别人的源码:
module my_led(rst_n,clk,keyin,ledout);
input rst_n;
input clk;
input[3:0] keyin;
output[3:0] ledout;
reg[19:0] cnt;
always @(posedge clk or negedge rst_n)
begin
if (!rst_n)
cnt <= 20'd0;//
else
cnt <= cnt + 1'b1;
end
wire sample_pulse = cnt == 20'hF4240;
wire led0_out;
key0 U1
.en(sample_pulse),
.rst_n(rst_n),
.clk(clk),
.key(keyin[0]),
.ledout(led0_out)
);//一个API的调用写了多行
wire led1_out;
key1 U2
.en(sample_pulse),
.rst_n(rst_n),
.clk(clk),
.key(keyin[1]),
.ledout(led1_out)
wire led2_out;
key2 U3
.en(sample_pulse),
.rst_n(rst_n),
.clk(clk),
.key(keyin[2]),
.ledout(led2_out)
wire led3_out;
key3 U4
.en(sample_pulse),
.rst_n(rst_n),
.clk(clk),
.key(keyin[3]),
.ledout(led3_out)
assign ledout = {led3_out,led2_out,led1_out,led0_out};//ledout 是输出的数组变量
endmodule
//-----------------------key0-----------------------
module key0(en,rst_n,clk,key,ledout);
input clk;
input rst_n;
input en;
input key;
output ledout;
reg low_sw;
begin
if (!rst_n)
low_sw <= 1'b1;
else if(en)
low_sw <= key;
end
reg low_sw_r;
always @(posedge clk )//上升沿
low_sw_r <= low_sw;
wire led_ctrl = low_sw_r & (!low_sw);
reg ledout_r;
begin
if (!rst_n)
ledout_r <= 1'b0;
else if(led_ctrl)
ledout_r <= ~ledout_r;
end
assign ledout = ledout_r;
endmodule
//-----------------------key1-----------------------
module key1(en,rst_n,clk,key,ledout);
input clk;
input rst_n;
input en;
input key;
output ledout;
reg low_sw;
begin
if (!rst_n)
low_sw <= 1'b1;
else if(en)
low_sw <= key;
end
reg low_sw_r;
low_sw_r <= low_sw;
reg ledout_r;
begin
if (!rst_n)
ledout_r <= 1'b0;
else if(led_ctrl)
end
endmodule
//-----------------------key2-----------------------
module key2(en,rst_n,clk,key,ledout);
input clk;
input rst_n;
input en;
input key;
output ledout;
reg low_sw;
begin
if (!rst_n)
low_sw <= 1'b1;
else if(en)
low_sw <= key;
end
reg low_sw_r;
low_sw_r <= low_sw;
reg ledout_r;
begin
if (!rst_n)
ledout_r <= 1'b0;
else if(led_ctrl)
end
endmodule
//-----------------------key3-----------------------
module key3(en,rst_n,clk,key,ledout);
input clk;
input rst_n;
input en;
input key;
output ledout;
reg low_sw;
begin
if (!rst_n)
low_sw <= 1'b1;
else if(en)
low_sw <= key;
end
reg low_sw_r;
low_sw_r <= low_sw;
reg ledout_r;
begin
if (!rst_n)
ledout_r <= 1'b0;
else if(led_ctrl)
end
endmodule
我的引脚配置:
clk Input PIN_129 3 B3_N1 3.3-V LVTTL (default) 24mA (default)
keyin[3] Input PIN_113 3 B3_N1 3.3-V LVTTL (default) 24mA (default)
keyin[2] Input PIN_114 3 B3_N1 3.3-V LVTTL (default) 24mA (default)
keyin[1] Input PIN_110 3 B3_N1 3.3-V LVTTL (default) 24mA (default)
keyin[0] Input PIN_112 3 B3_N1 3.3-V LVTTL (default) 24mA (default)
ledout[3] Output PIN_133 3 B3_N0 3.3-V LVTTL (default) 24mA (default)
ledout[2] Output PIN_134 3 B3_N0 3.3-V LVTTL (default) 24mA (default)
ledout[1] Output PIN_127 3 B3_N1 3.3-V LVTTL (default) 24mA (default)
ledout[0] Output PIN_128 3 B3_N1 3.3-V LVTTL (default) 24mA (default)
rst_n Input PIN_30 1 B1_N1 3.3-V LVTTL (default) 24mA (default)
<<new node>>
别人的编译好的东西运行在他的板子是好的(有视频),我把他的sof现在到我的板子上也是不行。我自己编译的也是不行。key不能控制相关led(参考别人代码)
相关作者的帖子
http://forum.eepw.com.cn/forum/main?url=http%3A%2F%2Fforum.eepw.com.cn%2Fforum%2F275%2F1
