电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 急急急,protel99se出现在DRC错误怎么办,是什么原因,新手求教,
共16条 1/2 1 2 › 跳转至页
2014-12-15 16:48:10     打赏
这是我的第一块电路板,求高手指教啊。
 第二张图中间部分是在生成PCB文件之后画上的直接加了一个网络地GND会不会有问题?第三个图是Design>option里面的设置,这个橘色是是DRC错误自己改成这色了,哪里不合适的请大家指导啊,
这是DRC检测里面的一部分错误,这个要怎么修改啊
   Violation         Net P14_0   is broken into 4 sub-nets. Routed To 72.73%
     Subnet : S13-2    S13-2    S13-2
     Subnet : S14-2    S14-2    S14-2
     Subnet : S15-2    S15-2    S15-2
     Subnet : S16-2    S16-2    S16-2
   Violation         Net XT2OUT_0   is broken into 3 sub-nets. Routed To 0.00%
     Subnet : C3-2
     Subnet : U2-52
     Subnet : Y1-2
   Violation         Net XT2IN_0   is broken into 3 sub-nets. Routed To 0.00%
     Subnet : Y1-1
     Subnet : U2-53
     Subnet : C4-2
   Violation         Net XOUT_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : Y2-1
     Subnet : U2-9
   Violation         Net VREF+_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : C10-2
     Subnet : U2-7
   Violation         Net TMS_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U2-56
     Subnet : JP1-5
   Violation         Net TDO_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U2-54
     Subnet : JP1-1
   Violation         Net TDI_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U2-55
     Subnet : JP1-3
   Violation         Net TCK_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U2-57
     Subnet : JP1-7
   Violation         Net REST_0   is broken into 5 sub-nets. Routed To 0.00%
     Subnet : D1-1
     Subnet : C1-2
     Subnet : JP1-11
     Subnet : R3-1
     Subnet : U2-58
   Violation         Net P63_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : J1-4
     Subnet : U2-2
   Violation         Net P53_0   is broken into 3 sub-nets. Routed To 0.00%
     Subnet : R10-1
     Subnet : U2-47
     Subnet : U4-6
2014-12-15 17:08:44     打赏
嗯,我试试,但是我刚发现一个问题,在封装库里这个封装,紫色部分有重叠,是不是这个问题呢
2014-12-16 08:50:38     打赏
嗯,明白了,
Protel Design System: Library Component Rule Check
PCB File : my430PCB
Date     : 16-Dec-2014
Time     : 08:49:02
Name                Warnings
SOT-223                  Duplicate Pad Name On Pads Pad Free-2(2.29997mm,0.00001mm)  TopLayer And Pad Free-2(2.29997mm,6mm)  TopLayer
SW-PB-001                Duplicate Pad Name On Pads Pad Free-1(-6.25mm,-3.8mm)  TopLayer And Pad Free-1(6.25mm,-3.8mm)  TopLayer
SW-PB-001                Duplicate Pad Name On Pads Pad Free-1(0mm,0mm)  TopLayer And Pad Free-1(6.25mm,-3.8mm)  TopLayer
SW-PB-001                Duplicate Pad Name On Pads Pad Free-2(0mm,-11.176mm)  TopLayer And Pad Free-2(-3.048mm,-7.4mm)  TopLayer
SW-PB-001                Duplicate Pad Name On Pads Pad Free-2(3.1mm,-7.4mm)  TopLayer And Pad Free-2(-3.048mm,-7.4mm)  TopLayer
SW-PB-001                Duplicate Pad Name On Pads Pad Free-1(0mm,-3.8mm)  TopLayer And Pad Free-1(6.25mm,-3.8mm)  TopLayer
这是什么意思呀
2014-12-16 09:44:39     打赏
这个都是重叠的,没有问题啊,或者说这个这样画对不对,如果不对应该怎么画啊
2014-12-16 13:41:11     打赏
忘了写上了这个是按键
2014-12-17 16:42:20     打赏
是这个键盘的封装,倒山字部分是确实用的一个焊盘名,下半部分也是同一个名,
这样子不可以的话我应该怎么改呢,请具体说明谢谢
2014-12-17 16:58:29     打赏
Processing Rule : Broken-Net Constraint ( (On the board ) )
   Violation         Net VCC   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U5-1
     Subnet : C5-1
     Subnet : C3-2
     Subnet : U2-52
     Subnet : Y1-2
     Subnet : Y1-1
     Subnet : U2-53
     Subnet : C4-2
     Subnet : Y2-1
     Subnet : U2-9
     Subnet : C10-2
     Subnet : U2-7
     Subnet : U2-56
     Subnet : JP1-5
     Subnet : U2-54
     Subnet : JP1-1
     Subnet : U2-55
     Subnet : JP1-3
     Subnet : U2-57
     Subnet : JP1-7
     Subnet : D1-1
     Subnet : C1-2
     Subnet : JP1-11
     Subnet : R3-1
     Subnet : U2-58
     Subnet : J1-4
     Subnet : U2-2
     Subnet : R10-1
     Subnet : U2-47
     Subnet : U4-6
   Violation         Net P41(SCL)_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U1-6
     Subnet : R2-1
   Violation         Net P40(SDA)_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U1-5
     Subnet : R1-1
   Violation         Net NetU4_22   is broken into 3 sub-nets. Routed To 0.00%
     Subnet : U4-22
     Subnet : C18-1
     Subnet : Y3-1
   Violation         Net NetU4_21   is broken into 3 sub-nets. Routed To 0.00%
     Subnet : U4-21
     Subnet : Y3-2
     Subnet : C17-1
   Violation         Net NetU4_16   is broken into 3 sub-nets. Routed To 0.00%
     Subnet : U4-16
     Subnet : R11-1
     Subnet : C12-2
   Violation         Net NetU4_13   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : L2-1
     Subnet : U4-13
   Violation         Net NetU4_11   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : L1-1
     Subnet : U4-11
   Violation         Net NetJ1_3   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : RV1-1
     Subnet : J1-3
   Violation         Net NetC8_1   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : C8-1
     Subnet : U3-6
   Violation         Net AVCC   is broken into 3 sub-nets. Routed To 0.00%
     Subnet : U2-64
     Subnet : C5-2
     Subnet : R4-2
   Violation         Net XIN_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : Y2-2
     Subnet : U2-8
   Violation         Net P10_0   is broken into 2 sub-nets. Routed To 94.12%
     Subnet : S13-1    S13-1    S9-1     S5-1     S1-1     S13-1    S13-1    S9-1     S5-1     S1-1
              S9-1     S9-1     S5-1     S5-1     S1-1     S1-1     R5-1
     Subnet : U2-12
   Violation         Net P11_0   is broken into 2 sub-nets. Routed To 94.12%
     Subnet : S14-1    S14-1    S14-1    S14-1    S10-1    S10-1    S10-1    S10-1    S6-1     S6-1
              S6-1     S6-1     S2-1     S2-1     S2-1     S2-1     R6-1
     Subnet : U2-13
   Violation         Net P12_0   is broken into 2 sub-nets. Routed To 94.12%
     Subnet : S15-1    S15-1    S15-1    S15-1    S11-1    S11-1    S11-1    S11-1    S7-1     S7-1
              S7-1     S7-1     S3-1     S3-1     S3-1     S3-1     R7-1
     Subnet : U2-14
   Violation         Net P13_0   is broken into 2 sub-nets. Routed To 94.12%
     Subnet : S16-1    S16-1    S16-1    S16-1    S12-1    S8-1     S4-1     S12-1    S8-1     S4-1
              S12-1    S12-1    S8-1     S8-1     S4-1     S4-1     R8-1
     Subnet : U2-15
   Violation         Net P15_0   is broken into 2 sub-nets. Routed To 91.67%
     Subnet : S9-2     S9-2     S9-2     S10-2    S10-2    S10-2    S11-2    S11-2    S11-2    S12-2
              S12-2    S12-2
     Subnet : U2-17
   Violation         Net P16_0   is broken into 2 sub-nets. Routed To 91.67%
     Subnet : S5-2     S5-2     S5-2     S6-2     S6-2     S6-2     S7-2     S7-2     S7-2     S8-2
              S8-2     S8-2
     Subnet : U2-18
   Violation         Net P17_0   is broken into 2 sub-nets. Routed To 91.67%
     Subnet : S1-2     S2-2     S1-2     S1-2     S2-2     S2-2     S3-2     S3-2     S3-2     S4-2
              S4-2     S4-2
     Subnet : U2-19
   Violation         Net P57_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U4-24
     Subnet : U2-51
   Violation         Net P56_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U4-29
     Subnet : U2-50
   Violation         Net P34_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U3-10
     Subnet : U2-32
   Violation         Net P55_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U4-30
     Subnet : U2-49
   Violation         Net NetU4_14   is broken into 10 sub-nets. Routed To 0.00%
     Subnet : U4-14
     Subnet : C13-1
     Subnet : C21-1
     Subnet : C21-2
     Subnet : C20-2
     Subnet : C20-1
     Subnet : C19-1
     Subnet : C16-1
     Subnet : C14-1
     Subnet : C15-2
   Violation         Net P35_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U3-9
     Subnet : U2-33
   Violation         Net P51_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U4-31
     Subnet : U2-45
   Violation         Net NetL1_2   is broken into 3 sub-nets. Routed To 0.00%
     Subnet : L1-2
     Subnet : C16-2
     Subnet : C14-2
   Violation         Net NetL2_2   is broken into 3 sub-nets. Routed To 0.00%
     Subnet : L2-2
     Subnet : C15-1
     Subnet : C19-2
   Violation         Net NetU4_17   is broken into 3 sub-nets. Routed To 0.00%
     Subnet : U4-17
     Subnet : R9-1
     Subnet : R11-2
   Violation         Net NetR9_2   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : C13-2
     Subnet : R9-2
   Violation         Net P64_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : J1-5
     Subnet : U2-3
   Violation         Net P65_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : J1-6
     Subnet : U2-4
   Violation         Net P20_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : J1-7
     Subnet : U2-20
   Violation         Net P21_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : J1-8
     Subnet : U2-21
   Violation         Net P22_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : J1-9
     Subnet : U2-22
   Violation         Net P23_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : J1-10
     Subnet : U2-23
   Violation         Net P24_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : J1-11
     Subnet : U2-24
   Violation         Net P25_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U2-25
     Subnet : J1-12
   Violation         Net P26_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U2-26
     Subnet : J1-13
   Violation         Net P27_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U2-27
     Subnet : J1-14
   Violation         Net P66_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U2-5
     Subnet : J1-15
   Violation         Net P67_0   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : U2-6
     Subnet : J1-16
   Violation         Net NetJ1_18   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : RV1-3
     Subnet : J1-18
   Violation         Net 3.3V   is broken into 24 sub-nets. Routed To 11.54%
     Subnet : R5-2     R6-2
     Subnet : C6-2     U3-16
     Subnet : R1-2
     Subnet : U1-8
     Subnet : J1-2
     Subnet : R10-2
     Subnet : U4-3
     Subnet : R2-2
     Subnet : D1-2
     Subnet : U4-2
     Subnet : U4-12
     Subnet : U4-32
     Subnet : R7-2     R8-2
