* 文件名 : 蜂鸣器发声.c
* 描述 : 蜂鸣器通过交替变化的电平后,会发出蜂鸣声。
* 杜邦线接法:P1.2用杜邦线连接到J17的左边第二个。
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
uchar Count;
sbit Speak =P1^2; //蜂鸣器器控制脚
/*以下数组是音符编码*/
unsigned char code SONG[] ={ //祝你平安
0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x10,0x20,0x10,0x20,0x80,0x26,0x20,0x30,0x20,
0x30,0x20,0x39,0x10,0x30,0x10,0x30,0x80,0x26,0x20,0x20,0x20,0x20,0x20,0x1c,0x20,
0x20,0x80,0x2b,0x20,0x26,0x20,0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x80,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x60,0x40,0x10,0x39,0x10,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x80,0x26,0x20,0x2b,0x10,0x2b,0x10,
0x2b,0x20,0x30,0x10,0x39,0x10,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x20,
0x20,0x10,0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x18,0x20,0x18,0x20,0x26,0x20,
0x20,0x20,0x20,0x40,0x26,0x20,0x2b,0x20,0x30,0x20,0x30,0x20,0x1c,0x20,0x20,0x20,
0x20,0x80,0x1c,0x20,0x1c,0x20,0x1c,0x20,0x30,0x20,0x30,0x60,0x39,0x10,0x30,0x10,
0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x10,0x26,0x10,0x26,0x10,0x2b,0x10,0x2b,0x80,
0x18,0x20,0x18,0x20,0x26,0x20,0x20,0x20,0x20,0x60,0x26,0x10,0x2b,0x20,0x30,0x20,
0x30,0x20,0x1c,0x20,0x20,0x20,0x20,0x80,0x26,0x20,0x30,0x10,0x30,0x10,0x30,0x20,
0x39,0x20,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x10,0x40,0x10,0x20,0x10,
0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x00,
//路边的野华不要采
0x30,0x1C,0x10,0x20,0x40,0x1C,0x10,0x18,0x10,0x20,0x10,0x1C,0x10,0x18,0x40,0x1C,
0x20,0x20,0x20,0x1C,0x20,0x18,0x20,0x20,0x80,0xFF,0x20,0x30,0x1C,0x10,0x18,0x20,
0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,
0x30,0x80,0xFF,0x20,0x20,0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
0x20,0x2B,0x40,0x20,0x20,0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
0x20,0x2B,0x40,0x20,0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,
0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,0x30,0x80,0x20,0x30,0x1C,0x10,0x20,
0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,0x15,0x1F,
0x05,0x20,0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,
0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,
0x20,0x26,0x20,0x20,0x20,0x30,0x30,0x20,0x30,0x1C,0x10,0x18,0x40,0x1C,0x20,0x20,
0x20,0x26,0x40,0x13,0x60,0x18,0x20,0x15,0x40,0x13,0x40,0x18,0x80,0x00,
* 名称 : Time0_Init()
* 功能 : 定时器的初始化,定时时间可用光碟中软件计算,11.0592MZ晶振,10ms
* 输入 : 无
* 输出 : 无
void Time0_Init()
TMOD = 0x01;
IE = 0x82;
TH0 = 0xDC;
TL0 = 0x00;
* 名称 : Time0_Int()
* 功能 : 定时器中断,中断中实现 Count 加一
* 输入 : 无
* 输出 : 无
void Time0_Int() interrupt 1
TH0 = 0xDC;
TL0 = 0x00;
Count++; //长度加1
* 名称 : Delay_xMs()
* 功能 : 延时子程序,经过软件调试,测得延时程序大概为55us.
* 输入 : x
* 输出 : 无
void Delay_xMs(uint x)
uint i,j;
for(i=0; i<x; i++)
for(j=0; j<3; j++);
* 名称 : Play_Song()
* 功能 : 播放蜂鸣器控制程序
* 输入 : i (选择播放哪首歌曲,0为“祝你平安”,1为“路边的野花你不要采”
* 输出 : 无
void Play_Song(uchar i)
uchar Temp1,Temp2;
uint Addr;
Count = 0; //中断计数器清0
Addr = i * 217;
while(1)
Temp1 = SONG[Addr++];
if (Temp1 == 0xFF) //休止符
TR0 = 0;
Delay_xMs(100);
else if (Temp1 == 0x00) //歌曲结束符
return;
else
Temp2 = SONG[Addr++];
TR0 = 1;
while(1)
Speak = ~Speak;
Delay_xMs(Temp1);
if(Temp2 == Count)
Count = 0;
break;
* 名称 : Main()
* 功能 : 主函数
* 输入 : 无
* 输出 : 无
void Main()
Time0_Init(); //定时器0中断初始化
while(1)
Play_Song(0); //Play_Song(0)为祝你平安 Play_Song(1)为路边的野花你不要裁
