共3条
有没有好心的汇编和c语言高手?
我最近买了个lcd,怎么都点不亮?我把使用手册和测试程序都翻烂了,调试了半个月,还没成功!
估计是我汇编和c语言功底不行,有些细节没注意到,能不能浪费您点时间帮我把这个51汇编程序给翻译成AVR上的c语言程序?
我非常感谢您的帮助!
;********* LCD10-3V TEST **********************
;/CS=P1.5 /WR=P1.3 DATA=P1.2 ********************
;RAM 20H:COMMAND CODE ********************
;RAM 21H: LCD ADDR ***
;RAM 25H: LCD DATA ***
ORG 0000H
JMP START
ORG 0100H
START: MOV P1,#0FFH
SETB P3.7
CALL DLY500
MOV 20H,#00100100B ;INITIALIZE
CALL WRCOM
MOV 20H,#00011000B ;RC
CALL WRCOM
MOV 20H,#00000001B ;SYS EN
CALL WRCOM
MOV 20H,#00000011B ;LCD ON
CALL WRCOM
MOV 21H,#00000000B ;CLEAR DISPLAY
MOV 23H,21H
MOV R6,#0
CALL WRDD
MOV 25H,#00000000B ;FIRST ADDR
MOV 27H,25H
CALL WRDA
CALL WALP
CALL DLY1S
MOV 21H,#00000000B ;DISPLAY 8
MOV 23H,21H
MOV R6,#0
CALL WRDD
MOV 25H,#00001111B
MOV 27H,25H
CALL WRDA
CALL WALP
MOV P1,#0FFH
CALL DLY1S
CALL DLY500 ;DISPLAY 123
MOV P1,#0FFH
CALL DLY1S
CALL WR123
MOV P1,#0FFH
CALL DLY1S
CALL DLY1S
MOV 21H,#00000000B ;DISPLAY D0
MOV 23H,21H
MOV R6,#0
CALL WRDD
MOV 25H,#00000001B
MOV 27H,25H
CALL WRDA
CALL WALP
MOV P1,#0FFH
CALL DLY1S
MOV 21H,#00000000B ;DISPLAY D1
MOV 23H,21H
MOV R6,#0
CALL WRDD
MOV 25H,#00000010B
MOV 27H,25H
CALL WRDA
CALL WALP
MOV P1,#0FFH
CALL DLY1S
MOV 21H,#00000000B ;DISPLAY D2
MOV 23H,21H
MOV R6,#0
CALL WRDD
MOV 25H,#00000100B
MOV 27H,25H
CALL WRDA
CALL WALP
MOV P1,#0FFH
CALL DLY1S
MOV 21H,#00000000B ;DISPLAY D3
MOV 23H,21H
MOV R6,#0
CALL WRDD
MOV 25H,#00001000B
MOV 27H,25H
CALL WRDA
CALL WALP
MOV P1,#0FFH
CALL DLY1S
STOP: MOV P1,#0FFH
CALL DLY1S
MOV 20H,#02H ;LCD OFF
CALL WRCOM
MOV P1,#0FFH
MOV 20H,#00H ;SYS DI
MOV 20H,#00001101B ;CTC=0
CALL WRCOM
MOV 20H,#00001001B ;BZ ON
CALL WRCOM
MOV 20H,#01100000B ;BZ =2KHZ
CALL WRCOM
CALL DLY1S
MOV 20H,#00001000B ;BZ OFF
CALL WRCOM
CALL DLY500
SETB P3.7 ;WDT LED OFF
SETB P1.7 ;TEST WDT
JNB P1.7,SE0
SETB 20H
JMP SS1
SE0: CLR 20H
SS1: NOP
MOV 20H,#10100110B ;WDT=1/16 S
CALL WRCOM
CALL WRCOM
MOV 20H,#00001110B ;WDT=0
CALL WRCOM
MOV 20H,#00000111B ;WDT ON
CALL WRCOM
MOV 20H,#10001000B ;WDT/CTC EN
CALL WRCOM
CALL DLY500 ;1S
CALL DLY500 ;1S
JNB P1.7,SE00
SETB 21H
JMP SS2
SE00: CLR 21H
SS2: JNB 20H,SS3
JB 21H,SS3
CLR P3.7 ;WDT LED OK
CALL DLY1S ;1S
CALL DLY1S ;1S
JMP SS4
SS3: SETB P3.7 ;WDT LED OFF
SS4:
MOV 20H,#00000101B ;WDT OFF
CALL WRCOM
MOV 20H,#10000000B ;WDT/CTC DIS
CALL WRCOM
CALL WRCOM
MOV 20H,#03H ;LCD ON
CALL WRCOM
JMP START
;**** LCD DRIVER MODE SUB. **************
;**** WRITE COMMAND SUB. ***********
WRCOM: SETB P1.5 ;/CS=1
NOP
CALL DLY5
CLR P1.5 ;/CS=0
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
