20mA 请教:4~20mA电流环芯片有哪些?多谢。
答 1:
还有价格怎样。多谢
答 2:
AD421,XTR101等,比较贵
答 3:
TI:Sensors, Sensor Conditioning, 4-20mA Transmitters
http://blog.21ic.com/more.asp?name=iC921&id=15812
注:表中*仅仅为表格显示好看而加上去的。
Sensors, Sensor Conditioning, 4-20mA Transmitters 答 4: 可不可以自己用运放作个4~20mA电路呢? 答 5: 可以用运放做
Part Number | Status | Sub Family | Vs (min) (V) | Vs (max) (V) | Pin/Package | Approx. 1KU Price (US$) | Description | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
RCV420 | ACTIVE | 4-20mA Transmitters | 11.4 | 36 | 16PDIP | 3.55 | Precision 4mA to 20mA Current Loop Receiver | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
XTR101 | ACTIVE | 4-20mA Transmitters | 11.6 | 40 | 14CDIP SB 14PDIP 16SOIC | 8.70 | Precision, Low Drift 4-20mA Two-Wire Transmitter | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
XTR105 | ACTIVE | 4-20mA Transmitters | 7.5 | 36 | 14PDIP 14SOIC | 4.00 | 4-20mA Current Transmitter with Sensor Excitation and Linearization | [TR]XTR106 | ACTIVE | 4-20mA Transmitters | 7.5 | 36 | 14PDIP 14SOIC | 4.00 | 4-20mA Current Transmitter with Bridge Excitation And Linearization | [TR]XTR108 | ACTIVE | 4-20mA Transmitters | 4.5 | * | 24SSOP/QSOP | 3.35 | 4-20mA, Two-Wire Transmitter 'Smart' Programmable with Signal Conditioning | [TR]XTR110 | ACTIVE | 4-20mA Transmitters | 13.5 | 40 | 16CDIP SB 16PDIP 16SOIC | 7.10 | Precision Voltage-To-Current Converter/Transmitter | [TR]XTR112 | ACTIVE | 4-20mA Transmitters | 7.5 | 36 | 14SOIC | 4.00 | 4-20mA Current Transmitters with Sensor Excitation and Linearization | [TR]XTR114 | ACTIVE | 4-20mA Transmitters | 7.5 | 36 | 14SOIC | 4.00 | 4-20mA Current Transmitters with Sensor Excitation and Linearization | [TR]XTR115 | ACTIVE | 4-20mA Transmitters | 7.5 | 36 | 8SOIC | 1.05 | 4-20mA Current Loop Transmitters | [TR]XTR116 | ACTIVE | 4-20mA Transmitters | 7.5 | 36 | 8SOIC | 1.05 | 4-20mA Current Loop Transmitters | XTR117 | NEW ACTIVE | 4-20mA Transmitters | 7.5 | 40 | 8MSOP 8SON | 0.90 | XTR117 4-20mA Current Loop Transmitter | [TR]XTR300 | NEW ACTIVE | 4-20mA Transmitters | 10 | 40 | 20QFN | 2.45 | Industrial Analog Current/Voltage Output Driver | [TR]TMP100 | ACTIVE | Temperature Sensors | * | * | 6SOT-23 | 0.75 | Digital Temperature Sensor with I2C Serial Interface | [TR]TMP101 | ACTIVE | Temperature Sensors | * | * | 6SOT-23 | 0.80 | Digital Temperature Sensor with I2C Serial Interface, Prog. Thermostat/AlARM Function | [TR]TMP105 | NEW ACTIVE | Temperature Sensors | * | * | 6DSBGA | 0.85 | Digital Temperature Sensor with 2-Wire Interface | [TR]TMP106 | NEW ACTIVE | Temperature Sensors | * | * | 6DSBGA | 0.85 | Digital Temperature Sensor with Two-Wire Interface in Chip Scale Package | [TR]TMP121 | ACTIVE | Temperature Sensors | * | * | 6SOT-23 | 0.90 | 1.5C Accurate Digital Temperature Sensor with SPI Interface | [TR]TMP122 | ACTIVE | Temperature Sensors | * | * | 6SOT-23 | 0.99 | 1.5C Accurate Programmable Temperature Sensor with SPI Interface | [TR]TMP123 | ACTIVE | Temperature Sensors | * | * | 6SOT-23 | 0.90 | 1.5C Accurate Digital Temperature Sensor with SPI Interface | [TR]TMP124 | ACTIVE | Temperature Sensors | * | * | 8SOIC | 0.70 | 1.5?C Accurate Programmable Digital Temp Sensor with SPI? Interface | [TR]TMP125 | ACTIVE | Temperature Sensors | * | * | 6SOT-23 | 0.80 | TMP125: 2 Degree Celsius Accurate Digital Temperature Sensor with SPI (TM) Interface | [TR]TMP141 | ACTIVE | Temperature Sensors | * | * | 6SOT-23 8MSOP | 0.65 | Digital Out Temperature Sensor | [TR]TMP175 | ACTIVE | Temperature Sensors | * | * | 8SOIC | 0.85 | Digital Temperature Sensor with 2-Wire Interface | [TR]TMP75 | ACTIVE | Temperature Sensors | * | * | 8MSOP 8SOIC | 0.70 | Digital Temperature Sensor with 2-Wire Interface | [TR]PGA309 | ACTIVE | Sensor Conditioning | 2.7 | 5 | 16TSSOP | 2.95 | PGA309 Voltage Output Programmable Sensor Conditioner | [TR]XTR108 | ACTIVE | Sensor Conditioning | 4.5 | * | 24SSOP/QSOP | 3.35 | 4-20mA, Two-Wire Transmitter 'Smart' Programmable with Signal Conditioning | [TR]UAF42 | ACTIVE | Active Filters | * | * | 14PDIP 16SOIC | 7.55 | Universal |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
