150MHz 请各位大哥帮我推荐种低噪管(150MHz,噪声低点的)!!
本人在做一个150M低噪放,请大家帮个忙。谢谢了!!
答 1:
9014怎样?
答 2:
c2856Gain bandwidth product fT — 310 — — 310 — MHz VCE = 6 V, IC = 10 mA
Collector output
capacitance
Cob — 3 — — 3 — pF VCB = 10 V, IE = 0,
f = 1 MHz
Noise figure NF — 0.15 1.5 — 0.15 1.5 dB VCE = 6 V, IC = 0.1 mA,
Rg = 10 kW, f = 1 kHz
— 0.2 2.0 — 0.2 2.0 dB VCE = 6 V, IC = 0.1 mA,
Rg = 10 kW, f = 10 Hz
Noise voltage referred to
input
en — 0.7 — — 0.7 — nV/ÖHz VCE = 6 V, IC = 10 mA,
Rg = 0, f = 1 kHz
Collector output
capacitance
f = 1 MHz
input
Rg = 0, f = 1 kHz
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
