easyarm,d12 我想在easyarm上用d12
我想在easyARM上用d12,你们提供的都是ucos上的代码,请问有没有不带操作系统的程序
答 1:
我自己改了一个D12Driver.c
#include "config.h"
#include "D12Config.h"
#include "D12CI.h"
#include "D12HAL.h"
#include "Chap_9.h"
#include "D12Driver.h"
#include "uart0.h"
extern EPPFLAGS bEPPflags;
unsigned char ssss[1024];
volatile unsigned char USB_setup_flag;
volatile unsigned char ep1_rx_ok;
unsigned char ep1_rx_buf[16];
volatile unsigned char ep1_tx_ok;
volatile unsigned char ep1_tx_max;
volatile unsigned char ep1_tx_cnt;
unsigned char *ep1_tx_buf;
volatile unsigned char ep2_rx_ok;
volatile unsigned short ep2_rx_max;
volatile unsigned short ep2_rx_cnt;
unsigned char ep2_rx_buf[1024];
volatile unsigned char ep2_tx_ok;
volatile unsigned short ep2_tx_max;
volatile unsigned short ep2_tx_cnt;
unsigned char *ep2_tx_buf;
void ep1_rxdone(void);
void ep1_txdone(void);
void ep2_rxdone(void);
void ep2_txdone(void);
unsigned char USB_write_port1(unsigned short len, unsigned char *buf)
unsigned char length;
ep1_tx_ok = 1;
D12_ClearBuff(3);
ep1_tx_buf = buf;
ep1_tx_max = len;
ep1_tx_cnt = 0;
length = ep1_tx_max - ep1_tx_cnt;
if (length > 0)
if (length >= 16)
length = D12_WriteEndpoint(3, 16, buf + ep1_tx_cnt);
else
length = D12_WriteEndpoint(3, length, buf + ep1_tx_cnt);
ep1_tx_cnt = ep1_tx_cnt + length;
ep1_tx_ok = 0;
return 0;
unsigned char USB_write_port2(unsigned short len, unsigned char *buf)
unsigned char i;
unsigned short length;
ep2_tx_ok = 1;
D12_ClearBuff(5);
ep2_tx_buf = buf;
ep2_tx_max = len;
ep2_tx_cnt = 0;
for (i= 0; i<2; i++)
length = ep2_tx_max - ep2_tx_cnt;
if (length > 0)
if (length >= 64)
length = D12_WriteEndpoint(5, 64, buf + ep2_tx_cnt);
else
length = D12_WriteEndpoint(5, (unsigned char)length, buf + ep2_tx_cnt);
ep2_tx_cnt = ep2_tx_cnt + length;
ep2_tx_ok = 0;
return 0;
unsigned char Init_D12(void)
unsigned short i;
Init_D12Port(); //初始化PDIUSBD12与LPC2200的连接的硬件配置
Rst_D12(); //复位PDIUSBD12
reconnect_USB(); //重新连接USB
if (readchipid() != 0x1012){ //读取芯片ID号,如果不为 1012H
return 1; //则复位失败
bEPPflags.value = 0; //初始化USB事件标志变量
USB_setup_flag = 0;
for (i=0; i<1024; i++)
ssss[i] = (unsigned char)i;
ep1_rx_ok = 0;
ep1_tx_ok = 1;
ep1_tx_cnt = 0;
ep1_tx_max = 0;
ep2_rx_ok = 0;
ep2_rx_cnt = 0;
ep2_rx_max = 1024;
ep2_tx_ok = 1;
ep2_tx_cnt = 0;
ep2_tx_max = 0;
return 0;
void bus_reset(void)
void dma_eot(void)
void USB_suspend(void)
void __irq USB_irq(void)
unsigned short i_st;
i_st = D12_ReadInterruptRegister(); //读取PDIUSBD12中断寄存器值
if(i_st != 0) {
if(i_st & D12_INT_BUSRESET)
bus_reset(); //总线复位处理
if(i_st & D12_INT_EOT)
dma_eot(); //DMA传输技术处理
if(i_st & D12_INT_SUSPENDCHANGE)
USB_suspend(); //总线挂起改变
if(i_st & D12_INT_ENDP0IN)
ep0_txdone(); //控制端点发送数据处理
if(i_st & D12_INT_ENDP0OUT)
ep0_rxdone(); //控制端点接收数据处理
if(i_st & D12_INT_ENDP1IN)
ep1_txdone(); //端点 1发送数据处理
if(i_st & D12_INT_ENDP1OUT)
ep1_rxdone(); //端点 1接收数据处理
if(i_st & D12_INT_ENDP2IN)
ep2_txdone(); //端点 2发送数据处理
if(i_st & D12_INT_ENDP2OUT)
ep2_rxdone(); //端点 2接收数据处理
CLR_INTD12(); //清除PDIUSBD12的中断标志
CLR_INT(); //通知中断结束
void USB_task(void)
unsigned char ack = 0x01;
unsigned short i;
if (USB_setup_flag == 1)
USB_setup_flag = 0;
control_handler();
if (ep1_rx_ok == 1)
for (i=0; i<8; i++)
uart0_putchar(ep1_rx_buf[i]);
D12_ClearBuff(4);
ep2_rx_cnt = 0;
USB_write_port1(1, &ack);
ep1_rx_ok = 0;
if (ep2_rx_ok == 1)
//for (i=0; i<1024; i++)
// uart0_putchar(ep2_rx_buf[i]);
ep2_rx_cnt = 0;
//D12_ClearBuff(4);
ep2_rx_max = 1024;
