电子产品世界 » 论坛首页 » 嵌入式开发 » 软件与操作系统 » rtthread串口框架V1
共3条 1/1 1 跳转至
rtthread串口框架V1
2024-11-26 20:06:46     打赏
前言
   RTT存在两版串口框架,而从bsp目录的适配情况看,两版串口框架都有新bsp适配使用,因此两套框架都需要学习。
       由于V2相比较于V1,改动还挺多,因此学习时,将两套框架分开学习。
代码解析
   V1框架的代码主要放置于/components/drivers/serial/serial.c中,因此学习也是围绕该文件而展开的。
串口注册入口
     串口注册入口其实挺好找,在RTT设备框架里,所有设备都是基于device框架实现的,因此只需要在框架文件中搜索 struct rt_device_ops ,再反查便可定位到注册入口,具体注册入口如下:
#ifdef RT_USING_DEVICE_OPS
const static struct rt_device_ops serial_ops =
    rt_serial_init,
    rt_serial_open,
    rt_serial_close,
    rt_serial_read,
    rt_serial_write,
    rt_serial_control
#endif
 * serial register
rt_err_t rt_hw_serial_register(struct rt_serial_device *serial,
                               const char              *name,
                               rt_uint32_t              flag,
                               void                    *data)
    rt_err_t ret;
    struct rt_device *device;
    RT_ASSERT(serial != RT_NULL);
    rt_spin_lock_init(&(serial->spinlock));
    device = &(serial->parent);
    device->type        = RT_Device_Class_Char;
    device->rx_indicate = RT_NULL;
    device->tx_complete = RT_NULL;
    device->ops         = &serial_ops;
#else
    device->init        = rt_serial_init;
    device->open        = rt_serial_open;
    device->close       = rt_serial_close;
    device->read        = rt_serial_read;
    device->write       = rt_serial_write;
    device->control     = rt_serial_control;
#endif
    device->user_data   = data;
    /* register a character device */
    ret = rt_device_register(device, name, flag);
#ifdef RT_USING_POSIX_STDIO
    /* set fops */
    device->fops        = &_serial_fops;
#endif
#if defined(RT_USING_SMART)
    rt_hw_serial_register_tty(serial);
#endif
    return ret;
       观察注册入口,其实就可以发现,里面主要干了这么几件事,初始化自旋锁(作用得后面分析才清楚),标准的设备注册操作,最后是特定功能的特定入口注册,由于现在所使用的平台是非RTSmart的平台,因此关于RT_USING_SMART也就不去分析了。
串口初始化入口
static rt_err_t rt_serial_init(struct rt_device *dev)
    rt_err_t result = RT_EOK;
    struct rt_serial_device *serial;
    RT_ASSERT(dev != RT_NULL);
    serial = (struct rt_serial_device *)dev;
    /* initialize rx/tx */
    serial->serial_rx = RT_NULL;
    serial->serial_tx = RT_NULL;
    rt_memset(&serial->rx_notify, 0, sizeof(struct rt_device_notify));
    /* apply configuration */
    if (serial->ops->configure)
        result = serial->ops->configure(serial, &serial->config);
    return result;
    从初始化入口上看,实际上就是提前初始化串口所需要的变量,以防后面逻辑跑乱。另外,调用了驱动层的configure入口,将当前串口的配置信息传递至驱动层实现。
串口打开入口
static rt_err_t rt_serial_open(struct rt_device *dev, rt_uint16_t oflag)
    rt_uint16_t stream_flag = 0;
    LOG_D("open serial device: 0x%08x with open flag: 0x%04x",
        dev, oflag);
    /* check device flag with the open flag */
    if ((oflag & RT_DEVICE_FLAG_DMA_RX) && !(dev->flag & RT_DEVICE_FLAG_DMA_RX))
        return -RT_EIO;
    if ((oflag & RT_DEVICE_FLAG_DMA_TX) && !(dev->flag & RT_DEVICE_FLAG_DMA_TX))
        return -RT_EIO;
    if ((oflag & RT_DEVICE_FLAG_INT_RX) && !(dev->flag & RT_DEVICE_FLAG_INT_RX))
        return -RT_EIO;
    if ((oflag & RT_DEVICE_FLAG_INT_TX) && !(dev->flag & RT_DEVICE_FLAG_INT_TX))
        return -RT_EIO;
    /* keep steam flag */
    if ((oflag & RT_DEVICE_FLAG_STREAM) || (dev->open_flag & RT_DEVICE_FLAG_STREAM))
        stream_flag = RT_DEVICE_FLAG_STREAM;
