电子产品世界 » 论坛首页 » 休闲专区 » 我爱工作 » DIODES(PERICOM)HDMI相关的主要物料型号与功能
2021-07-13 16:20:39     打赏
 Part Number & function
PI3DPX1203B :   8.1Gbps Displayport 1.4 Linear Redriver. Low-jitter, Latency Free.
PI3HDX1204B1 : 6Gbps HDMI 2.0 Redriver and Displayport Level Shifter, Low-jitter, High EQ.
PI3HDX414:  1:4 Active 3.4Gbps HDMI 1.4b Splitter/DeMux with Signal Conditioning
PI3HDX412BD : 1:2 Active 3.4Gbps HDMI 1.4b Splitter/DeMux with Signal Conditioning
PI3HDX621  :2:1 Active 3.4Gbps HDMI 1.4b Switch
PI3HDMI336 :     3:1 Active 2.5Gbps HDMI Switch with I2C control and ARC Transmitter
PI3DPX1202 :     5.4Gbps Displayport 1.2 Redriver with built-in auto test mode
PI3USB14-A :2-channel, 4:1 Multiplexer/Demultiplexer with 3-state outputs.
PI3HDMI2410FFEX:4:1 HDMI Switch Mux
PI3HDMI1310-A: 3-to-1 HDMI Mux/DeMux  Switch
PI3WVR31310AZLEX: DP/HDMI 1:3 De-mux/Mux switches
PI3WVR12412ZHEX: 4-lane,1:2 mux/demux  switches
PI3USB102EZLEX:  2:1 multiplexer/ demultiplexer USB 2.0 High-Speed (480 Mbps)  Switch.
PI5V330SQEX/PI5C3257QEX:  4 x 2:1 multiplexer/ demultiplexer 视频多路复用器/多路分解器。
PI5V331QEX:  bidirectional 2x 4:1  multiplexer/demultiplexer
PI3HDMI301FFEX:  3:1 Active Switch for HDMI Signals with Optimized Equalization for Enhanced Signal Integrity.
PI3HDMI101ZHEX:1:1 Active HDMI Redriver with Optimized Equalization & I2C Buffer.
PI3HDMI511ZLEX: HDMI1.4 Redriver Sour HDMI1.4 Redriver Source-side Applicationce-side Application
关键词: DIODES     HDMI
