输入条件:SysKind=0--->EasmChip的操作,SysKind=1-->CpuCard的操作。
输出项目:RetData=0x00成功,RetData!=0x00:失败。
unsigned char CosReset(bool SysKind)
unsigned char i,j;
unsigned short Temp;
for(i = 0; i < 3; i ++)//---------------------------------------------------循环复位5次,若均失败则返回0xFF
WDT();
SysErrInfo = 0x00;
for(j = 0; j < 13; j++)
CosBuf[j] = 0;
Temp = 1000;//---------------------------------------------------------复位应答超时计数器
if(SysKind)
CpuCardRstDirOut;
CpuCardRstLow;
for(j=0;j<15;j++)//-------------------------------------------------上电复位延时35个ETU
WDT();
Delay10etu();
CpuCardRstHig;//----------------------------------------------------完成复位
CpuCardSdaDirIn;
while(--Temp)//-----------------------------------------------------超时时400/fi-40000 /fi
WDT();
if(!(CpuCardSdaInSt&BIT5))
CosBuf[0] = AckRecv(1);
if(CosBuf[0] == 0x3b)
CosBuf[1] = ResetReceive(1);
if( (CosBuf[1] & 0xf0) != 0x60 )
SysErrInfo = 0xFF;
else
for(j = 2; j < 4+(CosBuf[1] & 0x0F); j++)
CosBuf[j] = ResetReceive(1);
break;
WDT();
if(Temp == 0)//-----------------------------------------------------复位应答超时处理
CpuCardRstLow;
SysErrInfo = 0xFF;
else
if( (CosBuf[0] == 0x3B) && (CosBuf[1] == 0x69) )
if( (CosBuf[2] == 0x00) && (CosBuf[3] == 0x00) ) break;
else
EasmChipRstDirOut;
EasmChipRstLow;
WDT();
Delay10etu();
EasmChipRstHig;//---------------------------------------------------完成复位
EasmChipSdaDirIn;
WDT();
if(!(EasmChipSdaInSt&BIT1))
CosBuf[0] = AckRecv(0);
CosBuf[1] = ResetReceive(0);
if((CosBuf[1] & 0xf0) != 0x60)
SysErrInfo = 0xFF;
else
CosBuf[j] = ResetReceive(0);
break;
EasmChipRstLow;//-----------------------------------------------RESET = 0
SysErrInfo = 0xFF;
else
if(i < 3)
return 0x00;
else
return 0xff;