    /* get open flags */
    dev->open_flag = oflag & 0xff;
#ifdef RT_USING_PINCTRL
    /* initialize iomux in DM */
    rt_pin_ctrl_confs_apply_by_name(dev, RT_NULL);
#endif
    /* initialize the Rx/Tx structure according to open flag */
    if (serial->serial_rx == RT_NULL)
        if (oflag & RT_DEVICE_FLAG_INT_RX)
            struct rt_serial_rx_fifo* rx_fifo;
            rx_fifo = (struct rt_serial_rx_fifo*) rt_malloc (sizeof(struct rt_serial_rx_fifo) +
                serial->config.bufsz);
            RT_ASSERT(rx_fifo != RT_NULL);
            rx_fifo->buffer = (rt_uint8_t*) (rx_fifo + 1);
            rt_memset(rx_fifo->buffer, 0, serial->config.bufsz);
            rx_fifo->put_index = 0;
            rx_fifo->get_index = 0;
            rx_fifo->is_full = RT_FALSE;
            serial->serial_rx = rx_fifo;
            dev->open_flag |= RT_DEVICE_FLAG_INT_RX;
            /* configure low level device */
            serial->ops->control(serial, RT_DEVICE_CTRL_SET_INT, (void *)RT_DEVICE_FLAG_INT_RX);
#ifdef RT_SERIAL_USING_DMA
        else if (oflag & RT_DEVICE_FLAG_DMA_RX)
            if (serial->config.bufsz == 0) {
                struct rt_serial_rx_dma* rx_dma;
                rx_dma = (struct rt_serial_rx_dma*) rt_malloc (sizeof(struct rt_serial_rx_dma));
                RT_ASSERT(rx_dma != RT_NULL);
                rx_dma->activated = RT_FALSE;
                serial->serial_rx = rx_dma;
            } else {
                /* configure fifo address and length to low level device */
                serial->ops->control(serial, RT_DEVICE_CTRL_CONFIG, (void *) RT_DEVICE_FLAG_DMA_RX);
            dev->open_flag |= RT_DEVICE_FLAG_DMA_RX;
#endif /* RT_SERIAL_USING_DMA */
        else
    else
    if (serial->serial_tx == RT_NULL)
        if (oflag & RT_DEVICE_FLAG_INT_TX)
            struct rt_serial_tx_fifo *tx_fifo;
            tx_fifo = (struct rt_serial_tx_fifo*) rt_malloc(sizeof(struct rt_serial_tx_fifo));
            RT_ASSERT(tx_fifo != RT_NULL);
            rt_completion_init(&(tx_fifo->completion));
            serial->serial_tx = tx_fifo;
            dev->open_flag |= RT_DEVICE_FLAG_INT_TX;
            serial->ops->control(serial, RT_DEVICE_CTRL_SET_INT, (void *)RT_DEVICE_FLAG_INT_TX);
        else if (oflag & RT_DEVICE_FLAG_DMA_TX)
            struct rt_serial_tx_dma* tx_dma;
            tx_dma = (struct rt_serial_tx_dma*) rt_malloc (sizeof(struct rt_serial_tx_dma));
            RT_ASSERT(tx_dma != RT_NULL);
            tx_dma->activated = RT_FALSE;
            rt_data_queue_init(&(tx_dma->data_queue), 8, 4, RT_NULL);
            serial->serial_tx = tx_dma;
            dev->open_flag |= RT_DEVICE_FLAG_DMA_TX;
            serial->ops->control(serial, RT_DEVICE_CTRL_CONFIG, (void *)RT_DEVICE_FLAG_DMA_TX);
        else
    else
    /* set stream flag */
    dev->open_flag |= stream_flag;
    return RT_EOK;
   乍一看,这函数写的实在是长,完全违背了不超过屏幕一页的规则。但是细看,会发现,这个函数也就做了以下几个事情:
       1. 先是检查打开方式与对应串口支持的方式是否匹配。若不匹配,则直接返回错误信息,若匹配,则继续后续操作。其中,流模式比较特殊,具体操作为不匹配,则不保存对应功能,原因稍后给出。
      2. 根据serial_rx这个指针是否被赋值,决定是否需要打开RX功能,其中,不同打开方式操作方式有细微差异
      3. 根据serial_tx这个指针是否被赋值,决定是否需要打开TX功能,其中,不同打开方式的操作方式有细微差异
       4. 存储流模式标记
串口读操作
 * Serial poll routines
rt_inline int _serial_poll_rx(struct rt_serial_device *serial, rt_uint8_t *data, int length)
    int ch;
    int size;