//USB_write_port2(1024, ep2_rx_buf);
ep2_rx_ok = 0;
unsigned char len;
D12_ReadLastTransactionStatus(2);
if (ep1_rx_ok == 0)
len = (unsigned char)D12_ReadEndpoint(2, 16, ep1_rx_buf);
if (len == 8)
ep1_rx_ok = 1;
else
D12_ClearBuff(2);
unsigned char i;
unsigned char endpstatus;
unsigned short len;
D12_ReadLastTransactionStatus(4);
if (ep2_rx_ok == 0)
for (i=0; i<2; i++)
len = ep2_rx_max - ep2_rx_cnt;
if (len > 0)
if (len >= 64)
len = (unsigned char)D12_ReadEndpoint(4, 64, ep2_rx_buf+ep2_rx_cnt);
else
len = (unsigned char)D12_ReadEndpoint(4, len, ep2_rx_buf+ep2_rx_cnt);
ep2_rx_cnt = ep2_rx_cnt + len;
if (ep2_rx_cnt >= ep2_rx_max)
ep2_rx_ok = 1;
break;
endpstatus = D12_ReadEndpointStatus(4);
if ((endpstatus & 0x60) == 0)
break;
else
D12_ClearBuff(4);
unsigned char len;
D12_ReadLastTransactionStatus(3);
if (ep1_tx_ok == 0)
if (ep1_tx_cnt >= ep1_tx_max)
endpstatus = D12_ReadEndpointStatus(3) & 0x60;
if (endpstatus == 0)
ep1_tx_ok = 1;
else
return;
else
return;
if (ep1_tx_ok == 0)
if (endpstatus == 0x60)
return;
len = ep1_tx_max - ep1_tx_cnt;
if (len > 0)
if (len >= 16)
len = D12_WriteEndpoint(3, 16, ep1_tx_buf + ep1_tx_cnt);
else
len = D12_WriteEndpoint(3, len, ep1_tx_buf + ep1_tx_cnt);
ep1_tx_cnt = ep1_tx_cnt + len;
unsigned short len;
unsigned char i,endpstatus;
D12_ReadLastTransactionStatus(5);
if (ep2_tx_ok == 0)
if (ep2_tx_cnt >= ep2_tx_max)
endpstatus = D12_ReadEndpointStatus(5) & 0x60;
ep2_tx_ok = 1;
else
return;
else
return;
if (ep2_tx_ok == 0)
for (i=0; i<2; i++)
break;
len = ep2_tx_max - ep2_tx_cnt;
if (len > 0)
if (len >= 64)
len = D12_WriteEndpoint(5, 64, ep2_tx_buf + ep2_tx_cnt);
else
len = D12_WriteEndpoint(5, len, ep2_tx_buf + ep2_tx_cnt);
ep2_tx_cnt = ep2_tx_cnt + len;
void Init_D12Int(void)
VICVectCntl1 = (0x20 | 0x0E); //EINT0通道分配到IRQ slot 1
VICVectAddr1 = (unsigned long)USB_irq; //设置EINT0向量地址
VICIntEnable = 1 << 14; //允许EINT0
#include "config.h"
#include "D12CI.h"
#include "D12HAL.h"
#include "Chap_9.h"
#include "uart0.h"
ep1_tx_ok = 1;
D12_ClearBuff(3);
ep1_tx_buf = buf;
ep1_tx_max = len;
ep1_tx_cnt = 0;
if (length > 0)
if (length >= 16)
else
ep1_tx_ok = 0;
return 0;
unsigned char i;
ep2_tx_ok = 1;
D12_ClearBuff(5);
ep2_tx_buf = buf;
ep2_tx_max = len;
ep2_tx_cnt = 0;
if (length > 0)
if (length >= 64)
else
ep2_tx_ok = 0;
return 0;
unsigned short i;
return 1; //则复位失败
USB_setup_flag = 0;
ep1_rx_ok = 0;
ep1_tx_ok = 1;
ep1_tx_cnt = 0;
ep1_tx_max = 0;
ep2_rx_ok = 0;
ep2_rx_cnt = 0;
ep2_rx_max = 1024;
ep2_tx_ok = 1;
ep2_tx_cnt = 0;
ep2_tx_max = 0;
return 0;
void dma_eot(void)
if(i_st != 0) {
CLR_INT(); //通知中断结束
void USB_task(void)
unsigned short i;
USB_setup_flag = 0;
control_handler();
if (ep1_rx_ok == 1)
for (i=0; i<8; i++)
D12_ClearBuff(4);
ep2_rx_cnt = 0;
ep1_rx_ok = 0;
if (ep2_rx_ok == 1)
ep2_rx_cnt = 0;
//D12_ClearBuff(4);
ep2_rx_max = 1024;
ep2_rx_ok = 0;
unsigned char len;
if (ep1_rx_ok == 0)
if (len == 8)
ep1_rx_ok = 1;
else
D12_ClearBuff(2);
unsigned char i;
unsigned short len;
if (ep2_rx_ok == 0)
for (i=0; i<2; i++)
if (len > 0)
if (len >= 64)
else
ep2_rx_ok = 1;
break;
break;
else
D12_ClearBuff(4);
unsigned char len;
if (ep1_tx_ok == 0)
ep1_tx_ok = 1;
else
return;
else
return;
if (ep1_tx_ok == 0)
return;
if (len > 0)
if (len >= 16)
else
unsigned short len;
if (ep2_tx_ok == 0)
ep2_tx_ok = 1;
else
return;
else
return;
if (ep2_tx_ok == 0)
for (i=0; i<2; i++)
break;
if (len > 0)
if (len >= 64)
else
| 为遥控小车巧添功能被打赏¥26元 | |
