共3条
庆祝,庆祝!编译通过...
在各位的帮助下,系统编译通过,谢谢各位特别是 "DrCZL".
C:\Tppc\target\config\bcm5600>make CPU=PPC603 SSP_NAME=bcm5600 TMS_CFLAGS=-DBOOT
ROM bootrom.bin
C:\Tppc\target/h/make/rules.x86-win32:26: warning: overriding commands for targe
t `depend.bcm5600'
C:\Tppc\target/h/make/rules.ssp:199: warning: ignoring old commands for target `
depend.bcm5600'
ccppc -BC:\Tppc/host/x86-win32/lib/gcc-lib/ -M -MG -mstrict-align -ansi -nostdin
c -O2 -fvolatile -fno-builtin -fno-for-scope -Wall -I/h -I. -IC:\Tppc\target/h/
tms -IC:\Tppc\target/h/tms/stp -IC:\Tppc\target/h/tms/swdrv -IC:\Tppc\target/h/t
ms/swdrv/bcm5600_ssp -IC:\Tppc\target/h/tms/idb -IC:\Tppc\target/h/tms/libt -IC:
\Tppc\target/h/tms/common -IC:\Tppc\target/h/tms/swdrv/bcm5600_ssp/orion/include
-I. -IC:\Tppc\target\config\all -IC:\Tppc\target/h -IC:\Tppc\target/src/config
-IC:\Tppc\target/src/drv -DCPU=PPC603 -DTMS -DBCM5600_B0 -DMOUSSE -DVXWORKS -D
BROADCOM_BSP -DBOOTROM -g -O0 appConfig.c bootConfig.c dec21x4xEnd.c dnlValidat
e.c epic.c flashFsLib.c flashLib.c ftpXfer2.c i8250Sio.c m48t59y.c pciConfigLib.
c pciConfigShow.c pciSupport.c portTable.c srecLoad.c sysCache.c sysConfig.c sys
Lib.c sysNetyk.c sysSerial.c sysSwitch.c sysflash.c usrConfig.c C:\Tppc\target\c
onfig\all/bootConfig.c C:\Tppc\target\config\all/bootInit.c C:\Tppc\target\confi
g\all/dataSegPad.c C:\Tppc\target\config\all/usrConfig.c C:\Tppc\target\config\a
ll/version.c > depend.bcm5600
ccppc -BC:\Tppc/host/x86-win32/lib/gcc-lib/ -E -P -xc -M -E -I/h -I. -IC:\Tppc\
target/h/tms -IC:\Tppc\target/h/tms/stp -IC:\Tppc\target/h/tms/swdrv -IC:\Tppc\t
arget/h/tms/swdrv/bcm5600_ssp -IC:\Tppc\target/h/tms/idb -IC:\Tppc\target/h/tms/
libt -IC:\Tppc\target/h/tms/common -IC:\Tppc\target/h/tms/swdrv/bcm5600_ssp/orio
n/include -I. -IC:\Tppc\target\config\all -IC:\Tppc\target/h -IC:\Tppc\target/sr
c/config -IC:\Tppc\target/src/drv -DCPU=PPC603 romInit.s >> depend.bcm5600
c/config -IC:\Tppc\target/src/drv -DCPU=PPC603 sysALib.s >> depend.bcm5600
wtxtcl C:\Tppc/host/src/hutils/bspDepend.tcl depend.bcm5600
t `depend.bcm5600'
depend.bcm5600'
ccppc -BC:\Tppc/host/x86-win32/lib/gcc-lib/ -c -mstrict-align -ansi -nostdinc -O
2 -fvolatile -fno-builtin -fno-for-scope -Wall -I/h -I. -IC:\Tppc\target/h/tms
-IC:\Tppc\target/h/tms/stp -IC:\Tppc\target/h/tms/swdrv -IC:\Tppc\target/h/tms/s
wdrv/bcm5600_ssp -IC:\Tppc\target/h/tms/idb -IC:\Tppc\target/h/tms/libt -IC:\Tpp
c\target/h/tms/common -IC:\Tppc\target/h/tms/swdrv/bcm5600_ssp/orion/include -I.
