HELLO.C
Copyright 1995-1999 Keil Software, Inc.
#include <REG52.H> /* special function register declarations */
/* for the intended 8051 derivative */
#include <stdio.h> /* prototype declarations for I/O functions */
#ifdef MONITOR51 /* Debugging with Monitor-51 needs */
char code reserve [3] _at_ 0x23; /* space for serial interrupt if */
#endif /* Stop Exection with Serial Intr. */
/* is enabled */
The main C function. Program execution starts
here after stack initialization.
void main (void) {
Setup the serial port for 1200 baud at 16MHz.
#ifndef MONITOR51
SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */
TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */
TH1 = 221; /* TH1: reload value for 1200 baud @ 16MHz */
TR1 = 1; /* TR1: timer 1 run */
TI = 1; /* TI: set TI to send first char of UART */
#endif
Note that an embedded program never exits (because
there is no operating system to return to). It
must loop and execute forever.
while (1) {
P1 ^= 0x01; /* Toggle P1.0 each time we print */
printf ("Hello World\n"); /* Print "Hello World" */
char code reserve [3] _at_ 0x23;中的-at-是什么意思?为什么monitor51需要空间? 答 1: reserve数组定位在0x23地址而0x23正好是定时器串行口中断入口地址。
不过这个code怎么没赋值呢,调试用这个是干什么用的?
HELLO.C
/* is enabled */
void main (void) {
#ifndef MONITOR51
#endif
while (1) {
