电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【换取逻辑分析仪】MCXN947-传感器动态采集模板设计
2024-12-09 11:10:42     打赏
在上一篇GUI guider的使用基础上,本次设计一个传感器数据动态展示界面,并且添加时间信息。
生成针对KEIL工具链的代码,然后再打开工程。在setup_scr_screen.c源文件里面可以看到UI相关组件的代码。
void setup_scr_screen(lv_ui *ui)
	//Write codes screen
	ui->screen = lv_obj_create(NULL);
	lv_obj_set_size(ui->screen, 480, 320);
	lv_obj_set_scrollbar_mode(ui->screen, LV_SCROLLBAR_MODE_OFF);
	//Write style for screen, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
	lv_obj_set_style_bg_opa(ui->screen, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	//Write codes screen_nxpChart
	ui->screen_nxpChart = lv_chart_create(ui->screen);
	lv_chart_set_type(ui->screen_nxpChart, LV_CHART_TYPE_LINE);
	lv_chart_set_div_line_count(ui->screen_nxpChart, 3, 5);
	lv_chart_set_point_count(ui->screen_nxpChart, 5);
	lv_chart_set_range(ui->screen_nxpChart, LV_CHART_AXIS_PRIMARY_Y, 0, 100);
	lv_chart_set_axis_tick(ui->screen_nxpChart, LV_CHART_AXIS_PRIMARY_Y, 10, 5, 5, 4, true, 40);
	lv_chart_set_range(ui->screen_nxpChart, LV_CHART_AXIS_SECONDARY_Y, 0, 100);
	lv_chart_set_axis_tick(ui->screen_nxpChart, LV_CHART_AXIS_PRIMARY_X, 10, 5, 5, 4, true, 40);
	lv_chart_set_zoom_x(ui->screen_nxpChart, 256);
	lv_chart_set_zoom_y(ui->screen_nxpChart, 256);
	ui->screen_nxpChart_0 = lv_chart_add_series(ui->screen_nxpChart, lv_color_hex(0x000000), LV_CHART_AXIS_PRIMARY_Y);
#if LV_USE_FREEMASTER == 0
	lv_chart_set_next_value(ui->screen_nxpChart, ui->screen_nxpChart_0, 1);
	lv_chart_set_next_value(ui->screen_nxpChart, ui->screen_nxpChart_0, 20);
	lv_chart_set_next_value(ui->screen_nxpChart, ui->screen_nxpChart_0, 30);
	lv_chart_set_next_value(ui->screen_nxpChart, ui->screen_nxpChart_0, 40);
	lv_chart_set_next_value(ui->screen_nxpChart, ui->screen_nxpChart_0, 5);
#endif
	lv_obj_set_pos(ui->screen_nxpChart, 34, 24);
	lv_obj_set_size(ui->screen_nxpChart, 411, 273);
	lv_obj_set_scrollbar_mode(ui->screen_nxpChart, LV_SCROLLBAR_MODE_OFF);
	//Write style for screen_nxpChart, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
	lv_obj_set_style_bg_opa(ui->screen_nxpChart, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_bg_color(ui->screen_nxpChart, lv_color_hex(0xffffff), LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_bg_grad_dir(ui->screen_nxpChart, LV_GRAD_DIR_NONE, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_border_width(ui->screen_nxpChart, 1, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_border_opa(ui->screen_nxpChart, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_border_color(ui->screen_nxpChart, lv_color_hex(0xe8e8e8), LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_border_side(ui->screen_nxpChart, LV_BORDER_SIDE_FULL, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_radius(ui->screen_nxpChart, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_line_width(ui->screen_nxpChart, 2, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_line_color(ui->screen_nxpChart, lv_color_hex(0xe8e8e8), LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_line_opa(ui->screen_nxpChart, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_shadow_width(ui->screen_nxpChart, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	//Write style for screen_nxpChart, Part: LV_PART_TICKS, State: LV_STATE_DEFAULT.
