电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 定时器10分钟
定时器10分钟
2014-11-26 20:23:01     打赏
#include<reg52.h>
#include<intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit dula=P2^0;
sbit wela=P2^1;
sbit beep=P3^2;
uint num,num1,num2;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delayus(uint us)
    while(us--);
void delay(uint z)
    uint a,b;
    for(a=0;a<z;z++)
        for(b=0;b<110;b++);
void display(uint disnum)
    uchar wan,qian,bai,shi,ge;
    wan=disnum/10000;
    qian=disnum%10000/1000;
    bai=disnum%1000/100;
    shi=disnum%100/10;
    ge=disnum%10;
    dula=1;
    P0=table[wan];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0xf7;
    wela=0;
    delayus(100);
    dula=1;
    P0=table[qian];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0xef;
    wela=0;
    delayus(100);
    dula=1;
    P0=table[bai];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0xdf;
    wela=0;
    delayus(100);
    dula=1;
    P0=table[shi];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0xbf;
    wela=0;
    delayus(100);
    dula=1;
    P0=table[ge];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0x7f;
    wela=0;
    delayus(100);
void main()
    TH0=(65536-46080)/256;
    TL0=(65536-46080)%256;
    TMOD=0x01;
    EA=1;
    ET0=1;
    TR0=1;
    while(1)
        if(num==20)
            num=0;
            num1++;
            num2++;
        if(num2==30)
            beep=0;
            delayus(2000);
            beep=1;
            num2=0;
        if(num1==600)
            num1=0;
        display(num1);
void T0_timer() interrupt 1
    num++;
