现在的FPGA基本上都提供了Block RAM供用户使用,所以在自己的工程怎么用VHDL来使用这些Block RAM就非常重要。当然,还是推荐使用开发商提供的软件来生成一个RAM模块,但是这样的RAM块不论移植性还是灵活性都降低了。所以这里采用VHDL来描述一个RAM,对于不同的综合工具和约束条件,综合出的结果可能有所不同,尽管这样,其移植性和灵活性还是要比使用工具生成的RAM块好。使用不同的综合工具,只要稍加修改就可以满足自己设计的要求。
下面的VHDL代码使用ISE的XST综合,综合结果使用了Block RAM,这是我们期望的。当然有时对于用到的容量很小的RAM,我们并不需要其使用Block RAM,那么只要稍微修改一下就可以综合成Distribute RAM。具体如何修改后面再做介绍。
-- Engineer: skycanny
-- Module Name: ram - Behavioral
-- Tool versions: ISE 7.1
-- Description: This module is designed to generate a RAM
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity ram is
generic(width: integer := 16; -- used to change the memory data's width
depth: integer := 8); -- used to change the memery address' width during
-- instantiation.
port(
clk : in std_logic; --clock
addr : in std_logic_vector(depth - 1 downto 0); --address bus
cs : in std_logic; --chip select
oe : in std_logic; --output enable
--high for write
--low for read
data_i: in std_logic_vector(width - 1 downto 0); --write data bus
data_o: out std_logic_vector(width - 1 downto 0) --read data bus
end ram;
architecture Behavioral of ram is
type ram is array(2 ** depth - 1 downto 0) of std_logic_vector(width - 1 downto 0);
signal ram1 : ram;
begin
process(clk)
begin
if(clk'event and clk = '1') then
if(cs = '0') then
if(oe = '0') then
data_o <= ram1(conv_integer(addr));
else
ram1(conv_integer(addr)) <= data_i;
end if;
end if;
end if;
end process;
end Behavioral;
我们看一下综合报告:
* HDL Synthesis *
Synthesizing Unit <ram>.
Related source file is "G:/vhdl/ram/ram.vhd".
Found 256x16-bit single-port block RAM for signal <ram1>.
| mode | no-change | |
| aspect ratio | 256-word x 16-bit | |
| clock | connected to signal <clk> | rise |
| enable | connected to signal <cs> | low |
| write enable | connected to signal <oe> | high |
| address | connected to signal <addr> | |
| data in | connected to signal <data_i> | |
| data out | connected to signal <data_o> | |
| ram_style | Auto | |
Summary:
inferred 1 RAM(s).
Unit <ram> synthesized.
可见确实综合成了Block RAM。并且只要改变Width和Depth,就可以改变生成RAM的宽度和容量 。
下面是把上面的代码稍做修改后生成Distribute RAM的代码和其综合报告,可见改动是非常小的。
entity ram is
-- instantiation.
port(
--low for read
wr : in std_logic; --low for write --add for distribute ram
end ram;
signal ram1 : ram;
begin
process(clk)
begin
if(cs = '0') then
if(oe = '0') then
elsif(wr = '0') then --change for distribute ram
end if;
end if;
end if;
end process;
end Behavioral;
* HDL Synthesis *
Found 256x16-bit single-port distributed RAM for signal <ram1>.
| write enable | connected to internal node | high |
| data out | connected to internal node | |
Found 16-bit register for signal <data_o>.
Summary:
inferred 1 RAM(s).
inferred 16 D-type flip-flop(s).
由以上的讨论我们可以看出,用VHDL来描述RAM其实是非常方便,更加重要的这种方法在移植是时候有着更加优越的特点。