NOP
SETB P1.2 ;D=1 (100)
CALL DLY5
NOP
SETB P1.3 ;/WR=1
CALL DLY5
NOP
CLR P1.3 ;/WR=0
CALL DLY5
NOP
CLR P1.2 ;D=0
CALL DLY5
NOP
SETB P1.3 ;/WR=1
CALL DLY5
NOP
CLR P1.3 ;/WR=0
CALL DLY5
NOP
CLR P1.2 ;D=0
CALL DLY5
NOP
SETB P1.3 ;/WR=1
CALL DLY5
NOP
MOV R7,#9 ;LOOP=DATA 8 BIT +1X
CLR C
LOOPWR: NOP
CALL DLY5
CLR P1.3
CALL DLY5
MOV A,20H
RLC A
MOV 20H,A
JC WR1
CLR P1.2 ;DATA=0
CALL DLY5
JMP WRR
WR1: SETB P1.2 ;DATA=1
CALL DLY5
WRR: SETB P1.3
CALL DLY5
DJNZ R7,LOOPWR
RET
;**** LOOP WRDA SUB. ****
WALP:
ST1: MOV 21H,23H
MOV A,21H
ADD A,#00000100B
MOV 21H,A
MOV 23H,A
INC R6
CALL WRDD
MOV 25H,27H
CALL WRDA
CJNE R6,#31,ST1
RET
;**** WRITE DATA SUB.****************************
WRDD: SETB P1.5 ;/CS=1
CALL DLY5
NOP
CLR P1.5 ;/CS=0
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
SETB P1.2 ;D=1 (101)
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
CLR P1.2 ;D=0
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
SETB P1.2 ;D=1
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
MOV R4,#6
MOV 22H,21H
ADDWR2: NOP
CALL DLY5
CLR P1.3
CALL DLY5
MOV A,21H
RLC A
MOV 21H,A
JC WR11
CLR P1.2 ;DATA=0
CALL DLY5
JMP WRR1
WR11: NOP
CALL DLY5
SETB P1.2 ;DATA=1
CALL DLY5
WRR1: NOP
CALL DLY5
SETB P1.3
CALL DLY5
DJNZ R4,ADDWR2
RET
WRDA: MOV R5,#4 ;LOOP=DATA 4 BIT
ADDWR3: NOP
CALL DLY5
CLR P1.3
CALL DLY5
MOV A,25H
RRC A
MOV 25H,A
JC WR12
CLR P1.2 ;DATA=0
CALL DLY5
JMP WRR2
WR12: NOP
CALL DLY5
SETB P1.2 ;DATA=1
CALL DLY5
WRR2: NOP
CALL DLY5
SETB P1.3
CALL DLY5
DJNZ R5,ADDWR3
RET
DLY5: NOP
NOP
NOP
NOP
RET
DLY25M: MOV R1,#250 ;12M/2.5MS
DLOP: CALL DLY5
CALL DLY5
DJNZ R1,DLOP
RET
DLY1S: MOV R0,#20 ;1S
DLOP1: CALL DLY25M
CALL DLY25M
DJNZ R0,DLOP1
RET
DLY500: MOV R0,#5
DLOP11: CALL DLY25M
CALL DLY25M
DJNZ R0,DLOP11
RET
;**** LIANXV WR SUB. ****
WR123: NOP
SETB P1.5 ;/CS=1
CALL DLY5
NOP
CLR P1.5 ;/CS=0
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
CLR P1.2 ;D=0
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
SETB P1.2 ;D=1
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
MOV R2,#6
LOOP: CLR P1.3 ;/WR=0
CALL DLY5
CLR P1.2 ;D=0
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
DJNZ R2,LOOP
MOV R3,#32
MOV DPTR,#TABDA
LOOP1: CLR A
MOVC A,@A+DPTR
MOV 25H,A
CALL WRDA
INC DPTR
DJNZ R3,LOOP1
RET
TABDA: DB 05H,02H,06H,05H,06H,06H,07H,04H,07H,07H,06H,07H,04H,00H,02H,07H;
DB 06H,02H,07H,04H,06H,02H,04H,06H,07H,00H,04H,07H,02H,06H,00H,00H;
END
答 1: 你用的是什么LCD?前些天我刚写了个程序16*2标准的点阵字符型,点亮LCD必须正确初始化 答 2: 我用的是段式的lcm1010,至于驱动程序我都快翻烂了我检查了半个月也没检查出来错误,不知是什么原因?
