电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » STC单片机做的ds1302时钟模块,走时比正常的快了十倍,不知道什么原因?
2021-09-13 14:29:40     打赏
我的ds1302走时比正常的快了十倍, 不知道什么原因? 请大侠们帮忙看一下单片机程序:
    #include <STC12C5630AD.h>
    #include <string.h>
    typedef unsigned char uint8;
    #define LCM2402_DB0_DB7 P2
    sbit LCM2402_RS = P1 ^ 5;
    sbit LCM2402_RW = P1 ^ 6;
    sbit LCM2402_E = P1 ^ 7;
    sbit LCM2402_Busy = P2 ^ 7;
    sbit DQ = P1 ^ 3;
    sbit clock_clk = P1 ^ 0;
    sbit clock_dat = P1 ^ 1;
    sbit clock_Rst = P1 ^ 2;
    data unsigned int ii;
    data unsigned char mode = 0;
    data unsigned char TIME_WW;
    #define CMD_clear 0x01
    #define CMD_back 0x02
    #define CMD_dec1 0x04
    #define CMD_add1 0x06
    #define CMD_dis_gb1 0x0f
    #define CMD_dis_gb2 0x0e
    #define CMD_dis_gb3 0x0c
    #define CMD_OFF_dis 0x08
    #define CMD_set82 0x38
    #define CMD_set81 0x30
    #define CMD_set42 0x28
    #define CMD_set41 0x20
    #define lin_1 0x80
    #define lin_2 0xc0
    void MCU_MS (unsigned int a){
    unsigned int i;
    while( --a != 0){
    for(i = 0; i < 600; i++);
    void PWM_init (void){
    CMOD=0x02;
    CL=0x00;
    CH=0x00;
    CCAPM0=0x42;
    CCAP0L=0x00;
    CCAP0H=0x00;
    CR=1;
    void PWM0_set (unsigned char a){
    CCAP0L= a;
    CCAP0H= a;
    void LCM2402_TestBusy(void){
    LCM2402_DB0_DB7 = 0xff;
    LCM2402_RS = 0;
    LCM2402_RW = 1;
    LCM2402_E = 1;
    while(LCM2402_Busy);
    LCM2402_E = 0;
    void LCM2402_WriteCMD(uint8 LCM2402_command) {
    LCM2402_TestBusy();
    LCM2402_RS = 0;
    LCM2402_RW = 0;
    LCM2402_DB0_DB7 = (LCM2402_command/16)*16;
    LCM2402_E = 1;
    LCM2402_E = 0;
    LCM2402_DB0_DB7 = (LCM2402_command%16)*16;
    LCM2402_E = 1;
    LCM2402_E = 0;
    void LCM2402_WriteData(uint8 LCM2402_data){
    LCM2402_TestBusy();
    LCM2402_RS = 1;
    LCM2402_RW = 0;
    LCM2402_DB0_DB7 = (LCM2402_data/16)*16;
    LCM2402_E = 1;
    LCM2402_E = 0;
    LCM2402_DB0_DB7 = (LCM2402_data%16)*16;
    LCM2402_E = 1;
    LCM2402_E = 0;
    void print(uint8 a,uint8 *str){
    LCM2402_WriteCMD(a | 0x80);
    while(*str != '\0'){
    LCM2402_WriteData(*str++);
    *str = 0;
    void print2(uint8 a,uint8 t){
    LCM2402_WriteData(t);
    uint8 code Xword[]={
    0x18,0x18,0x07,0x08,0x08,0x08,0x07,0x00,
    0x00,0x00,0x00,0x00,0xff,0x00,0x00,0x00,
    0x00,0x00,0x00,0x0e,0x00,0xff,0x00,0x00,
    0x00,0x00,0xff,0x00,0x0e,0x00,0xff,0x00,
    0x00,0x00,0xff,0xf5,0xfb,0xf1,0xff,0x00,
    0x00,0xfe,0x08,0xfe,0x0a,0x0a,0xff,0x00,
    0x00,0x04,0x00,0xff,0x00,0x0a,0x11,0x00,
    0x00,0x1f,0x11,0x1f,0x11,0x11,0x1f,0x00,
    void CgramWrite(void) {
    uint8 i;
    LCM2402_WriteCMD(0x06);
    LCM2402_WriteCMD(0x40);
    for(i=0;i<64;i++) {
    LCM2402_WriteData(Xword[i]);
    void LCM2402_Init(void){
    LCM2402_WriteCMD(CMD_set42); /
    sbit a0 = ACC ^ 0;
    sbit a1 = ACC ^ 1;
    sbit a2 = ACC ^ 2;
    sbit a3 = ACC ^ 3;
    sbit a4 = ACC ^ 4;
    sbit a5 = ACC ^ 5;
    sbit a6 = ACC ^ 6;
    sbit a7 = ACC ^ 7;
    void clock_out(unsigned char dd){
    ACC=dd;
    clock_dat=a0; clock_clk=1; clock_clk=0;
    clock_dat=a1; clock_clk=1; clock_clk=0;
    clock_dat=a2; clock_clk=1; clock_clk=0;
    clock_dat=a3; clock_clk=1; clock_clk=0;
    clock_dat=a4; clock_clk=1; clock_clk=0;
    clock_dat=a5; clock_clk=1; clock_clk=0;
    clock_dat=a6; clock_clk=1; clock_clk=0;
    clock_dat=a7; clock_clk=1; clock_clk=0;
    unsigned char clock_in(void){
    clock_dat=1;
    a0=clock_dat;
    clock_clk=1; clock_clk=0; a1=clock_dat;
    clock_clk=1; clock_clk=0; a2=clock_dat;
    clock_clk=1; clock_clk=0; a3=clock_dat;
    clock_clk=1; clock_clk=0; a4=clock_dat;