    size = length;
    while (length)
        ch = serial->ops->getc(serial);
        if (ch == -1) break;
        *data = ch;
        data ++; length --;
        if(serial->parent.open_flag & RT_DEVICE_FLAG_STREAM)
            if (ch == '\n') break;
    return size - length;
 * Serial DMA routines
rt_inline int _serial_dma_rx(struct rt_serial_device *serial, rt_uint8_t *data, int length)
    rt_base_t level;
    RT_ASSERT((serial != RT_NULL) && (data != RT_NULL));
    level = rt_spin_lock_irqsave(&(serial->spinlock));
        int result = RT_EOK;
        struct rt_serial_rx_dma *rx_dma;
        rx_dma = (struct rt_serial_rx_dma*)serial->serial_rx;
        if (rx_dma->activated != RT_TRUE)
            rx_dma->activated = RT_TRUE;
            RT_ASSERT(serial->ops->dma_transmit != RT_NULL);
            serial->ops->dma_transmit(serial, data, length, RT_SERIAL_DMA_RX);
        else result = -RT_EBUSY;
        rt_spin_unlock_irqrestore(&(serial->spinlock), level);
        if (result == RT_EOK) return length;
        rt_set_errno(result);
        return 0;
    else
        struct rt_serial_rx_fifo *rx_fifo = (struct rt_serial_rx_fifo *) serial->serial_rx;
        rt_size_t recv_len = 0, fifo_recved_len = rt_dma_calc_recved_len(serial);
        if (length < (int)fifo_recved_len)
            recv_len = length;
        else
            recv_len = fifo_recved_len;
        if (rx_fifo->get_index + recv_len < serial->config.bufsz)
            rt_memcpy(data, rx_fifo->buffer + rx_fifo->get_index, recv_len);
        else
                    serial->config.bufsz - rx_fifo->get_index);
            rt_memcpy(data + serial->config.bufsz - rx_fifo->get_index, rx_fifo->buffer,
                    recv_len + rx_fifo->get_index - serial->config.bufsz);
        rt_dma_recv_update_get_index(serial, recv_len);
        return recv_len;
 * Serial interrupt routines
rt_inline int _serial_int_rx(struct rt_serial_device *serial, rt_uint8_t *data, int length)
    int size;
    size = length;
    rx_fifo = (struct rt_serial_rx_fifo*) serial->serial_rx;
    /* read from software FIFO */
    while (length)
        int ch;
        rt_base_t level;
        /* disable interrupt */
        /* there's no data: */
        if ((rx_fifo->get_index == rx_fifo->put_index) && (rx_fifo->is_full == RT_FALSE))
            /* no data, enable interrupt and break out */
            break;
        /* otherwise there's the data: */
        ch = rx_fifo->buffer[rx_fifo->get_index];
        rx_fifo->get_index += 1;
        if (rx_fifo->get_index >= serial->config.bufsz) rx_fifo->get_index = 0;
        if (rx_fifo->is_full == RT_TRUE)
        /* enable interrupt */
        *data = ch & 0xff;
        data ++; length --;
static rt_ssize_t rt_serial_read(struct rt_device *dev,
                                rt_off_t          pos,
                                void             *buffer,
                                rt_size_t         size)
    if (size == 0) return 0;
    if (dev->open_flag & RT_DEVICE_FLAG_INT_RX)
        return _serial_int_rx(serial, (rt_uint8_t *)buffer, size);
    else if (dev->open_flag & RT_DEVICE_FLAG_DMA_RX)
        return _serial_dma_rx(serial, (rt_uint8_t *)buffer, size);
    return _serial_poll_rx(serial, (rt_uint8_t *)buffer, size);
   从这里面可以看到,串口框架实现了三种读取方式,三种读取方式的具体实现如下:
         1. 中断接收(_serial_int_rx):是用中断方式去驱动读取,而由于存在buffer操作,因此需要自旋锁的保护措施,以防多方操作buffer导致数据异常。
        2. dma接收(_serial_dma_rx):里面操作根据不同的dma类型,存在不同的操作。其分为两种实现,一种为dma自己维护buffer时,直接调用驱动提供的dma_transmit接口读取数据,另一种与中断方式类似,直接读取buffer中的缓存。两种读取方式都需要自旋锁保护(暂时不理解为何dma维护buffre时,也需要自旋锁保护)。
       3. 轮询接收(_serial_poll_rx):此方法使用轮询的方式直接从驱动中读取数据,因此实现中直接对接驱动中的getc,且没有自旋锁保护的措施。而在这实现中,可以发现,所谓的流模式,即为遇到换行符时退出读取。
串口写操作
rt_inline int _serial_poll_tx(struct rt_serial_device *serial, const rt_uint8_t *data, int length)
    int size;
    size = length;
    while (length)
         * to be polite with serial console add a line feed
         * to the carriage return character
        if (*data == '\n' && (serial->parent.open_flag & RT_DEVICE_FLAG_STREAM))
            serial->ops->putc(serial, '\r');
        serial->ops->putc(serial, *data);
        ++ data;
        -- length;
rt_inline int _serial_dma_tx(struct rt_serial_device *serial, const rt_uint8_t *data, int length)
    rt_base_t level;
    rt_err_t result;
    struct rt_serial_tx_dma *tx_dma;
    tx_dma = (struct rt_serial_tx_dma*)(serial->serial_tx);
    result = rt_data_queue_push(&(tx_dma->data_queue), data, length, RT_WAITING_FOREVER);
        if (tx_dma->activated != RT_TRUE)
            tx_dma->activated = RT_TRUE;
            /* make a DMA transfer */
            serial->ops->dma_transmit(serial, (rt_uint8_t *)data, length, RT_SERIAL_DMA_TX);
        else
        return length;
    else
        return 0;
rt_inline int _serial_int_tx(struct rt_serial_device *serial, const rt_uint8_t *data, int length)
    int size;
    struct rt_serial_tx_fifo *tx;
    size = length;
    tx = (struct rt_serial_tx_fifo*) serial->serial_tx;
    RT_ASSERT(tx != RT_NULL);
    while (length)
            if (serial->ops->putc(serial, '\r') == -1)
                rt_completion_wait(&(tx->completion), RT_WAITING_FOREVER);
                continue;
        while (serial->ops->putc(serial, *(char*)data) == -1)
        data ++; length --;
static rt_ssize_t rt_serial_write(struct rt_device *dev,
                                 rt_off_t          pos,
                                 const void       *buffer,
                                 rt_size_t         size)
    if (dev->open_flag & RT_DEVICE_FLAG_INT_TX)
        return _serial_int_tx(serial, (const rt_uint8_t *)buffer, size);
    else if (dev->open_flag & RT_DEVICE_FLAG_DMA_TX)
        return _serial_dma_tx(serial, (const rt_uint8_t *)buffer, size);
    else
        return _serial_poll_tx(serial, (const rt_uint8_t *)buffer, size);
   串口写的函数结构,大致上和串口读一致,因此理解起来也是一样的思路,具体如下:
       1. 中断发送(_serial_int_tx):中断发送,其实实现很简单,就是调用驱动提供的putc接口,但是需要注意的是,需要收到驱动回复的完成量tx->completion信息再进行下一步的写。另外中断读不加流操作,中断写加流操作,这点完全看不懂。
      2. dma发送(_serial_dma_tx):DMA方式的写,其实实现不止于此,但是放在这全部写,又有些多余,因此这里仅写这部分的思路,这部分的思路为,先将所有数据存储至一个叫tx_dma->data_queue的队列中,然后调用dma_transmit去实现数据发送。而我提到的后续部分,实际上是因为需要有DMA发送完成信息,以及由于dma发送有长度限制,因此在接收到完成信息后需要判断是否还有数据要发送,是否需要告诉上层数据发送完毕。至于这部分,晚点贴出。
      3. 轮询发送(_serial_poll_tx):这个方法与中断传输一致,可能由于是轮询方式直接发送,不能像中断那样在中断产生前MCU干别的事,因此就没有加完成量的处理了。
串口控制操作
static rt_err_t rt_serial_control(struct rt_device *dev,
                                  int              cmd,
                                  void             *args)
    rt_err_t ret = RT_EOK;
    switch (cmd)
        case RT_DEVICE_CTRL_SUSPEND:
            /* suspend device */
