电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » Quartus II 7.2的重大改进
Quartus II 7.2的重大改进
2007-12-16 13:30:48     打赏
Quartus II 7.2的重大改进
4个方面改进最大:
n        State Machine Diagram Entry
-         Two Methods for Entry
l        Graphical Entry, user enters the state-machine using bubble diagram
l        Text based Entry, user enters the state-machine using a Wizard
l        Auto generation of HDLs (Verilog and VHDL)
FFT IP:
n        32-bit floating point support for Radix 2 variable streaming cores。
终于支持MMU了,但是Altera没有说明是否支持Vxworks:
Nios II & EDS
Embedded Systems
n          MMU support
-          Hidden from general use, OS required
-          Release is for OS port start
n          Improved protection features for illegal operations
-          Hidden from general use, requires tech specialist engagement.
-          Primary customers Huawei and Motorola
n        Stratix II, HardCopy II
-         Military temperature grade support
-         Military ordering codes for HardCopy II
关键词: Quartus     重大     改进
2007-12-16 22:47:05     打赏
用过7.1发现比6.0方便许多,很期待7.2