	lv_obj_set_style_text_color(ui->screen_nxpChart, lv_color_hex(0x151212), LV_PART_TICKS|LV_STATE_DEFAULT);
	lv_obj_set_style_text_font(ui->screen_nxpChart, &lv_font_montserratMedium_12, LV_PART_TICKS|LV_STATE_DEFAULT);
	lv_obj_set_style_text_opa(ui->screen_nxpChart, 255, LV_PART_TICKS|LV_STATE_DEFAULT);
	lv_obj_set_style_line_width(ui->screen_nxpChart, 2, LV_PART_TICKS|LV_STATE_DEFAULT);
	lv_obj_set_style_line_color(ui->screen_nxpChart, lv_color_hex(0xe8e8e8), LV_PART_TICKS|LV_STATE_DEFAULT);
	lv_obj_set_style_line_opa(ui->screen_nxpChart, 255, LV_PART_TICKS|LV_STATE_DEFAULT);
	//Write codes screen_label_1
	ui->screen_label_1 = lv_label_create(ui->screen);
	lv_label_set_text(ui->screen_label_1, "NXP MCXN947 Cool");
	lv_label_set_long_mode(ui->screen_label_1, LV_LABEL_LONG_WRAP);
	lv_obj_set_pos(ui->screen_label_1, 112, 6);
	lv_obj_set_size(ui->screen_label_1, 245, 23);
	//Write style for screen_label_1, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
	lv_obj_set_style_border_width(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_radius(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_text_color(ui->screen_label_1, lv_color_hex(0x000000), LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_text_font(ui->screen_label_1, &lv_font_montserratMedium_16, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_text_opa(ui->screen_label_1, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_text_letter_space(ui->screen_label_1, 2, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_text_line_space(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_text_align(ui->screen_label_1, LV_TEXT_ALIGN_CENTER, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_bg_opa(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_pad_top(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_pad_right(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_pad_bottom(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_pad_left(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_shadow_width(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	//Write codes screen_digital_clock_1
	static bool screen_digital_clock_1_timer_enabled = false;
	ui->screen_digital_clock_1 = lv_dclock_create(ui->screen, "11:25:50 AM");
	if (!screen_digital_clock_1_timer_enabled) {
		lv_timer_create(screen_digital_clock_1_timer, 1000, NULL);
		screen_digital_clock_1_timer_enabled = true;
	lv_obj_set_pos(ui->screen_digital_clock_1, 289, 56);
	lv_obj_set_size(ui->screen_digital_clock_1, 130, 36);
	//Write style for screen_digital_clock_1, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
	lv_obj_set_style_radius(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_text_color(ui->screen_digital_clock_1, lv_color_hex(0xffffff), LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_text_font(ui->screen_digital_clock_1, &lv_font_montserratMedium_16, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_text_opa(ui->screen_digital_clock_1, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_text_letter_space(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_text_align(ui->screen_digital_clock_1, LV_TEXT_ALIGN_CENTER, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_bg_opa(ui->screen_digital_clock_1, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_bg_color(ui->screen_digital_clock_1, lv_color_hex(0x2195f6), LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_bg_grad_dir(ui->screen_digital_clock_1, LV_GRAD_DIR_NONE, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_pad_top(ui->screen_digital_clock_1, 7, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_pad_right(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_pad_bottom(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_pad_left(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	lv_obj_set_style_shadow_width(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
	//The custom code of screen.
	//Update current screen layout.
	lv_obj_update_layout(ui->screen);
在上段代码的倒数第二行,增加如下代码,来动态更新图表数据。
	chart = ui->screen_nxpChart;
	chart_ser1 = ui->screen_nxpChart_0;
	lv_chart_set_update_mode(ui->screen_nxpChart,LV_CHART_UPDATE_MODE_SHIFT);     //设置循环刷新
	lv_timer_create(add_data, 1, NULL);
本段代码创建了一个LVGL的内部定时间,单位是毫秒。该回调函数的实现如下:
static void add_data(lv_timer_t * timer)
    LV_UNUSED(timer);
    static uint32_t cnt = 0;
    lv_chart_set_next_value(chart, chart_ser1, lv_rand(20, 90));
    cnt++;
这样就可以使用随机数来验证图表是否能正常刷新显示。
数字时钟的UI代码如下:
实物效果:
站长统计
Digikey let's do
· 2025年第1期限时报名开启,5月8日截止
· Digikey助力,提供一站式免费器件支持
· 跟大佬一起 【DIY 功率监测与控制系统】