            dev->flag |= RT_DEVICE_FLAG_SUSPENDED;
            break;
        case RT_DEVICE_CTRL_RESUME:
            /* resume device */
            dev->flag &= ~RT_DEVICE_FLAG_SUSPENDED;
            break;
        case RT_DEVICE_CTRL_CONFIG:
            if (args)
                struct serial_configure *pconfig = (struct serial_configure *) args;
                if (pconfig->bufsz != serial->config.bufsz && serial->parent.ref_count)
                    /*can not change buffer size*/
                    return -RT_EBUSY;
                /* set serial configure */
                serial->config = *pconfig;
                if (serial->parent.ref_count)
                    /* serial device has been opened, to configure it */
                    serial->ops->configure(serial, (struct serial_configure *) args);
            break;
        case RT_DEVICE_CTRL_NOTIFY_SET:
            if (args)
                rt_memcpy(&serial->rx_notify, args, sizeof(struct rt_device_notify));
            break;
        case RT_DEVICE_CTRL_CONSOLE_OFLAG:
            if (args)
                *(rt_uint16_t*)args = RT_DEVICE_FLAG_RDWR | RT_DEVICE_FLAG_INT_RX | RT_DEVICE_FLAG_STREAM;
            break;
#if defined(RT_USING_POSIX_TERMIOS)
        case TCGETA:
        case TCGETS:
                struct termios *tio, tmp;
                if (cmd == TCGETS)
                    tio = (struct termios*)args;
                else
                    tio = &tmp;
                if (tio == RT_NULL) return -RT_EINVAL;
                tio->c_iflag = 0;
                tio->c_oflag = 0;
                tio->c_lflag = 0;
                /* update oflag for console device */
                if (rt_console_get_device() == dev)
                    tio->c_oflag = OPOST | ONLCR;
                /* set cflag */
                tio->c_cflag = 0;
                if (serial->config.data_bits == DATA_BITS_5)
                    tio->c_cflag = CS5;
                else if (serial->config.data_bits == DATA_BITS_6)
                    tio->c_cflag = CS6;
                else if (serial->config.data_bits == DATA_BITS_7)
                    tio->c_cflag = CS7;
                else if (serial->config.data_bits == DATA_BITS_8)
                    tio->c_cflag = CS8;
                if (serial->config.stop_bits == STOP_BITS_2)
                    tio->c_cflag |= CSTOPB;
                if (serial->config.parity == PARITY_EVEN)
                    tio->c_cflag |= PARENB;
                else if (serial->config.parity == PARITY_ODD)
                    tio->c_cflag |= (PARODD | PARENB);
                cfsetospeed(tio, _get_speed(serial->config.baud_rate));
                if (cmd == TCGETA)
                    _termios_to_termio(tio, args);
            break;
        case TCSETAW:
        case TCSETAF:
        case TCSETA:
        case TCSETSW:
        case TCSETSF:
        case TCSETS:
                int baudrate;
                struct serial_configure config;
                if ((cmd >= TCSETA) && (cmd <= TCSETA + 2))
                    _termio_to_termios(args, &tmp);
                    tio = &tmp;
                else
                config = serial->config;
                baudrate = _get_baudrate(cfgetospeed(tio));
                config.baud_rate = baudrate;
                switch (tio->c_cflag & CSIZE)
                case CS5:
                    config.data_bits = DATA_BITS_5;
                    break;
                case CS6:
                    config.data_bits = DATA_BITS_6;
                    break;
                case CS7:
                    config.data_bits = DATA_BITS_7;
                    break;
                default:
                    config.data_bits = DATA_BITS_8;
                    break;
                if (tio->c_cflag & CSTOPB) config.stop_bits = STOP_BITS_2;
                else config.stop_bits = STOP_BITS_1;
                if (tio->c_cflag & PARENB)
                    if (tio->c_cflag & PARODD) config.parity = PARITY_ODD;
                    else config.parity = PARITY_EVEN;
                else config.parity = PARITY_NONE;
                serial->ops->configure(serial, &config);
            break;
#ifndef RT_USING_TTY
        case TCFLSH:
                int queue = (int)(rt_ubase_t)args;
                _tc_flush(serial, queue);
            break;
        case TCXONC:
            break;
#endif /*RT_USING_TTY*/
#endif /*RT_USING_POSIX_TERMIOS*/
        case TIOCSWINSZ:
                struct winsize* p_winsize;
                p_winsize = (struct winsize*)args;
                rt_kprintf("\x1b[8;%d;%dt", p_winsize->ws_col, p_winsize->ws_row);
            break;
        case TIOCGWINSZ:
                if(rt_thread_self() != rt_thread_find("tshell"))
                    /* only can be used in tshell thread; otherwise, return default size */
                    p_winsize->ws_col = 80;
                    p_winsize->ws_row = 24;
                else
                    #include <shell.h>
                    #define _TIO_BUFLEN 20
                    char _tio_buf[_TIO_BUFLEN];
                    unsigned char cnt1, cnt2, cnt3, i;
                    char row_s[4], col_s[4];
                    char *p;
                    rt_memset(_tio_buf, 0, _TIO_BUFLEN);
                    /* send the command to terminal for getting the window size of the terminal */
                    rt_kprintf("\033[18t");
                    /* waiting for the response from the terminal */
                    i = 0;
                    while(i < _TIO_BUFLEN)
                        _tio_buf[i] = finsh_getchar();
                        if(_tio_buf[i] != 't')
                            i ++;
                        else
                            break;
                    if(i == _TIO_BUFLEN)
                        /* buffer overloaded, and return default size */
                        break;
                    /* interpreting data eg: "\033[8;1;15t" which means row is 1 and col is 15 (unit: size of ONE character) */
                    rt_memset(row_s,0,4);
                    rt_memset(col_s,0,4);
                    cnt1 = 0;
                    while(cnt1 < _TIO_BUFLEN && _tio_buf[cnt1] != ';')
                        cnt1++;
                    cnt2 = ++cnt1;
                    while(cnt2 < _TIO_BUFLEN && _tio_buf[cnt2] != ';')
                        cnt2++;
                    p = row_s;
                    while(cnt1 < cnt2)
                        *p++ = _tio_buf[cnt1++];
                    p = col_s;
                    cnt2++;
                    cnt3 = rt_strlen(_tio_buf) - 1;
                    while(cnt2 < cnt3)
