电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » Android平台移植FFMPEG媒体解码库
2018-05-22 11:00:04     打赏
交叉编译环境:Ubuntu12.04 (32位)
FFMPEG版本:ffmpeg-2.8.1.tar.bz2
Android NDK开发包:android-ndk32-r10b-linux-x86.tar.bz2
[plain] view plain copy
  1. </pre><pre name="code" class="plain">#!/bin/bash
  2. #
  3. # FFmpeg-Android, a bash script to build FFmpeg for Android.
  4. #
  5. # Copyright (c) 2012 Cedric Fung <root@vec.io>
  6. #
  7. # FFmpeg-Android will build FFmpeg for Android automatically,
  8. # with patches from VPlayer's Android version <https://vplayer.net/>.
  9. #
  10. # FFmpeg-Android is free software; you can redistribute it and/or
  11. # modify it under the terms of the GNU Lesser General Public
  12. # License as published by the Free Software Foundation; either
  13. # version 3 of the License, or (at your option) any later version.
  14.
  15. # FFmpeg-Android is distributed in the hope that it will be useful,
  16. # but WITHOUT ANY WARRANTY; without even the implied warranty of
  17. # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  18. # Lesser General Public License for more details.
  19.
  20. # You should have received a copy of the GNU Lesser General Public
  21. # License along with FFmpeg-Android; if not, write to the Free Software
  22. # Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
  23. #
  24. #
  25. # Instruction:
  26. #
  27. # 0. Install git and Android ndk
  28. # 1. $ export ANDROID_NDK=/path/to/your/android-ndk
  29. # 2. $ ./FFmpeg-Android.sh
  30. # 3. libffmpeg.so will be built to build/ffmpeg/{neon,armv7,vfp,armv6}/
  31. #
  32. #
  33.
  34. DEST=`pwd`/build/ffmpeg && rm -rf $DEST
  35. SOURCE=`pwd`/ffmpeg
  36. ANDROID_NDK=/work/FFMPEG/android-ndk-r10b
  37.
  38. TOOLCHAIN=/work/FFMPEG/toolchain
  39. SYSROOT=$TOOLCHAIN/sysroot/
  40. #$ANDROID_NDK/build/tools/make-standalone-toolchain.sh --platform=android-14 --install-dir=$TOOLCHAIN
  41.
  42. export PATH=$TOOLCHAIN/bin:$PATH
  43. export CC="ccache arm-linux-androideabi-gcc"
  44. export LD=arm-linux-androideabi-ld
  45. export AR=arm-linux-androideabi-ar
  46.
  47. CFLAGS="-O3 -Wall -mthumb -pipe -fpic -fasm \
  48.         -finline-limit=300 -ffast-math \
  49.         -fstrict-aliasing -Werror=strict-aliasing \
  50.         -fmodulo-sched -fmodulo-sched-allow-regmoves \
  51.         -Wno-psabi -Wa,--noexecstack \
  52.         -D__ARM_ARCH_5__ -D__ARM_ARCH_5E__ -D__ARM_ARCH_5T__ -D__ARM_ARCH_5TE__ \
  53.         -DANDROID -DNDEBUG"
  54.
