransceiver TO-220
MRF454 80W 12dB 12,5V 1,5-30MHz FM/AM/SSB
MRF455 60W 13dB 12,5V 1,5-30MHz FM/AM/SSB
MRF475 12W 10dB 13,5V 1,5-30MHz FM/AM/SSB TO-220 B C E
MRF476 3W 15dB 13,5V 1,5-30MHz FM/AM/SSB TO-220 B C E
MRF477 40W 15dB 13,5V 1,5-30MHz FM/AM/SSB TO-220 B E C
MRF479 15W 10dB 13,5V 1,5-30MHz FM/AM/SSB TO-220
MRF485 15W 10dB 28V 1,5-30MHz WINTransceiver TO-220
MRF486 40W 15dB 28V 1,5-30MHz WINTransceiver TO-220
MRF496 40W 15dB 13,5V 1,5-30MHz WINTransceiver TO-220
MRF497 60W 10dB 13,5V 27-50MHz WINTransceiver TO-220 B E C
MRF517 0,75W 10dB 20V 1000MHz WINTransceiver TO-39
MRF607 1,75W 11,5dB 16V 175MHz WINTransceiver TO-39
MRF660 7W 5,4dB 12,5V 400-512MHz WINTransceiver TO-220
MS1226 30W 18dB 28V 30MHz FM/AM/SSB
MS1227 20W 15dB 12,5V 30MHz FM/AM/SSB
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