-IC:\Tppc\target\config\all -IC:\Tppc\target/h -IC:\Tppc\target/src/config -IC:
\Tppc\target/src/drv -DCPU=PPC603 -DTMS -DBCM5600_B0 -DMOUSSE -DVXWORKS -DBROA
DCOM_BSP -DBOOTROM -g -O0 C:\Tppc\target\config\all\bootInit.c
ccppc -BC:\Tppc/host/x86-win32/lib/gcc-lib/ -mstrict-align -ansi -nostdinc -O2 -
fvolatile -fno-builtin -fno-for-scope -I/h -I. -IC:\Tppc\target/h/tms -IC:\Tppc
\target/h/tms/stp -IC:\Tppc\target/h/tms/swdrv -IC:\Tppc\target/h/tms/swdrv/bcm5
600_ssp -IC:\Tppc\target/h/tms/idb -IC:\Tppc\target/h/tms/libt -IC:\Tppc\target/
h/tms/common -IC:\Tppc\target/h/tms/swdrv/bcm5600_ssp/orion/include -I. -IC:\Tpp
c\target\config\all -IC:\Tppc\target/h -IC:\Tppc\target/src/config -IC:\Tppc\tar
get/src/drv -DCPU=PPC603 -DTMS -DBCM5600_B0 -DMOUSSE -DVXWORKS -DBROADCOM_BSP
-DBOOTROM -g -O0 -P -x assembler-with-cpp -c -o romInit.o romInit.s
DCOM_BSP -DBOOTROM -g -O0 C:\Tppc\target/config/bcm5600/bootConfig.c
-DBOOTROM -g -O0 -P -x assembler-with-cpp -c -o sysALib.o sysALib.s
fvolatile -fno-builtin -fno-for-scope -Wall -I/h -I. -IC:\Tppc\target/h/tms -IC
:\Tppc\target/h/tms/stp -IC:\Tppc\target/h/tms/swdrv -IC:\Tppc\target/h/tms/swdr
v/bcm5600_ssp -IC:\Tppc\target/h/tms/idb -IC:\Tppc\target/h/tms/libt -IC:\Tppc\t
arget/h/tms/common -IC:\Tppc\target/h/tms/swdrv/bcm5600_ssp/orion/include -I. -I
C:\Tppc\target\config\all -IC:\Tppc\target/h -IC:\Tppc\target/src/config -IC:\Tp
pc\target/src/drv -DCPU=PPC603 -DTMS -DBCM5600_B0 -DMOUSSE -DVXWORKS -DBROADCO
M_BSP -DBOOTROM -g -O0 -c sysLib.c
M_BSP -DBOOTROM -g -O0 -c epic.c
M_BSP -DBOOTROM -g -O0 -c m48t59y.c
M_BSP -DBOOTROM -g -O0 -c sysCache.c
M_BSP -DBOOTROM -g -O0 -c sysSerial.c
M_BSP -DBOOTROM -g -O0 -c dnlValidate.c
M_BSP -DBOOTROM -g -O0 -c dec21x4xEnd.c
M_BSP -DBOOTROM -g -O0 -c flashLib.c
M_BSP -DBOOTROM -g -O0 -c flashFsLib.c
M_BSP -DBOOTROM -g -O0 -c pciConfigLib.c
M_BSP -DBOOTROM -g -O0 -c pciConfigShow.c
M_BSP -DBOOTROM -g -O0 -c pciSupport.c
M_BSP -DBOOTROM -g -O0 -c ftpXfer2.c
M_BSP -DBOOTROM -g -O0 -c srecLoad.c
DCOM_BSP -DBOOTROM -g -O0 -o version.o C:\Tppc\target\config\all/version.c
ldppc -o tmp.o -X -N -Map mousse.map -e usrInit \
-Ttext 00c00000 bootConfig.o version.o sysALib.o sysLib.o epic.o m48t59y.o