  55. FFMPEG_FLAGS="--prefix=/work/FFMPEG/ffmpeg_android/ \
  56.               --target-os=android \
  57.               --arch=arm \
  58.               --enable-cross-compile \
  59.               --cross-prefix=arm-linux-androideabi- \
  60.               --enable-shared \
  61.               --disable-symver \
  62.               --disable-doc \
  63.               --disable-ffplay \
  64.               --disable-ffmpeg \
  65.               --disable-ffprobe \
  66.               --disable-ffserver \
  67.               --disable-avdevice \
  68.               --disable-avfilter \
  69.               --disable-encoders \
  70.               --disable-muxers \
  71.               --disable-bsfs \
  72.               --disable-filters \
  73.               --disable-devices \
  74.               --disable-everything \
  75.               --enable-protocols  \
  76.               --enable-parsers \
  77.               --enable-demuxers \
  78.               --disable-demuxer=sbg \
  79.               --enable-decoders \
  80.               --enable-network \
  81.               --enable-swscale  \
  82.               --enable-version3 \
  83.               --disable-inline-asm \
  84.               --disable-yasm \
  85.               --disable-mips32r2 \
  86.               --disable-mipsdspr1 \
  87.               --disable-mipsdspr2 \
  88.               --disable-mipsfpu \
  89.               --disable-fast-unaligned \
  90.               --disable-debug \
  91.               --disable-xmm-clobber-test \
  92.               --enable-decoder=h264 \
  93.               --enable-decoder=mpeg4 \
  94.               --enable-decoder=mjpeg \
  95.               --enable-demuxer=h264 \
  96.               --enable-demuxer=mpeg4 \
  97.               --enable-demuxer=mjpeg \
  98.               --enable-parser=h264 \
  99.               --enable-memalign-hack \
  100.               --disable-asm \
  101.               --disable-altivec \
  102.               --disable-amd3dnow \
  103.               --disable-amd3dnowext \
  104.               --enable-mmx \
  105.               --enable-mmxext \
  106.               --disable-sse \
  107.               --disable-sse2 \
  108.               --disable-sse3 \
  109.               --disable-ssse3 \
  110.               --disable-sse4 \
  111.               --disable-fma4"
  112.
  113.
  114. for version in neon armv7 vfp armv6; do
  115.
  116. cd $SOURCE
  117.
  118. case $version in
  119. neon)
  120.     EXTRA_CFLAGS="-march=armv7-a -mfpu=neon -mfloat-abi=softfp -mvectorize-with-neon-quad"
  121.     EXTRA_LDFLAGS="-Wl,--fix-cortex-a8"
  122.     ;;
  123. armv7)
  124.     EXTRA_CFLAGS="-march=armv7-a -mfpu=vfpv3-d16 -mfloat-abi=softfp"
  125.     EXTRA_LDFLAGS="-Wl,--fix-cortex-a8"
  126.     ;;
  127. vfp)
  128.     EXTRA_CFLAGS="-march=armv6 -mfpu=vfp -mfloat-abi=softfp"
  129.     EXTRA_LDFLAGS=""
  130.     ;;
  131. armv6)
  132.     EXTRA_CFLAGS="-march=armv6"
  133.     EXTRA_LDFLAGS=""
  134.     ;;
  135. *)
  136.     EXTRA_CFLAGS=""
  137.     EXTRA_LDFLAGS=""
  138.     ;;
  139. esac
  140.
  141. PREFIX="$DEST/$version" && mkdir -p $PREFIX
  142. FFMPEG_FLAGS="$FFMPEG_FLAGS --prefix=$PREFIX"
  143.
  144. ./configure $FFMPEG_FLAGS --extra-cflags="$CFLAGS $EXTRA_CFLAGS" --extra-ldflags="$EXTRA_LDFLAGS" | tee $PREFIX/configuration.txt
  145. cp config.* $PREFIX
  146. [ $PIPESTATUS == 0 ] || exit 1
  147.
  148. make clean
  149. make -j4 || exit 1
  150. make install || exit 1
  151.
  152. rm libavcodec/inverse.o
  153. $CC -lm -lz -shared --sysroot=$SYSROOT -Wl,--no-undefined -Wl,-z,noexecstack $EXTRA_LDFLAGS libavutil/*.o libavutil/arm/*.o libavcodec/*.o libavcodec/arm/*.o libavformat/*.o libswresample/*.o libswscale/*.o -o $PREFIX/libffmpeg.so
  154.
  155. cp $PREFIX/libffmpeg.so $PREFIX/libffmpeg-debug.so
  156. arm-linux-androideabi-strip --strip-unneeded $PREFIX/libffmpeg.so
  157.
  158. done
注意:
1、直接运行上面的脚本会出错,提示如下:
arm-linux-androideabi-gcc is unable to create an executable file.
C compiler test failed.
解决办法
执行以上脚本前,先在命令行上执行以下命令把对NDK包中的交叉编译工具链独立提取出来到指定的目录:
/work/FFMPEG/android-ndk-r10b/build/tools/make-standalone-toolchain.sh --platform=android-14 --install-dir=/work/FFMPEG/toolchain/
2、target-os=android,此处不要再用linux了。
3、注意NDK的版本,如果应用代码中使用的是32位系统库,则交叉编译的时候就应该用32位的NDK开发包。