     Subnet : C22-1
     Subnet : C23-1
     Subnet : C2-1
     Subnet : R3-2
     Subnet : U4-15
     Subnet : C11-1
     Subnet : U2-1
     Subnet : JP1-2
     Subnet : R4-1
     Subnet : J1-17
     Subnet : J1-19
   Violation         Net GND   is broken into 30 sub-nets. Routed To 17.14%
     Subnet : J2-5     C8-2     U3-11    U3-15
     Subnet : U1-4
     Subnet : U1-3
     Subnet : U1-2
     Subnet : U1-7
     Subnet : U1-1
     Subnet : RV1-2
     Subnet : J1-1
     Subnet : U4-5     U4-33    U4-10    U4-18
     Subnet : U4-4
     Subnet : U4-1
     Subnet : U5-2
     Subnet : U5-3
     Subnet : R12-1
     Subnet : C22-2
     Subnet : C23-2
     Subnet : U5-2
     Subnet : JP1-9
     Subnet : C2-2
     Subnet : C10-1
     Subnet : C1-1
     Subnet : C12-1
     Subnet : U2-63
     Subnet : U2-62
     Subnet : C3-1
     Subnet : C4-1
     Subnet : C18-2
     Subnet : C11-2
     Subnet : J1-20
     Subnet : C17-2
Rule Violations :56
Processing Rule : Clearance Constraint (Gap=10mil) (On the board ),(On the board )
   Violation between Pad U2-2(1760mil,4460.315mil)  TopLayer and
                     Pad U2-1(1760mil,4480mil)  TopLayer
   Violation between Pad U2-55(2025.748mil,4568.583mil)  TopLayer and
                     Pad U2-54(2045.433mil,4568.583mil)  TopLayer
   Violation between Pad U2-53(2065.118mil,4568.583mil)  TopLayer and
   Violation between Pad U2-44(2232.441mil,4401.26mil)  TopLayer and
                     Pad U2-45(2232.441mil,4420.945mil)  TopLayer
   Violation between Pad U2-46(2232.441mil,4440.63mil)  TopLayer and
   Violation between Pad U2-3(1760mil,4440.63mil)  TopLayer and
   Violation between Pad U2-14(1760mil,4224.095mil)  TopLayer and
                     Pad U2-13(1760mil,4243.779mil)  TopLayer
   Violation between Pad U2-12(1760mil,4263.465mil)  TopLayer and
   Violation between Pad U2-35(2232.441mil,4224.095mil)  TopLayer and
                     Pad U2-36(2232.441mil,4243.779mil)  TopLayer
   Violation between Pad U2-37(2232.441mil,4263.465mil)  TopLayer and
   Violation between Pad U2-29(2084.803mil,4096.142mil)  TopLayer and
                     Pad U2-30(2104.488mil,4096.142mil)  TopLayer
   Violation between Pad U2-31(2124.173mil,4096.142mil)  TopLayer and
   Violation between Pad U2-41(2232.441mil,4342.205mil)  TopLayer and
                     Pad U2-42(2232.441mil,4361.89mil)  TopLayer
   Violation between Pad U2-43(2232.441mil,4381.575mil)  TopLayer and
   Violation between Pad U2-34(2232.441mil,4204.409mil)  TopLayer and
   Violation between Pad U2-7(1760mil,4361.89mil)  TopLayer and
                     Pad U2-6(1760mil,4381.575mil)  TopLayer
   Violation between Pad U2-5(1760mil,4401.26mil)  TopLayer and
   Violation between Pad U2-20(1907.638mil,4096.142mil)  TopLayer and
                     Pad U2-21(1927.323mil,4096.142mil)  TopLayer
   Violation between Pad U2-22(1947.008mil,4096.142mil)  TopLayer and
   Violation between Pad U2-32(2143.858mil,4096.142mil)  TopLayer and
                     Pad U2-11(1760mil,4283.15mil)  TopLayer
   Violation between Pad U2-10(1760mil,4302.835mil)  TopLayer and
   Violation between Pad U2-62(1887.953mil,4568.583mil)  TopLayer and
                     Pad U2-61(1907.638mil,4568.583mil)  TopLayer
   Violation between Pad U2-60(1927.323mil,4568.583mil)  TopLayer and
                     Pad U2-33(2232.441mil,4184.724mil)  TopLayer
