电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » lpc2131,iap lpc2131 iap例程编译出错
2006-09-17 18:14:16     打赏
关键词: lpc2131     例程     编译     出错
2006-12-22 22:43:00     打赏
问 4.13.6-IAP-在应用编程中的例程连接出现如下错误:
testiap.axf: Error: L6241E: startup.o(vectors) CANnot use the address of '~IW' function ResetInit as the image contains 'IW' functions.
testiap.axf: Error: L6241E: startup.o(vectors) CANnot use the address of '~IW' function Undefined as the image contains 'IW' functions.
testiap.axf: Error: L6241E: startup.o(vectors) CANnot use the address of '~IW' function SoftwareInterrupt as the image contains 'IW' functions.
testiap.axf: Error: L6241E: startup.o(vectors) CANnot use the address of '~IW' function PrefetchAbort as the image contains 'IW' functions.
testiap.axf: Error: L6241E: startup.o(vectors) CANnot use the address of '~IW' function DataAbort as the image contains 'IW' functions.
testiap.axf: Error: L6241E: startup.o(vectors) CANnot use the address of '~IW' function FIQ_Handler as the image contains 'IW' functions. 答 1: re:请直接将光盘上的IAP_test工程目录复制到D:\下,再打开编译调试(使用ADS1.2软件编译).
答 2: 问题解决了
