我在redhat 9.0上编译arm版本的apache时提示:输入make后提示的 不知道哪里出了错,谢谢啦~~ cd ../apache_1.3.39 make 出现以下错误信息: gcc -c -I../os/unix -I../include -DSOLARIS2=290 -DMOD_SSL=208114 -DEAPI `../apaci` util.c util.c: In function `ap_find_token': util.c:1410: error: `test_char_table' undeclared (first use in this function) util.c:1410: error: (Each undeclared identifier is reported only once util.c:1410: error: for each function it appears in.) util.c:1410: error: `T_HTTP_TOKEN_STOP' undeclared (first use in this function) util.c: In function `ap_escape_logitem': util.c:1487: error: `test_char_table' undeclared (first use in this function) util.c:1487: error: `T_ESCAPE_LOGITEM' undeclared (first use in this function) util.c: In function `ap_escape_shell_cmd': util.c:1547: error: `test_char_table' undeclared (first use in this function) util.c:1547: error: `T_ESCAPE_SHELL_CMD' undeclared (first use in this function) util.c: In function `ap_escape_path_segment': util.c:1651: error: `test_char_table' undeclared (first use in this function) util.c:1651: error: `T_ESCAPE_PATH_SEGMENT' undeclared (first use in this function) util.c: In function `ap_os_escape_path': util.c:1680: error: `test_char_table' undeclared (first use in this function) util.c:1680: error: `T_OS_ESCAPE_PATH' undeclared (first use in this function) make[3]: *** [util.o] Error 1 make[2]: *** [subdirs] Error 1 make[2]: Leaving directory `/httpd/tmp/apache_1.3.27/src' make[1]: *** [build-std] Error 2 make[1]: Leaving directory `/httpd/tmp/apache_1.3.27' make: *** [build] Error 2 |
共3条
Apache 的util.c编译错误
关键词: Apache util.c 编译 错误 funct
共3条
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
