CAN CAN 总线应用有点问题,请大虾指教 ...
CAN 总线应用有点问题,请大虾指教
问题:我每次中断接收数据以后,总是要再次初始化CAN后才能再接收。查了很久都查不出原因....... CAN:SJA1000 我的初始化程序:
void initialize_for_CAN() /**/
uchar pdata *pointer;
uchar j,i;
CAN_enable=0;
do
pointer=0;
*pointer=1;
i=0;
i=0;
j=*pointer;
j=j&0x01;
} while(j!=1);
pointer=0x04;
*pointer=0xe7;
pointer=0x05;
*pointer=0xff;
pointer=0x06;
*pointer=0x53; //43
pointer=0x07;
*pointer=0x2f; //2F
pointer=0x08;
*pointer=0xda; //DA
pointer=31;
*pointer=0x27;
do
pointer=0;
*pointer=0x02;
i=0;
i=0;
j=*pointer;
j=j&0x01;
} while(j!=0);
pointer=2;
j=*pointer;
CAN_enable=1;
答 1: 诶,查来查去 都没发现什么............... 答 2: 接收后要释放接收缓冲区 有一位的,去下一个看看 答 3: 我已释放过我已释放过,可还不行,
系统已一秒的频率发数据(一贞)给 CAN,原者上CAN差不多1S收满 后给控制器中断
,可就要十几秒后才发生中断, 如果CAN收到后,再初始化 就行了, 请指点啊... 答 4: 诶自己顶一下 答 5: mei 没办法查不出
uchar j,i;
CAN_enable=0;
do
pointer=0;
*pointer=1;
i=0;
i=0;
j=*pointer;
j=j&0x01;
} while(j!=1);
pointer=0x04;
*pointer=0xe7;
pointer=0x05;
*pointer=0xff;
pointer=0x06;
*pointer=0x53; //43
pointer=0x07;
*pointer=0x2f; //2F
pointer=0x08;
*pointer=0xda; //DA
pointer=31;
*pointer=0x27;
do
pointer=0;
*pointer=0x02;
i=0;
i=0;
j=*pointer;
j=j&0x01;
} while(j!=0);
pointer=2;
j=*pointer;
CAN_enable=1;
| 为遥控小车巧添功能被打赏¥26元 | |
