电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » 【转载】STM32F4学习笔记一(F1和F4的独立看门狗)--from三叶
2024-05-21 23:44:21     打赏
F1和F4的独立看门狗基本一样,有一点不一样
F1的LSI = 40KHz左右,而F4的是 32KHz左右。
F4独立看门狗
F1独立看门狗
How to use this driver
  *          1. Enable write access to IWDG_PR and IWDG_RLR registers using
  *             IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable) function
  *          2. Configure the IWDG prescaler using IWDG_SetPrescaler() function
  *          3. Configure the IWDG counter value using IWDG_SetReload() function.
  *             This value will be loaded in the IWDG counter each time the counter
  *             is reloaded, then the IWDG will start counting down from this value.
  *          4. Start the IWDG using IWDG_Enable() function, when the IWDG is used
  *             in software mode (no need to enable the LSI, it will be enabled
  *             by hardware)
  *          5. Then the application program must reload the IWDG counter at regular
  *             intervals during normal operation to prevent an MCU reset, using
  *             IWDG_ReloadCounter() function.
来源: 整理文章为传播相关技术,网络版权归原作者所有,如有侵权,请联系删除。
站长统计
Digikey let's do
· 2025年第1期限时报名开启,5月8日截止
· Digikey助力,提供一站式免费器件支持
· 跟大佬一起 【DIY 功率监测与控制系统】
