F149,UART 求救各位高手!F149 UART 发送的难题?
我在发送时要在每个字符之间加很多延时才能发送正确,而且我加了
while((UTCTL0&TXEPT)==0);然后TXBUF0= c; 也没用,请问哪位高手能否指点一下,怎样处理好???我不想用 加很多延时的方法。
void uart_init(void)
unsigned int i;
//Baud rate 4800,8,1 ,外部晶振7372800hz
DCOCTL = 0xe0;
BCSCTL1 = 0x07;// open XT2, LFTX1 low freq = ACLK 分频是1
BCSCTL2 = 0x08;// MCLK 为DCOCLK, 分频是1,SMCLK 为XT2, 分频是1
do
IFG1 &= ~OFIFG; // Clear OSCFault flag
for (i = 0xFF; i > 0; i--); // Time for flag to set
while ((IFG1 & OFIFG) == OFIFG);
UCTL0 = CHAR; // 8-bit character
UTCTL0 = SSEL1;//+TXEPT; // UCLK = SMCLK = TX2 = 7.3728 Mhz
UBR00 = 0x00; //03 // 7372800hz/4800 - 1536(0x600)
UBR10 = 0x06;
UMCTL0 = 0x00; //4a // modulation
ME1 |= UTXE0 + URXE0; // Enable USART0 TXD/RXD
IE1 |= URXIE0 + UTXIE0; // Enable USART0 RX/TX interrupt
} 答 1: 引用: 答 2: 我是这样使用的:
interrupt[UART0TX_VECTOR] void usart0_tx (void)
{//user
bTxEnd = 1;
void putChar(unsigned char ch)
while (!(bTxEnd))
bTxEnd = 0;
TXBUF0 = ch;
void main(void)
uart_init();
发送数据包
请问大家有何高见???
unsigned int i;
DCOCTL = 0xe0;
do
UBR10 = 0x06;
{//user
bTxEnd = 1;
while (!(bTxEnd))
bTxEnd = 0;
TXBUF0 = ch;
void main(void)
uart_init();
发送数据包
请问大家有何高见???