我身边有个人用51汇编12m晶振写的程序都可以
所以我怀疑atmega8l单片机会不会有问题,比如驱动不了,这是我猜测的
我用的是8M晶振,iccAVR编译的,使用c语言,我们这里没人用过AVR也没人用过c语言
你能不能帮个忙,我可以把lcd资料发给您,上面是他的测试程序 答 3: 初始化很重要的应该没什么问题啊
有电路图吗? 答 4: 电路图很简单的,只是一个单片机和lcdlcd的vdd--+5v
vlcd--32k电阻---+5v
data---portd6
cd-----portd7
wr-----portb0
单片机使用内部8m晶振,再就是连一个电源和gnd,另外5k电阻++5v电源接reset,单片机工作正常,我用指示灯看过,置高置低都像我预期的那样,估计是在细节方面出错 答 5: 你的DELAY是不是太段了,可以用长一点的时间。
答 6: 怎么不考虑直接将它转换成AVR的汇编程序如果这个51汇编程序没问题,怎么不考虑直接将它转换成AVR的汇编程序?两者的指令系统有很大的相似之处 答 7: 已经够长了吧,要求200ms,我都500ms了 答 8: 我建议你从硬件查起将你的发送数据的程序写成一个死循环,然后让程序全速运行,用示波器观察信号看看是否正常,如果你要详细的指导,请回应信息给我。 答 9: to wyaner8非常感谢您,怎么和您联系
我需要详细的指导,着急 答 10: 如果是用44780核心的lcd,我发的给你(c)。lcm1010我没用过 答 11: 谢谢!我得用段式的 答 12: 你可以找相关的c源程序一般LCD使用说明里会带C程序的例程!
还有就是要注意对比度就是正压负压要调整好
我也是刚开始弄了半天没显示,原来是负压调太低了
还有,写入的时序要对 答 13: 这些我都试过了,电源跟定没问题,因为我用别人的51单片机都行 答 14: 请看看我的意见这位老兄,你若有兴趣可把lcd的资料与本来用51编的那个原理图发到我e-mail里(nbshl@tom.com)!反正我这几天没事做!和现在要用AVR的原理图! 答 15: 看看1621!
我非常感谢您的帮助!
ORG 0000H
JMP START
ORG 0100H
START: MOV P1,#0FFH
SETB P3.7
CALL DLY500
CALL WRCOM
CALL WRCOM
CALL WRCOM
CALL WRCOM
MOV 23H,21H
MOV R6,#0
CALL WRDD
MOV 27H,25H
CALL WRDA
CALL WALP
CALL DLY1S
MOV 23H,21H
MOV R6,#0
CALL WRDD
MOV 25H,#00001111B
MOV 27H,25H
CALL WRDA
CALL WALP
MOV P1,#0FFH
CALL DLY1S
MOV P1,#0FFH
CALL DLY1S
CALL WR123
MOV P1,#0FFH
CALL DLY1S
CALL DLY1S
MOV 23H,21H
MOV R6,#0
CALL WRDD
MOV 25H,#00000001B
MOV 27H,25H
CALL WRDA
CALL WALP
MOV P1,#0FFH
CALL DLY1S
MOV 23H,21H
MOV R6,#0
CALL WRDD
MOV 25H,#00000010B
MOV 27H,25H
CALL WRDA
CALL WALP
MOV P1,#0FFH
CALL DLY1S
MOV 23H,21H
MOV R6,#0
CALL WRDD
MOV 25H,#00000100B
MOV 27H,25H
CALL WRDA
CALL WALP
MOV P1,#0FFH
CALL DLY1S
MOV 23H,21H
MOV R6,#0
CALL WRDD
MOV 25H,#00001000B
MOV 27H,25H
CALL WRDA
CALL WALP
MOV P1,#0FFH
CALL DLY1S
STOP: MOV P1,#0FFH
CALL DLY1S
CALL WRCOM
MOV P1,#0FFH
CALL WRCOM
CALL WRCOM
CALL WRCOM
CALL DLY1S
CALL WRCOM
CALL DLY500
SETB P1.7 ;TEST WDT
JNB P1.7,SE0
SETB 20H
JMP SS1
SE0: CLR 20H
SS1: NOP
CALL WRCOM
CALL WRCOM
CALL WRCOM
CALL WRCOM
CALL WRCOM
CALL DLY500 ;1S
CALL DLY500 ;1S
JNB P1.7,SE00
SETB 21H
JMP SS2
SE00: CLR 21H
SS2: JNB 20H,SS3
JB 21H,SS3
CALL DLY1S ;1S
CALL DLY1S ;1S
