定时器是我们在嵌入式单片机里应用最广泛的外设。使用定时器的水平高低也决定着整个项目实施的水平高低。本次版主给大家带了使用TIM3定时器产生不同频率的示例。例程主要使用TIM3来产生不同频率的方波,占空比为50%,按键按下时,频率增加。
实例还是比较简单的,版主就不再多多叙述,大家直接看源代码吧!
源代码:
* @brief tim3 base 1KHz
* @param
* @retval
* @date 2015-03-31
* @note
void TIM3Freq(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
NVIC_InitTypeDef NVIC_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
/* GPIOA Configuration: TIM3 CH4 (PB1) */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource1, GPIO_AF_1);
/* Enable the TIM3 gloabal Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
TIM_TimeBaseStructure.TIM_Period = 0xFFFF;
TIM_TimeBaseStructure.TIM_Prescaler = 23;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = gCCR4_Val;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM_OC4Init(TIM3, &TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Disable);
TIM_ITConfig(TIM3, TIM_IT_CC4, ENABLE);
TIM_Cmd(TIM3, ENABLE);
* @brief TIM3_IRQHandler的中断入口函数
* @param
* @retval
* @date 2015-03-30
* @note
void TIM3_IRQHandler(void)
uint16_t capture;
/* TIM3_CH4 toggling with frequency = 4687.5 Hz */
if (TIM_GetITStatus(TIM3, TIM_IT_CC4) != RESET)
TIM_ClearITPendingBit(TIM3, TIM_IT_CC4);
capture = TIM_GetCapture4(TIM3);
TIM_SetCompare4(TIM3, capture + gCCR4_Val);
工程文件:
