我将 STM0 设置为 TC275 比较模式,以运行一个简单的操作系统。
在我的应用程序中,代码的运行符合预期。
现在,我开始在引导加载程序中使用相同的逻辑,但不幸的是,我发现在擦除/写入闪存后,定时器中断不再被触发。
调试时 我注意到STM0_CMP0 寄存器停止递增,但 STM0_tiM0 却一直正常运行。
下面是我的定时器代码和擦除功能的片段,其中我禁用了重置功能。
初始化函数
EXTERN bool_t IFX_OSISR_Initialise(void){ /* Set timer configuration
to default values */ IfxStm_Timer_Config timerConfig; bool_t
status = FALSE; IfxStm_Timer_initConfig( timerConfig, MODULE_STM0);
timerConfig.base.frequency = IFX_OSISR_STM_CLK_FREQ; /*
timer frequency */ timerConfig.base.isrPriority =
ISR_PRIORITY_TIMER_STM; /* interrupt priority */
timerConfig.base.isrProvider = IfxSrc_Tos_cpu0; /*
interrupt provider */ timerConfig.base.minResolution = (1.0 /
timerConfig.base.frequency) / 1000; /* Mini resolution of the timer in
seconds */ timerConfig.comparator = IfxStm_Comparator_0;
/* Comparator used for timer */ /* Initialize the STM timer
with the user configuration */ status = IfxStm_Timer_init(
g_timerDriver, timerConfig);// IfxStm_Timer_setSingleMode(
g_timerDriver,1); return status;}
启动功能
void IFX_OSISR_Start(void){ /* Start the STM */ IfxStm_Timer_run( g_timerDriver);}
中断处理程序
IFX_INTERRUPT(interruptHandlerSTM, 0, ISR_PRIORITY_TIMER_STM);
void interruptHandlerSTM(void){ /* Clear the interrupt flag and set
the next compare value */ IfxStm_Timer_acknowledgeTimerIrq(
g_timerDriver); /* Increment number of ticks since startup */
OsIsr_cntTicks = (OsIsr_cntTicks + 1u); /* execute handler of OS
module */ OS_ActivateTask();}
我的擦除闪存功能按预期运行,而且是通过 SPRAM 运行的。
boolean iState = IfxCpu_disableInterrupts(); /* Get the
current state of the interrupts and disable them*/ uint16
endInitSafetyPassword = IfxScuWdt_getSafetyWatchdogPasswordInline();
IfxScuWdt_clearSafetyEndinitInline(endInitSafetyPassword);
/* Erase the given sector */
IfxFlash_eraseMultipleSectors(sector.startAddress, 1);
IfxScuWdt_setSafetyEndinitInline(endInitSafetyPassword);
IfxFlash_waitUnbusy(FLASH_MODULE0, sector.flashType);
IfxCpu_restoreInterrupts(iState);
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/AURIX-TC275-STM0-in-compare-mode-stops-triggering-interrupts-after-flash-erase/td-p/705592
TC275处于比较模式的STM0在闪存擦除后停止触发中断怎么解决?
关键词: TC275 Aurix 中断 闪存
要解决这个问题,我们可以按照以下步骤进行:
1. 首先,确保在擦除/写入闪存之前,已经正确地保存了STM0的当前状态,包括STM0_CMP0寄存器的值。
2. 在擦除/写入闪存的过程中,确保不会干扰STM0定时器的正常运行。这可能需要在擦除/写入过程中禁用中断,然后在操作完成后重新启用中断。
3. 在擦除/写入闪存操作完成后,恢复STM0的原始状态,包括恢复STM0_CMP0寄存器的值。
4. 检查STM0定时器中断的配置,确保在擦除/写入闪存操作后,中断仍然可以被正确触发。
5. 如果问题仍然存在,可以尝试在擦除/写入闪存操作前后添加一些调试信息,以便更好地了解问题发生的原因。
以下是一个示例代码片段,展示了如何在擦除/写写入闪存操作前后保存和恢复STM0的状态:
```c
// 保存STM0的状态
uint32_t stm0Cmp0Value = IfxStm_Stm0_CMP0_Get();
// 擦除/写入闪存操作
EraseFlash();
WriteFlash();
// 恢复STM0的状态
IfxStm_Stm0_CMP0_Set(stm0Cmp0Value);
// 重新启用中断(如果之前禁用了)
IfxCpu_enableInterrupts();
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
