SALI-IMX6Q的uboot启动时默认选择LCD屏幕显示
在uboot启动时默认选择LCD屏幕显示这个问题我一直在想如何去实现,在经过不断地实验过后,我找到了解决办法,我是以电鱼电子公司SALI-IMX6Q开发板为例下面就分享给有需要的朋友们吧!
修改/uboot/board/freescale/mx6sabresd/mx6sabresd.c文件,如图所示:
修改如下部分:
struct display_info_t const displays[] = {{
.bus = -1,
.addr = 0,
.pixfmt = IPU_PIX_FMT_RGB24,
.detect = NULL,
.enable = enable_lvds,
.mode = {
.name = "Hannstar-XGA",
.refresh = 60,
.xres = 1920,
.yres = 1080,
.pixclock = 6734,
.left_margin = 90,
.right_margin = 50,
.upper_margin = 30,
.lower_margin = 6,
.hsync_len = 24,
.vsync_len = 3,
.sync = FB_SYNC_EXT,
.vmode = FB_VMODE_NONINTERLACED
.bus = -1,
.addr = 0,
.detect = NULL,
.enable = do_enable_hdmi,
.mode = {
.name = "HDMI",
.refresh = 60,
.xres = 640,
.yres = 480,
.pixclock = 39721,
.left_margin = 48,
.right_margin = 16,
.upper_margin = 33,
.lower_margin = 10,
.hsync_len = 96,
.vsync_len = 2,
.sync = 0,
.bus = 0,
.addr = 0,
.detect = NULL,
.enable = enable_rgb,
.mode = {
.name = "SEIKO-WVGA",
.refresh = 60,
.xres = 800,
.yres = 480,
.pixclock = 29850,
.left_margin = 89,
.right_margin = 164,
.upper_margin = 23,
.lower_margin = 10,
.hsync_len = 10,
.vsync_len = 10,
.sync = 0,
size_t display_count = ARRAY_SIZE(displays);
修改完成后如下图所示:
.bus = 0,
.addr = 0,
.detect = NULL,
.mode = {
.name = "CLAA-WVGA",
.refresh = 57,
.xres = 800,
.yres = 480,
.pixclock = 37037,
.left_margin = 40,
.right_margin = 60,
.upper_margin = 10,
.lower_margin = 10,
.hsync_len = 20,
.vsync_len = 10,
.sync = 0,
.bus = -1,
.addr = 0,
.pixfmt = IPU_PIX_FMT_RGB666,
.detect = NULL,
.mode = {
.refresh = 60,
.xres = 1024,
.yres = 768,
.pixclock = 15385,
.left_margin = 220,
.right_margin = 40,
.upper_margin = 21,
.lower_margin = 7,
.hsync_len = 60,
.vsync_len = 10,
.bus = -1,
.addr = 0,
.detect = NULL,
.mode = {
.name = "HDMI",
.refresh = 60,
.xres = 640,
.yres = 480,
.pixclock = 39721,
.left_margin = 48,
.right_margin = 16,
.upper_margin = 33,
.lower_margin = 10,
.hsync_len = 96,
.vsync_len = 2,
.sync = 0,
这样就实现了我们的目的,被这个问题所困扰的朋友们可以去试试啦,希望能够帮助到大家!
