Nginx是一个轻量级的web服务器,不过系统集成的版本一般比较老,如何尝试升级到比较新的呢,这里只是一个尝试,可能成功,也可能失败,查询了自己的系统中集成的三个版本,用命令nginx -v,从2012年的1.2.1到2014年的1.6.2,总之现在是2017年中了,现在的稳定版本是1.12.0了。
尝试了apt-get update,apt-get install nginx提示我的已经是最新的了,无语
尝试在sources.list中增加nginx官方的源,
vi /etc/apt/sources.list
deb http://nginx.org/packages/debian/ jessie nginx
可是没有arm的支持
Failed to fetch http://nginx.org/packages/debian/dists/jessie/nginx/binary-armhf/Packages 404 Not Found [IP: 95.211.80.227 80]
看来不能偷懒了,只能研究自己编译了
去 http://nginx.org/en/download.html 下载 nginx-1.12.0 (http://nginx.org/download/nginx-1.12.0.tar.gz)
首先解压
tar xzf nginx-1.12.0.tar.gz
然后
cd nginx-1.12.0 && ./configure 检查配置环境
虽然看不懂,但感觉少的东西不多,先编译尝试吧
checking for OS + Linux 3.4.39-BPI-M3-Kernel armv7l checking for C compiler ... found + using GNU C compiler + gcc version: 4.9.2 (Raspbian 4.9.2-10) checking for gcc -pipe switch ... found checking for -Wl,-E switch ... found checking for gcc builtin atomic operations ... found checking for C99 variadic macros ... found checking for gcc variadic macros ... found checking for gcc builtin 64 bit byteswap ... found checking for unistd.h ... found checking for inttypes.h ... found checking for limits.h ... found checking for sys/filio.h ... not found checking for sys/param.h ... found checking for sys/mount.h ... found checking for sys/statvfs.h ... found checking for crypt.h ... found checking for Linux specific features checking for epoll ... found checking for EPOLLRDHUP ... found checking for EPOLLEXCLUSIVE ... not found checking for O_PATH ... found checking for sendfile() ... found checking for sendfile64() ... found checking for sys/prctl.h ... found checking for prctl(PR_SET_DUMPABLE) ... found checking for sched_setaffinity() ... found checking for crypt_r() ... found checking for sys/vfs.h ... found checking for nobody group ... not found checking for nogroup group ... found checking for poll() ... found checking for /dev/poll ... not found checking for kqueue ... not found checking for crypt() ... not found checking for crypt() in libcrypt ... found checking for F_READAHEAD ... not found checking for posix_fadvise() ... found checking for O_DIRECT ... found checking for F_NOCACHE ... not found checking for directio() ... not found checking for statfs() ... found checking for statvfs() ... found checking for dlopen() ... not found checking for dlopen() in libdl ... found checking for sched_yield() ... found checking for SO_SETFIB ... not found checking for SO_REUSEPORT ... found checking for SO_ACCEPTFILTER ... not found checking for SO_BINDANY ... not found checking for IP_BIND_ADDRESS_NO_PORT ... not found checking for IP_TRANSPARENT ... found checking for IP_BINDANY ... not found checking for IP_RECVDSTADDR ... not found checking for IP_PKTINFO ... found checking for IPV6_RECVPKTINFO ... found checking for TCP_DEFER_ACCEPT ... found checking for TCP_KEEPIDLE ... found checking for TCP_FASTOPEN ... found checking for TCP_INFO ... found checking for accept4() ... found checking for eventfd() ... found checking for int size ... 4 bytes checking for long size ... 4 bytes checking for long long size ... 8 bytes checking for void * size ... 4 bytes checking for uint32_t ... found checking for uint64_t ... found checking for sig_atomic_t ... found checking for sig_atomic_t size ... 4 bytes checking for socklen_t ... found checking for in_addr_t ... found checking for in_port_t ... found checking for rlim_t ... found checking for uintptr_t ... uintptr_t found checking for system byte ordering ... little endian checking for size_t size ... 4 bytes checking for off_t size ... 8 bytes checking for time_t size ... 4 bytes checking for AF_INET6 ... found checking for setproctitle() ... not found checking for pread() ... found checking for pwrite() ... found checking for pwritev() ... found checking for sys_nerr ... found checking for localtime_r() ... found checking for posix_memalign() ... found checking for memalign() ... found checking for mmap(MAP_ANON|MAP_SHARED) ... found checking for mmap("/dev/zero", MAP_SHARED) ... found checking for System V shared memory ... found checking for POSIX semaphores ... not found checking for POSIX semaphores in libpthread ... found checking for struct msghdr.msg_control ... found checking for ioctl(FIONBIO) ... found checking for struct tm.tm_gmtoff ... found checking for struct dirent.d_namlen ... not found checking for struct dirent.d_type ... found checking for sysconf(_SC_NPROCESSORS_ONLN) ... found checking for openat(), fstatat() ... found checking for getaddrinfo() ... found checking for PCRE library ... found checking for PCRE JIT support ... found checking for zlib library ... found creating objs/Makefile Configuration summary + using system PCRE library + OpenSSL library is not used + using system zlib library nginx path prefix: "/usr/local/nginx" nginx binary file: "/usr/local/nginx/sbin/nginx" nginx modules path: "/usr/local/nginx/modules" nginx configuration prefix: "/usr/local/nginx/conf" nginx configuration file: "/usr/local/nginx/conf/nginx.conf" nginx pid file: "/usr/local/nginx/logs/nginx.pid" nginx error log file: "/usr/local/nginx/logs/error.log" nginx http access log file: "/usr/local/nginx/logs/access.log" nginx http client request body temporary files: "client_body_temp" nginx http proxy temporary files: "proxy_temp" nginx http fastcgi temporary files: "fastcgi_temp" nginx http uwsgi temporary files: "uwsgi_temp" nginx http scgi temporary files: "scgi_temp"
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
电流检测模块MAX4080S被打赏10分 | |
多组DCTODC电源方案被打赏50分 | |
新手必看!C语言精华知识:表驱动法被打赏50分 | |
【我踩过的那些坑】杜绑线问题被打赏50分 | |
【我踩过的那些坑】晶振使用的问题被打赏100分 | |
【我踩过的那些坑】工作那些年踩过的记忆深刻的坑被打赏10分 |