                        *p++ = _tio_buf[cnt2++];
                    /* load the window size date */
                    p_winsize->ws_col = atoi(col_s);
                    p_winsize->ws_row = atoi(row_s);
                #undef _TIO_BUFLEN
                p_winsize->ws_xpixel = 0;/* unused */
                p_winsize->ws_ypixel = 0;/* unused */
            break;
        case FIONREAD:
                rt_size_t recved = 0;
                rt_base_t level;
                recved = _serial_fifo_calc_recved_len(serial);
                *(rt_size_t *)args = recved;
            break;
#endif /* RT_USING_POSIX_STDIO */
        default :
            /* control device */
            ret = serial->ops->control(serial, cmd, args);
            break;
    return ret;
   看似控制操作很多,实际上去掉几个目前学习来说无用宏包裹的部分看, 仅仅有那么几个入口:
       1. 挂起/恢复串口:虽然写了这么个标志,但是没啥用,因为这标志压根没用到
      2. 设置串口参数入口:功能同init中,个人理解为打开串口前的操作入口,即find,设置串口参数,打开串口
3. RT_DEVICE_CTRL_NOTIFY_SET:不知道什么情况下需要使用这种方式上报信息,tx_complete完全可以满足要求
4. RT_DEVICE_CTRL_CONSOLE_OFLAG:不明所以的实现,或许是历史遗留吧,得梳理历史提交记录才能确认
5. 其他入口:标准框架实现不了,驱动独有的设置入口,对应接口为驱动层的control
串口关闭操作
static rt_err_t rt_serial_close(struct rt_device *dev)
    /* this device has more reference count */
    if (dev->ref_count > 1) return RT_EOK;
        serial->ops->control(serial, RT_DEVICE_CTRL_CLR_INT, (void*)RT_DEVICE_FLAG_INT_RX);
        dev->open_flag &= ~RT_DEVICE_FLAG_INT_RX;
        rx_fifo = (struct rt_serial_rx_fifo*)serial->serial_rx;
        rt_free(rx_fifo);
        serial->ops->control(serial, RT_DEVICE_CTRL_CLR_INT, (void *) RT_DEVICE_FLAG_DMA_RX);
        dev->open_flag &= ~RT_DEVICE_FLAG_DMA_RX;
            rt_free(rx_dma);
        else
            rt_free(rx_fifo);
        struct rt_serial_tx_fifo* tx_fifo;
        serial->ops->control(serial, RT_DEVICE_CTRL_CLR_INT, (void*)RT_DEVICE_FLAG_INT_TX);
        dev->open_flag &= ~RT_DEVICE_FLAG_INT_TX;
        tx_fifo = (struct rt_serial_tx_fifo*)serial->serial_tx;
        rt_free(tx_fifo);
        serial->ops->control(serial, RT_DEVICE_CTRL_CLR_INT, (void *) RT_DEVICE_FLAG_DMA_TX);
        dev->open_flag &= ~RT_DEVICE_FLAG_DMA_TX;
        tx_dma = (struct rt_serial_tx_dma*)serial->serial_tx;
        rt_data_queue_deinit(&(tx_dma->data_queue));
        rt_free(tx_dma);
    serial->ops->control(serial, RT_DEVICE_CTRL_CLOSE, RT_NULL);
    dev->flag &= ~RT_DEVICE_FLAG_ACTIVATED;
    return RT_EOK;
   关闭操作,就是关闭硬件,销毁资源,而从实际代码上看,这入口也就干了这么个事。但是需要注意的是,他只有在所有打开这个串口的应用都关闭了串口后才去操作。
Add on
    看了那么多,实际上我们漏了一个内容,接收时,数据是怎么送到buffer里的,发送时,完成量是怎么发出的,这一系列功能,貌似都没有在上面的分析中体现。而这部分代码,实际上在serial.c里面有写,具体实现如下:
/* ISR for serial interrupt */
void rt_hw_serial_isr(struct rt_serial_device *serial, int event)
    switch (event & 0xff)
        case RT_SERIAL_EVENT_RX_IND:
            int ch = -1;
            rt_base_t level;
            /* interrupt mode receive */
            while (1)
                rx_fifo->buffer[rx_fifo->put_index] = ch;
                rx_fifo->put_index += 1;
                if (rx_fifo->put_index >= serial->config.bufsz) rx_fifo->put_index = 0;
                /* if the next position is read index, discard this 'read char' */
                if (rx_fifo->put_index == rx_fifo->get_index)
                    rx_fifo->is_full = RT_TRUE;
                    _serial_check_buffer_size();
             * Invoke callback.
