电子产品世界 » 论坛首页 » 综合技术 » 通讯及无线技术 » IPQ6010QCN9074highpowerindustrialwifirou
IPQ6010QCN9074highpowerindustrialwifiroutersupportopenWRT/Wallys802.11axboardsDR
2022-12-09 15:16:18     打赏
IPQ6010 QCN9074 high power industrial wifi router support openWRT/Wallys 802.11ax boards DR6018V4
802.11ac and 802.11ax are different wireless (WiFi) technology standards that are present in WiFi routers or gateways.  WiFi and Internet capabilities are constantly evolving. Up until 2019, the most common wireless standard called for 802.11ac, also referred to as WiFi 5. However, in late 2019, 802.11ax (also known as WiFi 6) was launched, providing enhanced capabilities over its predecessor. These two WiFi standards are important to understand because they determine what devices you will need for your home network, which features they support, and the overall performance of your WiFi.
802.11ac is the 5th generation in WiFi standards and was introduced around 2013.  802.11ac is commonly referred to as WiFi 5 and was developed by the Wi-Fi Alliance to achieve gigabit speeds, meaning WiFi 5 could provide speeds up to 3.5 Gbps under optimal conditions.  In addition to faster speeds, WiFi 5 offered wider WiFi frequency channels that allowed wireless devices to send and receive more data, resulting in faster overall performance.  WiFi 5 (802.11ac) also introduced MU-MIMO technology that facilitated data to be sent to multiple devices simultaneously.Most notably, WiFi 5 was developed to only use the 5GHz wireless frequency, rather than both 2.4 GHz and 5 GHz frequencies.
802.11ax, or WiFi 6, is the latest WiFi standard and is the highest performing.  WiFi 6 is capable of speeds up to 9.6 Gbps which means its faster than WiFi 5, making it better for video streaming, online gaming and more high-bandwidth applications.  WiFi 6 offers more efficient data management for faster speeds and supports both the 2.4 GHz and 5 GHz frequencies for faster Internet across both frequency channels.  A new feature called Targeted Wake Time (TWT)allows your router to put the WiFi connection to sleepwhen not in use, saving the battery life of your smartphones, laptops and other connected devices until they are needed.  WiFi 6 has the power to higher number of connected devices and deliver more data to those devices, meaning you will have a much faster and more efficient Internet connection to all devices.
Here I would like to introduce you wallys 802.11ax boards and cards.
They are:
DR6018 V4
DR6018C V01
DR6018-S V02
DR8072 V01
DR5018
DR9074-6E(PN02.7)
DR9074-5G(PN02.1)
DR9074-2.4G(PN01.1)
And today lets talk about the DR6018V4 first.
DR6018 V4
This is a router board integrated with Qualcomm-Atheros IPQ6010 CPU,Processor with Quad-core ARM 64bit A53 @1.8GHz,and the System Memory is 1GB DDRL3L.32MB NOR Flash, 256MB NAND Flash,Supports Dynamic Frequency Selection (DFS),2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate,2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate,support: QUECTEL RM500Q-GL,support: QCN9074 WiFi 6E Card.
Regard to the Absolute Maximum Rating of DR6018V4,well introduce from 4 perspectives parameters:Supply Voltage,Operating Temperature Range,Storage Temperature Range and Operating Humidity Range.
For the Supply Voltage,it is 24V~48V.
For the Operating Temperature Range,it is -40ºC to +70ºC.
For the Storage Temperature Range,it is -45ºC to +105ºC.
For the Operating Humidity Range,It is 5 to +95 (non-condensing)%.
Regard to the Hardware Specifications of DR6018V4,well introduce from 17 perspectives:CPU,CPU Frequency,system memory,ethernet port,NGFF Slot,SD card Slot,USB,POE,DC Jack,LED header,Serial Port,Wireless,Bluetooth,Nor Flash,Nand Flash,DDR and Dimension.
For the CPU,it is Qualcomm-Atheros IPQ6010.
For the CPU Frequency,it is Quad-core ARM 64 bit A53 @1.8 GHz processor.
For the System Memory,it is 1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design.
For the Ethernet Port,It is 1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port.
For the NGFF Slot,It is M.2 (NGFF) E KeySocket with MiniPCIe 3.0
For the SD Card Slot,It is 1x SD Card Slot
For the USB /header,It is 1x USB 2.0 Port
For the POE,It is 24V~48V passive POE/Active POE(Suport 802.3bt)
For the DC Jack,It is 24V power supply
For the LED header,It is FFC/FPC Connector
For the Serial Port,It is 1x Serial Port 4 Pin Connector
For the Wireless,It is On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain;On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain;4 x MMCX Connectors
For the Bluetooth,It is optional
For the Nor Flash,It is 8-32MB(normally is 8MB)
For the Nand Flash,It is 256MB
For the DDR,It is 1GB
For the Dimension,It is 185mm x 116mm.
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
Email us by sales1@wallystech.com
For more information,visit our website:https://www.wallystech.com/
关键词: IPQ6010     QCN9074     power     ind
