附件图中,如何消除latch_signal的竞争冒险(不可引入新的时钟或其它信号,还有将clk_base两次not的方法我也试过了,没有效果)
我的程序如下
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY counting_controller IS
PORT(clk_base:IN STD_LOGIC;
latch_signal,gate_signal,cleared_signal:OUT STD_LOGIC);
END counting_controller;
ARCHITECTURE countingcontroller OF counting_controller IS
SIGNAL latchsignal,gatesignal,clearedsignal:STD_LOGIC;
BEGIN
latch_signal<=latchsignal;
gate_signal<=gatesignal;
cleared_signal<=clearedsignal;
latchsignal<=clk_base and (NOT gatesignal);
clearedsignal<=(NOT clk_base) AND (not latchsignal) AND (not gatesignal);
clkbase<=NOT (not clk_base);
process(clk_base)
BEGIN
IF(clk_base'EVENT AND clk_base='1')THEN
gatesignal<=NOT gatesignal;
END IF;
END process;
END countingcontroller;
