电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » key不能控制相关led(参考别人代码)
共3条 1/1 1 跳转至页
2012-10-23 10:15:40     打赏
别人的源码:
module my_led(rst_n,clk,keyin,ledout);
 input rst_n;
 input clk;
 input[3:0] keyin;
 output[3:0] ledout;
 reg[19:0] cnt;
 always @(posedge clk or negedge rst_n)
 begin
  if (!rst_n)
   cnt <= 20'd0;//
  else
   cnt <= cnt + 1'b1;
 end
 wire sample_pulse = cnt == 20'hF4240;
 wire led0_out;
 key0 U1
  .en(sample_pulse),
  .rst_n(rst_n),
  .clk(clk),
  .key(keyin[0]),
  .ledout(led0_out)
 );//一个API的调用写了多行
  wire led1_out;
 key1 U2
  .en(sample_pulse),
  .rst_n(rst_n),
  .clk(clk),
  .key(keyin[1]),
  .ledout(led1_out)
 wire led2_out;
 key2 U3
  .en(sample_pulse),
  .rst_n(rst_n),
  .clk(clk),
  .key(keyin[2]),
  .ledout(led2_out)
 wire led3_out;
 key3 U4
  .en(sample_pulse),
  .rst_n(rst_n),
  .clk(clk),
  .key(keyin[3]),
  .ledout(led3_out)
 assign ledout = {led3_out,led2_out,led1_out,led0_out};//ledout 是输出的数组变量
endmodule
//-----------------------key0-----------------------
module key0(en,rst_n,clk,key,ledout);
 input clk;
 input rst_n;
 input en;
 input key;
 output ledout;
 reg low_sw;
 begin
  if (!rst_n)
   low_sw <= 1'b1;
  else if(en)
   low_sw <= key;
 end
 reg low_sw_r;
 always @(posedge clk )//上升沿
  low_sw_r <= low_sw;
 wire led_ctrl = low_sw_r & (!low_sw);
 reg ledout_r;
 begin
  if (!rst_n)
   ledout_r <= 1'b0;
  else if(led_ctrl)
   ledout_r <= ~ledout_r;
 end
 assign ledout = ledout_r;
endmodule
//-----------------------key1-----------------------
module key1(en,rst_n,clk,key,ledout);
 input clk;
 input rst_n;
 input en;
 input key;
 output ledout;
 reg low_sw;
 begin
  if (!rst_n)
   low_sw <= 1'b1;
  else if(en)
   low_sw <= key;
 end
 reg low_sw_r;
  low_sw_r <= low_sw;
 reg ledout_r;
 begin
  if (!rst_n)
   ledout_r <= 1'b0;
  else if(led_ctrl)
 end
endmodule
//-----------------------key2-----------------------
module key2(en,rst_n,clk,key,ledout);
 input clk;
 input rst_n;
 input en;
 input key;
 output ledout;
 reg low_sw;
 begin
  if (!rst_n)
   low_sw <= 1'b1;
  else if(en)
   low_sw <= key;
 end
 reg low_sw_r;
  low_sw_r <= low_sw;
 reg ledout_r;
 begin
  if (!rst_n)
   ledout_r <= 1'b0;
  else if(led_ctrl)
 end
endmodule
//-----------------------key3-----------------------
module key3(en,rst_n,clk,key,ledout);
 input clk;
 input rst_n;
 input en;
 input key;
 output ledout;
 reg low_sw;
 begin
  if (!rst_n)
   low_sw <= 1'b1;
  else if(en)
   low_sw <= key;
 end
 reg low_sw_r;
  low_sw_r <= low_sw;
 reg ledout_r;
 begin
  if (!rst_n)
   ledout_r <= 1'b0;
  else if(led_ctrl)
 end
endmodule
我的引脚配置:
clk Input PIN_129 3 B3_N1 3.3-V LVTTL (default)  24mA (default)
keyin[3] Input PIN_113 3 B3_N1 3.3-V LVTTL (default)  24mA (default)
keyin[2] Input PIN_114 3 B3_N1 3.3-V LVTTL (default)  24mA (default)
keyin[1] Input PIN_110 3 B3_N1 3.3-V LVTTL (default)  24mA (default)
keyin[0] Input PIN_112 3 B3_N1 3.3-V LVTTL (default)  24mA (default)
ledout[3] Output PIN_133 3 B3_N0 3.3-V LVTTL (default)  24mA (default)
ledout[2] Output PIN_134 3 B3_N0 3.3-V LVTTL (default)  24mA (default)
ledout[1] Output PIN_127 3 B3_N1 3.3-V LVTTL (default)  24mA (default)
ledout[0] Output PIN_128 3 B3_N1 3.3-V LVTTL (default)  24mA (default)
rst_n Input PIN_30 1 B1_N1 3.3-V LVTTL (default)  24mA (default)
<<new node>>
别人的编译好的东西运行在他的板子是好的(有视频),我把他的sof现在到我的板子上也是不行。我自己编译的也是不行。key不能控制相关led(参考别人代码)
相关作者的帖子
http://forum.eepw.com.cn/forum/main?url=http%3A%2F%2Fforum.eepw.com.cn%2Fforum%2F275%2F1
关键词: 不能     控制     相关     参考     别人     代码     keyin     l
2012-10-23 15:03:19     打赏
好的 我试试。 先谢谢
2012-11-02 15:02:11     打赏
晶振没有起作用 。由Y2改为Y1位置就好了, 可能焊接有问题
共3条 1/1 1 跳转至页