             * First try notify if any, and if notify is existed, rx_indicate()
             * is not callback. This separate the priority and makes the reuse
             * of same serial device reasonable for RT console.
            if (serial->rx_notify.notify)
                serial->rx_notify.notify(serial->rx_notify.dev);
            else if (serial->parent.rx_indicate != RT_NULL)
                rt_size_t rx_length;
                /* get rx length */
                rx_length = (rx_fifo->put_index >= rx_fifo->get_index)? (rx_fifo->put_index - rx_fifo->get_index):
                    (serial->config.bufsz - (rx_fifo->get_index - rx_fifo->put_index));
                if (rx_length)
                    serial->parent.rx_indicate(&serial->parent, rx_length);
            break;
        case RT_SERIAL_EVENT_TX_DONE:
            rt_completion_done(&(tx_fifo->completion));
            break;
        case RT_SERIAL_EVENT_TX_DMADONE:
            const void *data_ptr;
            rt_size_t data_size;
            const void *last_data_ptr;
            tx_dma = (struct rt_serial_tx_dma*) serial->serial_tx;
            rt_data_queue_pop(&(tx_dma->data_queue), &last_data_ptr, &data_size, 0);
            if (rt_data_queue_peek(&(tx_dma->data_queue), &data_ptr, &data_size) == RT_EOK)
                /* transmit next data node */
                serial->ops->dma_transmit(serial, (rt_uint8_t *)data_ptr, data_size, RT_SERIAL_DMA_TX);
            else
            /* invoke callback */
            if (serial->parent.tx_complete != RT_NULL)
                serial->parent.tx_complete(&serial->parent, (void*)last_data_ptr);
            break;
        case RT_SERIAL_EVENT_RX_DMADONE:
            int length;
            rt_base_t level;
            /* get DMA rx length */
            length = (event & (~0xff)) >> 8;
                rx_dma = (struct rt_serial_rx_dma*) serial->serial_rx;
                RT_ASSERT(serial->parent.rx_indicate != RT_NULL);
                serial->parent.rx_indicate(&(serial->parent), length);
            else
                /* update fifo put index */
                rt_dma_recv_update_put_index(serial, length);
                /* calculate received total length */
                length = rt_dma_calc_recved_len(serial);
            break;
     这个函数,需要在驱动函数对应的中断中去调用,以便满足串口框架上的各种实现。
总结
   至此,最初版本的串口框架已经分析完毕,而分析完这个框架,我们可以以以下方式实现串口驱动的适配,通过在驱动中构建 struct rt_serial_device,调用 rt_hw_serial_register实现设备注册,在不同的中断中调用rt_hw_serial_isr并给予不同参数实现数据处理的方式实现串口适配。
关键词: rtthread     串口     框架     v1
2024-11-26 21:11:08     打赏
2024-11-26 21:15:43     打赏
共3条 1/1 1 跳转至
