电子产品世界 » 论坛首页 » 企业专区 » Xilinx » 请教各位大大Could not find a valid device tree
请教各位大大Could not find a valid device tree怎么破
2019-06-03 14:00:22     打赏
spi flash启动,按照分区依次烧写BOOT.mcs,uImage,devicetree.dtb,uramdisk.image.gz
然后按照分区修改了uboot的环境变量:setenv qspiboot 'echo Copying Linux from QSPI flash to RAM... && sf probe 0 0 0 && sf read ${kernel_load_address} 0xd00000 ${kernel_size} && sf read ${devicetree_load_address} 0x1200000 ${devicetree_size} && echo Copying ramdisk... && sf read ${ramdisk_load_address} 0x1220000 ${ramdisk_size} && bootm ${kernel_load_address} ${ramdisk_load_address} ${devicetree_load_address}\0'
另外,devicestree.dtb里分区也做了相应修改。
之后上电启动报错:
ERROR: Did not find a cmdline Flattened Device Tree
请教各位大大,这是哪里出了问题,怎么解决呢?
非常感谢!
关键词: zynq     uboot     qspi     分区     BOOT.b
2019-06-03 21:50:58     打赏
过来看看,坐等各位大神解决
