电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 急急急,protel99se出现在DRC错误怎么办,是什么原因,新手求教,
共31条 1/4 1 2 3 4 › 跳转至页
2014-12-15 16:48:10     打赏
这是我的第一块电路板,求高手指教啊。
 第二张图中间部分是在生成PCB文件之后画上的直接加了一个网络地GND会不会有问题?第三个图是Design>option里面的设置,这个橘色是是DRC错误自己改成这色了,哪里不合适的请大家指导啊,
这是DRC检测里面的一部分错误,这个要怎么修改啊
   Violation         Net P14_0   is broken into 4 sub-nets. Routed To 72.73%
     Subnet : S13-2    S13-2    S13-2
     Subnet : S14-2    S14-2    S14-2
     Subnet : S15-2    S15-2    S15-2
     Subnet : S16-2    S16-2    S16-2
   Violation         Net XT2OUT_0   is broken into 3 sub-nets. Routed To 0.00%
     Subnet : C3-2
     Subnet : U2-52
     Subnet : Y1-2
   Violation         Net XT2IN_0   is broken into 3 sub-nets. Routed To 0.00%
     Subnet : Y1-1
     Subnet : U2-53
     Subnet : C4-2
   Violation         Net XOUT_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : Y2-1
     Subnet : U2-9
   Violation         Net VREF+_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : C10-2
     Subnet : U2-7
   Violation         Net TMS_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U2-56
     Subnet : JP1-5
   Violation         Net TDO_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U2-54
     Subnet : JP1-1
   Violation         Net TDI_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U2-55
     Subnet : JP1-3
   Violation         Net TCK_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U2-57
     Subnet : JP1-7
   Violation         Net REST_0   is broken into 5 sub-nets. Routed To 0.00%
     Subnet : D1-1
     Subnet : C1-2
     Subnet : JP1-11
     Subnet : R3-1
     Subnet : U2-58
   Violation         Net P63_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : J1-4
     Subnet : U2-2
   Violation         Net P53_0   is broken into 3 sub-nets. Routed To 0.00%
     Subnet : R10-1
     Subnet : U2-47
     Subnet : U4-6
2014-12-15 17:02:21     打赏
在Design Rule 里修改一下焊盘最小间距的规则就可以通过DRC ,不过在投板的时候要和PCB 板制造注明最小间距看看工艺是否能达到
2014-12-15 17:08:44     打赏
嗯,我试试,但是我刚发现一个问题,在封装库里这个封装,紫色部分有重叠,是不是这个问题呢
2014-12-15 19:07:10     打赏
重叠式不行的,你可以把管脚画的细长,但是不能太粗
2014-12-16 08:50:38     打赏
嗯,明白了,
Protel Design System: Library Component Rule Check
PCB File : my430PCB
Date     : 16-Dec-2014
Time     : 08:49:02
Name                Warnings
SOT-223                  Duplicate Pad Name On Pads Pad Free-2(2.29997mm,0.00001mm)  TopLayer And Pad Free-2(2.29997mm,6mm)  TopLayer
SW-PB-001                Duplicate Pad Name On Pads Pad Free-1(-6.25mm,-3.8mm)  TopLayer And Pad Free-1(6.25mm,-3.8mm)  TopLayer
SW-PB-001                Duplicate Pad Name On Pads Pad Free-1(0mm,0mm)  TopLayer And Pad Free-1(6.25mm,-3.8mm)  TopLayer
SW-PB-001                Duplicate Pad Name On Pads Pad Free-2(0mm,-11.176mm)  TopLayer And Pad Free-2(-3.048mm,-7.4mm)  TopLayer
SW-PB-001                Duplicate Pad Name On Pads Pad Free-2(3.1mm,-7.4mm)  TopLayer And Pad Free-2(-3.048mm,-7.4mm)  TopLayer
SW-PB-001                Duplicate Pad Name On Pads Pad Free-1(0mm,-3.8mm)  TopLayer And Pad Free-1(6.25mm,-3.8mm)  TopLayer
这是什么意思呀
2014-12-16 09:18:20     打赏
在封装库里这个封装,紫色部分有重叠,
封装库还能重叠,这个肯定不行
2014-12-16 09:44:39     打赏
这个都是重叠的,没有问题啊,或者说这个这样画对不对,如果不对应该怎么画啊
2014-12-16 11:52:48     打赏
画这样的芯片封装,一般人的经验是,根据芯片手册提供的尺寸画,,没有捷径,,
当然可以修改所谓网上的封装库,这个捷径
楼上这样重叠是可以的,但是有这样的芯片管脚?怎么焊接,,没看懂
2014-12-16 13:41:11     打赏
忘了写上了这个是按键
2014-12-16 16:17:21     打赏
你好像是复制的,焊盘名字重复了
