开始写LED代码——静态
在这里开始出现2个警告。
总警告表里面内容如下,请教各位是如何解决的?
Warning: Output pins are stuck at VCC or GND
Warning (13410): Pin "led[0]" is stuck at GND
Warning (13410): Pin "led[1]" is stuck at VCC
Warning (13410): Pin "led[2]" is stuck at GND
Warning (13410): Pin "led[3]" is stuck at VCC
Warning (13410): Pin "led[4]" is stuck at GND
Warning (13410): Pin "led[5]" is stuck at VCC
Warning (13410): Pin "led[6]" is stuck at GND
Warning (13410): Pin "led[7]" is stuck at VCC
Warning: Found 8 output pins without output pin load capacitance assignment
Info: Pin "led[0]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
Info: Pin "led[1]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
Info: Pin "led[2]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
Info: Pin "led[3]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
Info: Pin "led[4]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
Info: Pin "led[5]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
Info: Pin "led[6]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
Info: Pin "led[7]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
Warning: Following 8 pins have nothing, GND, or VCC driving datain port -- changes to this connectivity may change fitting results
Info: Pin led[0] has GND driving its datain port
Info: Pin led[1] has VCC driving its datain port
Info: Pin led[2] has GND driving its datain port
Info: Pin led[3] has VCC driving its datain port
Info: Pin led[4] has GND driving its datain port
Info: Pin led[5] has VCC driving its datain port
Info: Pin led[6] has GND driving its datain port
Info: Pin led[7] has VCC driving its datain port
Warning: No paths found for timing analysis
