mac,flash,sdram 帮忙推荐一个集成mac,可外挂flash和sdram的芯片吧?
答 1:
AT91RM9200
答 2:
这个好像是ARM9的,有没有ARM7的呢?不过还是谢谢这位兄弟了
答 3:
ARM7太少了,4510有,但是停产了,ARM7太少了,4510有,但是停产了,
还是用9200吧,比较好用,而且,价格也便宜。
答 4: 用华邦的W90N740
W90N740 is a 32-bit ARM7TDMI-based MCU. It is a high performance/cost ratio networking oriented microcontroller. W90N740 targets at managed Ethernet switch, management board of data communications and telecommunications system, printer server, and other applications which need a high performance and low cost ommunication processor 答 5: 说句实话,不敢用。不知道什么时候停产!
答 4: 用华邦的W90N740