JMP SS4
SS4:
CALL WRCOM
CALL WRCOM
CALL WRCOM
CALL WRCOM
JMP START
NOP
CALL DLY5
CLR P1.5 ;/CS=0
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
NOP
CALL DLY5
NOP
SETB P1.3 ;/WR=1
CALL DLY5
NOP
CLR P1.3 ;/WR=0
CALL DLY5
NOP
CLR P1.2 ;D=0
CALL DLY5
NOP
SETB P1.3 ;/WR=1
CALL DLY5
NOP
CLR P1.3 ;/WR=0
CALL DLY5
NOP
CLR P1.2 ;D=0
CALL DLY5
NOP
SETB P1.3 ;/WR=1
CALL DLY5
NOP
CLR C
LOOPWR: NOP
CALL DLY5
CLR P1.3
CALL DLY5
MOV A,20H
RLC A
MOV 20H,A
JC WR1
CLR P1.2 ;DATA=0
CALL DLY5
JMP WRR
CALL DLY5
WRR: SETB P1.3
CALL DLY5
DJNZ R7,LOOPWR
RET
WALP:
ST1: MOV 21H,23H
MOV A,21H
ADD A,#00000100B
MOV 21H,A
MOV 23H,A
INC R6
CALL WRDD
MOV 25H,27H
CALL WRDA
CJNE R6,#31,ST1
RET
CALL DLY5
NOP
CLR P1.5 ;/CS=0
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
CLR P1.2 ;D=0
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
SETB P1.2 ;D=1
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
MOV R4,#6
MOV 22H,21H
ADDWR2: NOP
CALL DLY5
CLR P1.3
CALL DLY5
MOV A,21H
RLC A
MOV 21H,A
JC WR11
CLR P1.2 ;DATA=0
CALL DLY5
JMP WRR1
WR11: NOP
CALL DLY5
SETB P1.2 ;DATA=1
CALL DLY5
WRR1: NOP
CALL DLY5
SETB P1.3
CALL DLY5
DJNZ R4,ADDWR2
RET
ADDWR3: NOP
CALL DLY5
CLR P1.3
CALL DLY5
MOV A,25H
RRC A
MOV 25H,A
JC WR12
CLR P1.2 ;DATA=0
CALL DLY5
JMP WRR2
WR12: NOP
CALL DLY5
SETB P1.2 ;DATA=1
CALL DLY5
WRR2: NOP
CALL DLY5
SETB P1.3
CALL DLY5
DJNZ R5,ADDWR3
RET
DLY5: NOP
NOP
NOP
NOP
RET
DLOP: CALL DLY5
CALL DLY5
DJNZ R1,DLOP
RET
DLOP1: CALL DLY25M
CALL DLY25M
DJNZ R0,DLOP1
RET
DLY500: MOV R0,#5
DLOP11: CALL DLY25M
CALL DLY25M
DJNZ R0,DLOP11
RET
WR123: NOP
SETB P1.5 ;/CS=1
CALL DLY5
NOP
CLR P1.5 ;/CS=0
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
CLR P1.2 ;D=0
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
CLR P1.3 ;/WR=0
CALL DLY5
SETB P1.2 ;D=1
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
MOV R2,#6
CALL DLY5
CLR P1.2 ;D=0
CALL DLY5
SETB P1.3 ;/WR=1
CALL DLY5
DJNZ R2,LOOP
MOV R3,#32
MOV DPTR,#TABDA
LOOP1: CLR A
MOVC A,@A+DPTR
MOV 25H,A
CALL WRDA
INC DPTR
DJNZ R3,LOOP1
RET
END
vlcd--32k电阻---+5v
data---portd6
cd-----portd7
wr-----portb0
共3条
