iar,for,430,workbench 请问各位大侠在iar for 430 workbench 3.0 中出现如下错误是为什么??谢谢
Building configuration: new - Debug
vps2.c
icc430.exe -I C:\Program Files\IAR Systems\Embedded Workbench 3.2\430\INC\ -I C:\Program Files\IAR Systems\Embedded Workbench 3.2\430\INC\CLIB\ -o D:\
project\program\Debug\Obj\ -z2 --no_cse --no_unroll --no_inline --no_code_motion --debug -e --double=32 D:\project\program\vps2.c
IAR MSP430 C Compiler V2.10A/W32
Copyright 1996-2003 IAR Systems. All rights reserved.
Warning[Pe001]: last line of file ends without a newline
2 106 bytes of CODE memory
377 bytes of DATA memory (+ 40 bytes shared)
Errors: none
Warnings: 1
Linking
xlink.exe D:\project\program\Debug\Obj\vps2.r43 -o D:\project\program\Debug\Exe\new.d43 -rt -IC:\Program Files\IAR Systems\Embedded Workbench 3.2\430\LIB\ -f
C:\Program Files\IAR Systems\Embedded Workbench 3.2\430\config\lnk430C111.xcl C:\Program Files\IAR Systems\Embedded Workbench 3.2\430\lib\cl430f.r43
-e_small_write=_formatted_write -e_medium_read=_formatted_read -f C:\Program Files\IAR Systems\Embedded Workbench 3.2\430\config\compactmath.xcl
IAR Universal Linker V4.55H/386
Copyright 1987-2003 IAR Systems. All rights reserved.
Error[e16]: Segment DATA16_Z (size: 0x160 align: 0x1) is too long for segment definition. At least 0xdf more bytes needed. The problem occurred while processing the
segment placement command "-Z(DATA)DATA16_I,DATA16_Z,DATA16_N,HEAP+_HEAP_SIZE=0200-0280", where at the moment of placement the available memory
ranges were "CODE:200-280"
Total number of errors: 1
Total number of warnings: 1
vps2.c
Errors: none
Warnings: 1
Linking
