要T0 T1产生中断其实很容易,开 ET0 允许中断,然后开 EA 就行了。
; MCU : AT89S52 at 12MHZ
; Compiler: Keil C51
; Author : Etual
; Date : 2012-1-7
;                   vector
    ORG     00H
    LJMP    RESET_HANDLER
    ORG     0BH
    LJMP    INT_T0
    ORG     1BH
    LJMP    INT_T1
;                 main program
INT_T0:
    PUSH    ACC
    PUSH    PSW
    CPL     P1.0
    POP     PSW
    POP     ACC
    RETI
	INT_T1:
    PUSH    ACC
    PUSH    PSW
    CPL     P1.1
    POP     PSW
    POP     ACC
    RETI
;                 main program
RESET_HANDLER:
    MOV     SP,#70H
MAIN:
    CALL    SYSTEM_INIT
    MOV     TMOD,#12H
    SETB    TR0
    SETB    TR1
    SETB    ET0
    SETB    ET1
    SETB    EA
LOOP:
    JMP     LOOP
;             sub  routine
; SYSTEM INIT
SYSTEM_INIT:
	SYSTEM_INIT_END:
    RET
END