sysCache.o sysSerial.o dnlValidate.o dec21x4xEnd.o flashLib.o flashFsLib.o pciCo
nfigLib.o pciConfigShow.o pciSupport.o ftpXfer2.o srecLoad.o C:\Tppc\target/li
b/libPPC603gnutms.a C:\Tppc\target/lib/libPPC603gnuospfv2.a C:\Tppc\target/lib/l
ibPPC603gnuenvoy.a C:\Tppc\target/lib/libPPC603gnuzlib.a C:\Tppc\target/lib/libP
PC603gnuBCM5600_B0drv.a C:\Tppc\target/lib/libPPC603gnutms.a C:\Tppc\target/lib/
objPPC603gnuBCM5600_B0drv/libdiag.a C:\Tppc\target/lib/objPPC603gnuBCM5600_B0drv
/libtest.a C:\Tppc\target/lib/objPPC603gnuBCM5600_B0drv/libsal.a C:\Tppc\target/
lib/objPPC603gnuBCM5600_B0drv/libbcm.a C:\Tppc\target/lib/objPPC603gnuBCM5600_B0
drv/libsoc.a C:\Tppc\target/lib/objPPC603gnuBCM5600_B0drv/libsal.a C:\Tppc\targe
t/lib/libPPC603gnuvx.a
C:\Tppc\host\x86-win32\bin\elfToBin < tmp.o | C:\Tppc\host\x86-win32\bin\deflate
> tmp.Z
Deflation: 69.09%
C:\Tppc\host\x86-win32\bin\binToAsm tmp.Z >bootrom.Z.s
-DBOOTROM -g -O0 -P -x assembler-with-cpp -c -o bootrom.Z.o bootrom.Z.s
ldppc -X -N -Map mousse.map -e _romInit -Ttext 00010000 \
-o bootrom romInit.o bootInit.o version.o \
C:\Tppc\target/lib/libPPC603gnutms.a C:\Tppc\target/lib/libPPC603gnuospfv2.a
C:\Tppc\target/lib/libPPC603gnuenvoy.a C:\Tppc\target/lib/libPPC603gnuzlib.a C:
\Tppc\target/lib/libPPC603gnuBCM5600_B0drv.a C:\Tppc\target/lib/libPPC603gnutms.
a C:\Tppc\target/lib/objPPC603gnuBCM5600_B0drv/libdiag.a C:\Tppc\target/lib/objP
PC603gnuBCM5600_B0drv/libtest.a C:\Tppc\target/lib/objPPC603gnuBCM5600_B0drv/lib
sal.a C:\Tppc\target/lib/objPPC603gnuBCM5600_B0drv/libbcm.a C:\Tppc\target/lib/o
bjPPC603gnuBCM5600_B0drv/libsoc.a C:\Tppc\target/lib/objPPC603gnuBCM5600_B0drv/l
ibsal.a C:\Tppc\target/lib/libPPC603gnuvx.a bootrom.Z.o
C:\Tppc\host\x86-win32\bin\romsize PPC -b 00300000 bootrom
bootrom: 16328(t) + 264686(d) = 281014 (2864714 unused)
C:\Tppc/host/x86-win32/bin/objcopyppc -S --output-target=binary bootrom bootrom.
tmp
wtxtcl C:\Tppc/host/resource/tcl/ddtcl.tcl bs=256 skip=256 if=bootrom.tmp of=boo
trom.bin
Blocks written: 1098
wtxtcl C:\Tppc/host/resource/tcl/crc32.tcl bootrom.bin
(BOOTROM Version: Broadcom 2.0/15, Jul 23 2001, 12:08:20).
Size: 000449B8 CRC Value: 62885257
关键词: 庆祝 编译 通过 target config bc
共3条