   Violation between Pad U2-4(1760mil,4420.945mil)  TopLayer and
   Violation between Pad U2-9(1760mil,4322.52mil)  TopLayer and
                     Pad U2-8(1760mil,4342.205mil)  TopLayer
   Violation between Pad U2-64(1848.583mil,4568.583mil)  TopLayer and
                     Pad U2-63(1868.268mil,4568.583mil)  TopLayer
   Violation between Pad U2-59(1947.008mil,4568.583mil)  TopLayer and
   Violation between Pad U2-56(2006.063mil,4568.583mil)  TopLayer and
   Violation between Pad U2-47(2232.441mil,4460.315mil)  TopLayer and
   Violation between Pad U2-39(2232.441mil,4302.835mil)  TopLayer and
                     Pad U2-40(2232.441mil,4322.52mil)  TopLayer
                     Pad U2-38(2232.441mil,4283.15mil)  TopLayer
   Violation between Pad U2-28(2065.118mil,4096.142mil)  TopLayer and
   Violation between Pad U2-26(2025.748mil,4096.142mil)  TopLayer and
                     Pad U2-27(2045.433mil,4096.142mil)  TopLayer
   Violation between Pad U2-24(1986.378mil,4096.142mil)  TopLayer and
                     Pad U2-25(2006.063mil,4096.142mil)  TopLayer
   Violation between Pad U2-23(1966.693mil,4096.142mil)  TopLayer and
   Violation between Pad U2-19(1887.953mil,4096.142mil)  TopLayer and
   Violation between Pad U2-15(1760mil,4204.409mil)  TopLayer and
   Violation between Pad U2-58(1966.693mil,4568.583mil)  TopLayer and
   Violation between Pad U2-50(2124.173mil,4568.583mil)  TopLayer and
                     Pad U2-49(2143.858mil,4568.583mil)  TopLayer
   Violation between Pad U2-48(2232.441mil,4480mil)  TopLayer and
   Violation between Track (1726.429mil,4184.724mil)(1760mil,4184.724mil)  TopLayer and
   Violation between Pad U2-16(1760mil,4184.724mil)  TopLayer and
   Violation between Pad U2-18(1868.268mil,4096.142mil)  TopLayer and
                     Pad U2-17(1848.583mil,4096.142mil)  TopLayer
   Violation between Pad U2-51(2104.488mil,4568.583mil)  TopLayer and
   Violation between Pad U2-52(2084.803mil,4568.583mil)  TopLayer and
   Violation between Pad U2-57(1986.378mil,4568.583mil)  TopLayer and
   Violation between Pad U4-2(1160mil,6060.315mil)  TopLayer and
                     Pad U4-1(1160mil,6080mil)  TopLayer
Rule Violations :61
这个呢
2014-12-17 17:32:47     打赏
可是芯片引脚间距就是这个呀,430片子和RC522都按手册上的画了,那这个怎么办啊
2014-12-18 09:24:05     打赏
改成0了,还是有错,
是网络错误吗???
这个怎么改啊
Processing Rule : Width Constraint (Min=10mil) (Max=10mil) (Prefered=10mil) (On the board )
Rule Violations :0
Processing Rule : Clearance Constraint (Gap=0mil) (On the board ),(On the board )
Rule Violations :0
   Violation         Net GND   is broken into 28 sub-nets. Routed To 22.86%
     Subnet : U1-4
     Subnet : U1-3
     Subnet : U1-2
     Subnet : U1-1
     Subnet : RV1-2
     Subnet : U1-7
     Subnet : J1-1
     Subnet : U4-5     U4-4     U4-33    U4-10    U4-1     U4-18
     Subnet : C10-1
     Subnet : U5-2
     Subnet : C22-2
     Subnet : U5-3
     Subnet : R12-1
     Subnet : C23-2
     Subnet : U2-63
     Subnet : U5-2
     Subnet : JP1-9
     Subnet : C2-2
     Subnet : C1-1
     Subnet : U2-62
     Subnet : C3-1
     Subnet : C4-1
     Subnet : J1-20
     Subnet : C12-1
     Subnet : C11-2
     Subnet : C18-2
     Subnet : C17-2
     Subnet : R5-2     R6-2
     Subnet : C6-2     U3-16
     Subnet : R1-2
     Subnet : U1-8
     Sub
2014-12-18 15:58:14     打赏
第一点该怎么设置啊,
上次那个按键的封装画在一起了可是还是出错啊
共16条 1/2 1 2 › 跳转至页
