lpc2131,iap lpc2131 iap例程编译出错
4.13.6-IAP-在应用编程中的例程连接出现如下错误:
testiap.axf: Error: L6241E: startup.o(vectors) CANnot use the address of '~IW' function ResetInit as the image contains 'IW' functions.
testiap.axf: Error: L6241E: startup.o(vectors) CANnot use the address of '~IW' function Undefined as the image contains 'IW' functions.
testiap.axf: Error: L6241E: startup.o(vectors) CANnot use the address of '~IW' function SoftwareInterrupt as the image contains 'IW' functions.
testiap.axf: Error: L6241E: startup.o(vectors) CANnot use the address of '~IW' function PrefetchAbort as the image contains 'IW' functions.
testiap.axf: Error: L6241E: startup.o(vectors) CANnot use the address of '~IW' function DataAbort as the image contains 'IW' functions.
testiap.axf: Error: L6241E: startup.o(vectors) CANnot use the address of '~IW' function FIQ_Handler as the image contains 'IW' functions. 答 1: re:请直接将光盘上的IAP_test工程目录复制到D:\下,再打开编译调试(使用ADS1.2软件编译).
答 2: 问题解决了
答 2: 问题解决了
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
