电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » 调节系统显示亮度cpp代码
共3条 1/1 1 跳转至
调节系统显示亮度cpp代码
2017-12-31 12:20:16     打赏
调节系统显示亮度cpp代码
[cpp] view plain copy
  1. #include
  2.
  3. class CGammaRamp
  4. {
  5. protected:
  6.     HMODULE hGDI32;
  7.     HDC hScreenDC;
  8.     typedef BOOL (WINAPI *Type_SetDeviceGammaRamp)(HDC hDC, LPVOID lpRamp);
  9.
  10.     Type_SetDeviceGammaRamp pGetDeviceGammaRamp;
  11.     Type_SetDeviceGammaRamp pSetDeviceGammaRamp;
  12.
  13. public:
  14.
  15.     CGammaRamp();
  16.     ~CGammaRamp();
  17.     BOOL LoadLibrary();
  18.     void FreeLibrary();
  19.     BOOL LoadLibraryIfNeeded();
  20.     BOOL SetDeviceGammaRamp(HDC hDC, LPVOID lpRamp);
  21.     BOOL GetDeviceGammaRamp(HDC hDC, LPVOID lpRamp);
  22.     BOOL SetBrightness(HDC hDC, WORD wBrightness);
  23.
  24. };
  25.
  26. CGammaRamp::CGammaRamp()
  27. {
  28.     //Initialize all variables.
  29.     hGDI32 = NULL;
  30.     hScreenDC = NULL;
  31.     pGetDeviceGammaRamp = NULL;
  32.     pSetDeviceGammaRamp = NULL;
  33. }
  34.
  35. CGammaRamp::~CGammaRamp()
  36. {
  37.     FreeLibrary();
  38. }
  39.
  40.
  41. BOOL CGammaRamp::LoadLibrary()
  42. {
  43.     BOOL bReturn = FALSE;
  44.
  45.     FreeLibrary();
  46.     //Load the GDI library.
  47.     hGDI32 = ::LoadLibrary("gdi32.dll");
  48.     if (hGDI32 != NULL)
  49.     {
  50.         //Get the addresses of GetDeviceGammaRamp and SetDeviceGammaRamp API functions.
  51.         pGetDeviceGammaRamp =
  52.             (Type_SetDeviceGammaRamp)GetProcAddress(hGDI32, "GetDeviceGammaRamp");
  53.
  54.         pSetDeviceGammaRamp =
  55.             (Type_SetDeviceGammaRamp)GetProcAddress(hGDI32, "SetDeviceGammaRamp");
  56.
  57.         //Return TRUE only if these functions exist.
  58.         if (pGetDeviceGammaRamp == NULL || pSetDeviceGammaRamp == NULL)
  59.             FreeLibrary();
  60.         else
  61.             bReturn = TRUE;
  62.     }
  63.
  64.     return bReturn;
  65. }
  66.
  67.
  68. void CGammaRamp::FreeLibrary()
  69. {
  70.     //Free the GDI library.
  71.     if (hGDI32 != NULL)
  72.     {
  73.         ::FreeLibrary(hGDI32);
  74.         hGDI32 = NULL;
  75.     }
  76. }
  77.
  78.
  79. BOOL CGammaRamp::LoadLibraryIfNeeded()
  80. {
  81.     BOOL bReturn = FALSE;
  82.
  83.     if (hGDI32 == NULL)
  84.         LoadLibrary();
  85.
  86.     if (pGetDeviceGammaRamp != NULL && pSetDeviceGammaRamp != NULL)
  87.         bReturn = TRUE;
  88.
  89.     return bReturn;
  90. }
  91.
  92.
  93. BOOL CGammaRamp::SetDeviceGammaRamp(HDC hDC, LPVOID lpRamp)
  94. {
  95.     //Call to SetDeviceGammaRamp only if this function is successfully loaded.
  96.     if (LoadLibraryIfNeeded())
  97.     {
  98.         return pSetDeviceGammaRamp(hDC, lpRamp);
  99.     }
  100.     else
  101.         return FALSE;
  102. }
  103.
  104.
  105. BOOL CGammaRamp::GetDeviceGammaRamp(HDC hDC, LPVOID lpRamp)
  106. {
  107.     //Call to GetDeviceGammaRamp only if this function is successfully loaded.
  108.     if (LoadLibraryIfNeeded())
  109.     {
  110.         return pGetDeviceGammaRamp(hDC, lpRamp);
  111.     }
  112.     else
  113.         return FALSE;
  114.
  115. }
  116.
  117.
  118. BOOL CGammaRamp::SetBrightness(HDC hDC, WORD wBrightness)
  119. {
  120.     /*
  121.     Changes the brightness of the entire screen.
  122.     This function may not work properly in some video cards.
  123.
  124.     The wBrightness value should be a number between 0 and 255.
  125.     128 = Regular brightness
  126.     above 128 = brighter
  127.     below 128 = darker
  128.
  129.     If hDC is NULL, SetBrightness automatically load and release
  130.     the display device context for you.
  131.
  132.     */
  133.     BOOL bReturn = FALSE;
  134.     HDC hGammaDC = hDC;
  135.
  136.     //Load the display device context of the entire screen if hDC is NULL.
  137.     if (hDC == NULL)
  138.         hGammaDC = GetDC(NULL);
  139.
  140.     if (hGammaDC != NULL)
  141.     {
  142.         //Generate the 256-colors array for the specified wBrightness value.
  143.         WORD GammaArray[3][256];
  144.
  145.         for (int iIndex = 0; iIndex < 256; iIndex++)
  146.         {
  147.             int iArrayValue = iIndex * (wBrightness + 128);
  148.
  149.             if (iArrayValue > 65535)
  150.                 iArrayValue = 65535;
  151.
  152.             GammaArray[0][iIndex] =
  153.             GammaArray[1][iIndex] =
  154.             GammaArray[2][iIndex] = (WORD)iArrayValue;
  155.
  156.         }
  157.
  158.         //Set the GammaArray values into the display device context.
  159.         bReturn = SetDeviceGammaRamp(hGammaDC, GammaArray);
  160.     }
  161.
  162.     if (hDC == NULL)
  163.         ReleaseDC(NULL, hGammaDC);
  164.
  165.     return bReturn;
  166. }
  167.
  168.
  169. int main(int argc, char **argv)
  170. {
  171.     //Example for changing the brightness with CGammaRamp class:
  172.     //Be aware that this exmaple may not work properly in all
  173.     //Video cards.
  174.
  175.     CGammaRamp GammaRamp;
  176.
  177.     //Make the screen darker:
  178.     GammaRamp.SetBrightness(NULL, 64);
  179.
  180.     //Wait 3 seconds:
  181.     Sleep(3000);
  182.
  183.     //Return back to normal:
  184.     GammaRamp.SetBrightness(NULL, 128);
  185.
  186.     return 0;
  187. }
2018-01-01 07:51:57     打赏
谢谢楼主分享代码。
2018-01-01 15:59:59     打赏
共3条 1/1 1 跳转至
