交叉编译环境:Ubuntu12.04 (32位)
FFMPEG版本:ffmpeg-2.8.1.tar.bz2
Android NDK开发包:android-ndk32-r10b-linux-x86.tar.bz2
</pre><pre name="code" class="plain">#!/bin/bash
# FFmpeg-Android, a bash script to build FFmpeg for Android.
# Copyright (c) 2012 Cedric Fung <root@vec.io>
# FFmpeg-Android will build FFmpeg for Android automatically,
# with patches from VPlayer's Android version <https://vplayer.net/>.
# FFmpeg-Android is free software; you can redistribute it and/or
# modify it under the terms of the GNU Lesser General Public
# License as published by the Free Software Foundation; either
# version 3 of the License, or (at your option) any later version.
# FFmpeg-Android is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with FFmpeg-Android; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
# Instruction:
# 0. Install git and Android ndk
# 1. $ export ANDROID_NDK=/path/to/your/android-ndk
# 2. $ ./FFmpeg-Android.sh
# 3. libffmpeg.so will be built to build/ffmpeg/{neon,armv7,vfp,armv6}/
DEST=`pwd`/build/ffmpeg && rm -rf $DEST
SOURCE=`pwd`/ffmpeg
ANDROID_NDK=/work/FFMPEG/android-ndk-r10b
TOOLCHAIN=/work/FFMPEG/toolchain
SYSROOT=$TOOLCHAIN/sysroot/
#$ANDROID_NDK/build/tools/make-standalone-toolchain.sh --platform=android-14 --install-dir=$TOOLCHAIN
export PATH=$TOOLCHAIN/bin:$PATH
export CC="ccache arm-linux-androideabi-gcc"
export LD=arm-linux-androideabi-ld
export AR=arm-linux-androideabi-ar
CFLAGS="-O3 -Wall -mthumb -pipe -fpic -fasm \
-finline-limit=300 -ffast-math \
-fstrict-aliasing -Werror=strict-aliasing \
-fmodulo-sched -fmodulo-sched-allow-regmoves \
-Wno-psabi -Wa,--noexecstack \
-D__ARM_ARCH_5__ -D__ARM_ARCH_5E__ -D__ARM_ARCH_5T__ -D__ARM_ARCH_5TE__ \
-DANDROID -DNDEBUG"
FFMPEG_FLAGS="--prefix=/work/FFMPEG/ffmpeg_android/ \
--target-os=android \
--arch=arm \
--enable-cross-compile \
--cross-prefix=arm-linux-androideabi- \
--enable-shared \
--disable-symver \
--disable-doc \
--disable-ffplay \
--disable-ffmpeg \
--disable-ffprobe \
--disable-ffserver \
--disable-avdevice \
--disable-avfilter \
--disable-encoders \
--disable-muxers \
--disable-bsfs \
--disable-filters \
--disable-devices \
--disable-everything \
--enable-protocols \
--enable-parsers \
--enable-demuxers \
--disable-demuxer=sbg \
--enable-decoders \
--enable-network \
--enable-swscale \
--enable-version3 \
--disable-inline-asm \
--disable-yasm \
--disable-mips32r2 \
--disable-mipsdspr1 \
--disable-mipsdspr2 \
--disable-mipsfpu \
--disable-fast-unaligned \
--disable-debug \
--disable-xmm-clobber-test \
--enable-decoder=h264 \
--enable-decoder=mpeg4 \
--enable-decoder=mjpeg \
--enable-demuxer=h264 \
--enable-demuxer=mpeg4 \
--enable-demuxer=mjpeg \
--enable-parser=h264 \
--enable-memalign-hack \
--disable-asm \
--disable-altivec \
--disable-amd3dnow \
--disable-amd3dnowext \
--enable-mmx \
--enable-mmxext \
--disable-sse \
--disable-sse2 \
--disable-sse3 \
--disable-ssse3 \
--disable-sse4 \
--disable-fma4"
for version in neon armv7 vfp armv6; do
cd $SOURCE
case $version in
neon)
EXTRA_CFLAGS="-march=armv7-a -mfpu=neon -mfloat-abi=softfp -mvectorize-with-neon-quad"
EXTRA_LDFLAGS="-Wl,--fix-cortex-a8"
armv7)
EXTRA_CFLAGS="-march=armv7-a -mfpu=vfpv3-d16 -mfloat-abi=softfp"
vfp)
EXTRA_CFLAGS="-march=armv6 -mfpu=vfp -mfloat-abi=softfp"
EXTRA_LDFLAGS=""
armv6)
EXTRA_CFLAGS="-march=armv6"
EXTRA_LDFLAGS=""
EXTRA_CFLAGS=""
EXTRA_LDFLAGS=""
esac
PREFIX="$DEST/$version" && mkdir -p $PREFIX
FFMPEG_FLAGS="$FFMPEG_FLAGS --prefix=$PREFIX"
./configure $FFMPEG_FLAGS --extra-cflags="$CFLAGS $EXTRA_CFLAGS" --extra-ldflags="$EXTRA_LDFLAGS" | tee $PREFIX/configuration.txt
cp config.* $PREFIX
[ $PIPESTATUS == 0 ] || exit 1
make clean
make -j4 || exit 1
make install || exit 1
rm libavcodec/inverse.o
$CC -lm -lz -shared --sysroot=$SYSROOT -Wl,--no-undefined -Wl,-z,noexecstack $EXTRA_LDFLAGS libavutil/*.o libavutil/arm/*.o libavcodec/*.o libavcodec/arm/*.o libavformat/*.o libswresample/*.o libswscale/*.o -o $PREFIX/libffmpeg.so
cp $PREFIX/libffmpeg.so $PREFIX/libffmpeg-debug.so
arm-linux-androideabi-strip --strip-unneeded $PREFIX/libffmpeg.so
done
注意:
1、直接运行上面的脚本会出错,提示如下:
arm-linux-androideabi-gcc is unable to create an executable file.
C compiler test failed.
解决办法:
执行以上脚本前,先在命令行上执行以下命令把对NDK包中的交叉编译工具链独立提取出来到指定的目录:
/work/FFMPEG/android-ndk-r10b/build/tools/make-standalone-toolchain.sh --platform=android-14 --install-dir=/work/FFMPEG/toolchain/
2、target-os=android,此处不要再用linux了。
3、注意NDK的版本,如果应用代码中使用的是32位系统库,则交叉编译的时候就应该用32位的NDK开发包。