    clock_clk=1; clock_clk=0; a5=clock_dat;
    clock_clk=1; clock_clk=0; a6=clock_dat;
    clock_clk=1; clock_clk=0; a7=clock_dat;
    return(ACC);
    void write_clock(unsigned char ord, unsigned char dd){
    clock_clk=0;
    clock_Rst=0;
    clock_Rst=1;
    clock_out(ord);
    clock_out(dd);
    clock_Rst=0;
    clock_clk=1;
    unsigned char read_clock(unsigned char ord){
    unsigned char dd=0;
    clock_clk=0;
    clock_Rst=0;
    clock_Rst=1;
    clock_out(ord);
    dd=clock_in();
    clock_Rst=0;
    clock_clk=1;
    return(dd);
    void Init_1302(void){
    if(read_clock(0xc1) != 0xaa){
    write_clock(0x8e,0x00);
    write_clock(0x8c,0x21);
    write_clock(0x8a,0x07);
    write_clock(0x88,0x09);
    write_clock(0x86,0x015);
    write_clock(0x84,0x00);
    write_clock(0x82,0x00);
    write_clock(0x80,0x00);
    write_clock(0x90,0xa5);
    write_clock(0xc0,0xaa);
    write_clock(0x8e,0x80);
    void Delay(int num){
    while(num--) ;
    void Init_DS18B20(void){
    unsigned char x=0;
    DQ = 1;
    Delay(35);
    DQ = 0;
    Delay(480);
    DQ = 1;
    Delay(70);
    x=DQ;
    Delay(90);
    unsigned char ReadOneChar(void){
    unsigned char i=0;
    unsigned char dat = 0;
    for (i=8;i>0;i--){
    DQ = 0;
    dat>>=1;
    DQ = 1;
    if(DQ)
    dat|=0x80;
    Delay(30);
    return(dat);
    void WriteOneChar(unsigned char dat){
    unsigned char i=0;
    for (i=8; i>0; i--){
    DQ = 0;
    DQ = dat&0x01;
    Delay(30);
    DQ = 1;
    dat>>=1;
    unsigned int ReadTemperature(void){
    unsigned char a=0;
    unsigned char b=0;
    unsigned int t=0;
    float tt=0;
    Init_DS18B20();
    WriteOneChar(0xCC);
    WriteOneChar(0x44);
    Init_DS18B20();
    WriteOneChar(0xCC);
    WriteOneChar(0xBE);
    a=ReadOneChar();
    b=ReadOneChar();
    t=b;
    t<<=8;
    t=t|a;
    tt=t*0.0625;
    t= tt*10+0.5;
    return(t);
    void RealTime_Display(void){
    unsigned int i=0,o=0,o2=0;
    unsigned char a=0,b=0,c=0;
    i=ReadTemperature();
    a=i/100;
    print2(0x40,a+0x30);
    b=i/10-a*10;
    print2(0x41,b+0x30);
    print(0x42,".");
    c=i-a*100-b*10;
    print2(0x43,c+0x30);
    print2(0x44,0x00);
    print(0x00,"20");
    print2(0x02,(read_clock(0x8d)/16)+0x30);
    print2(0x03,(read_clock(0x8d)%16)+0x30);
    print(0x04,"/");
    print2(0x05,(read_clock(0x89)/16)+0x30);
    print2(0x06,(read_clock(0x89)%16)+0x30);
    print(0x07,"/");
    print2(0x08,(read_clock(0x87)/16)+0x30);
    print2(0x09,(read_clock(0x87)%16)+0x30);
    print2(0x0b,(read_clock(0x85)/16)+0x30);
    print2(0x0c,(read_clock(0x85)%16)+0x30);
    print(0x0d,":");
    print2(0x0e,(read_clock(0x83)/16)+0x30);
    print2(0x0f,(read_clock(0x83)%16)+0x30);
    print(0x10,":");
    print2(0x11,(read_clock(0x81)/16)+0x30);
    print2(0x12,(read_clock(0x81)%16)+0x30);
    TIME_WW=read_clock(0x8b)%16;
    print(0x46,"[");
    switch (TIME_WW){
    case 1:print(0x47,"Mon");break;
    case 2:print(0x47,"Tues");break;
    case 3:print(0x47,"Wed");break;
    case 4:print(0x47,"Thur");break;
    case 5:print(0x47,"Fri");break;
    case 6:print(0x47,"Sat");break;
    case 7:print(0x47,"Sun");break;
    default: print(0x47,"Error");break;
    if(TIME_WW==2||TIME_WW==4)
    print(0x4b,"]");
    else print(0x4a,"]");
    print(0x54,"Lamp brightness:");
    o=(ii/100*10+ii/10%10)*4;
    print2(0x64,o/100+0x30);
    print2(0x65,o/10%10+0x30);
    print2(0x66,o%10+0x30);
    print(0x67,"%");
    print(0x14,"-------b:");
    print(0x20,"%-------");
    print(0x4E,"MODE:");
    print2(0x53,mode+0x30);
    void main (void){
    LCM2402_Init();
    Init_1302();
    PWM_init();
    while(1){
    RealTime_Display();
关键词: ds1302     时钟     RTC
