接这位楼主的提问,看了许多大虾们的解答,想提问一下,考虑到a的高电平会持续一段时间。如果要求非要在a的上升沿将count清零,如何实现呢?谢谢各位的支持!!!
两个always模块的变量赋值问题
引入一个锁存器Lock,用来区分a的上升沿和高电平。
always @(posedge a or posedge b)
begin
if ( a==1 && Lock==0 )
begin
count <= 0;
Lock <= 1;
end
else
begin
count <= count + 1;
if ( a==0 )
Lock <= 0;
end
end
一般对于寄存器,复位是需要的,所以我这里省略了。
或者可以拆成两个写。这里采用同步复位
begin
if(rst==0)
begin
count <= 0;
end
else
begin
begin
count <= 0;
end
else
begin
count <= count + 1;
end
end
end
begin
if(rst==0)
begin
count <= 0;
end
else
begin
begin
Lock <= 1;
end
else
begin
if ( a==0 )
Lock <= 0;
end
end
end
好的。下面是我的程序,红色部分是增加的东西,增加了后就通过不了综合了。综合的问题是在第二个always上面涂红,问题是the logic for gpshighclkcnt [15:0] does not match a standard flip-flop.
module fuzhugen(gps,
gpshighclk,
rst,
fuzhu,
fuzhu1);
input gps;
input gpshighclk;
input rst;
output fuzhu; //增加一个fuzhu输出端口信号
output fuzhu1; //增加一个fuzhu1输出端口信号
reg fuzhu;
reg fuzhu1;
reg lockgpshigh;
reg [15:0] gpshighclkcnt;
always @ (posedge gps or posedge gpshighclk)
begin
if(rst)
begin
gpshighclkcnt<=16'd0;
fuzhu1<=(1==0);
fuzhu<=(0==1);
end
else
begin
if(gps && !lockgpshigh)
begin
fuzhu<=(0==1);
fuzhu1<=(0==1);
end //gps信号上升沿时候,计数器清零,fuzhu和fuzhu1输出port清零
if(gps && gpshighclkcnt==16'd239)
begin
fuzhu <=(1==1);
end //当gps信号为高时并且计数器计数到239的时候fuzhu信号输出高电平
if(gps && gpshighclkcnt==16'd240)
begin
fuzhu1<=(1==1);
end //当gps信号为高时并且计数器计数到240的时候fuzhu1信号输出高电平
else
begin
gpshighclkcnt<=gpshighclkcnt+16'd1;
end
end
end
begin
if(rst)
begin
end
else
begin
begin
lockgpshigh<=(1==1);
end
else
begin
if(!gps)
begin
lockgpshigh<=(1==0);
end
end
end
end
endmodule
