Company: I/O Interconnect, Santa Ana. CA USA
Location: 深圳 中国 Salary: Negotiable, and compatible. Send Resume t timx@ioint.com and jinink@ioint.com _________________________________________________________________________ Sr Firmware Engineer for PC Peripherals - Five or more years of experience in designing, coding and debugging embedded firmware. - Read hardware schematics, IC data sheets and language reference manuals. - Experience writing in the following languages - 8051 assembler - ARM 7 assembler - C and C++ - Windows DDM experience is a plus - Experience with real-time, multi-threaded RTOS. experience. - Demonstrate ability to use the following tools: - IDE (Integrated Developer Environment: Editor, Compiler, Linker, Debugger) - Software Debugger - ARM ICE (In Circuit Emulator) - Scope - Logic Analyzer - PROM Programmer - Soldering Iron - Experience debugging new system board designes - Understanding of optical peripherals is a plus. This includes: Interfaces, data rates, media formts and file systems e.g. MPEG(x), CD, DVD, UDF, ISO9660 etc. _______________________________________________________________________________ Jr Firmware Engineer for PC Peripherals - Two or more years of experience in coding and debugging embedded firmware. - IC data sheets and language reference manuals - Experience writing in the following languages - ARM 7 assembler - C and C++ - Windows DDM experience is a plus - Experience with real-time, multi-threaded RTOS. - Demonstrate ability to use the following tools: - IDE (Integrated Developer Environment: Editor, Compiler, Linker, Debugger) - Software Debugger - ARM ICE (In Circuit Emulator) - PROM Programmer - Soldering Iron 我要赚赏金打赏帖 |
