Avago公司的ALM-42316是全匹配功率放大模块,具有高度线性和低电压特性,工作频率在3.3-3.8GHz. ALM-42316是3级功率放大器,增益30dB,3.3V电源时的效率达14.5%, P1dB为30.5dBm,可广泛应用在IEEE 802.16移动端和固定端的高线性放大器和WLL放大器.本文介绍了ALM-42316的主要性能和技术指标, 内部电路图, 应用电路图及其元件布局和所用材料清单(BOM). Avago Technologies’ ALM-42316 is a fully-matched Power amplifier module for use in the (3.3-3.8)GHz band. High linear output power at 3.3V is achieved through the use of Avago Technologies’ proprietary 0.25um GaAs Enhancement-mode pHEMT process. It is housed in a miniature 5.0 x 5.0 x 1.1mm MCOB module. It includes shutdown and switchable gain functions. A detector is also included onchip. The compact footprint and low profile coupled with high gain and high efficiency make the ALM-42316 an ideal choice as a power amplifier for IEEE 802.16 (Wimax) and WLL applications. 主要特性: High Efficiency of 14.5% at low 3.3V supply voltage High gain: 30dB High linearity performance: 23dBm at 2.5% EVM (64 QAM FEC rate OFDMA). Broadband Fully-matched 50 Ohm input and output impedances 45dBc 2nd harmonic attenuation Built-in detector and shutdown switches Switchable gain : 18 dB attenuation using one single CMOS compatible switch pin GaAs E-pHEMT Technology Low cost small package size: 5.0 x 5.0 x 1.1 mm3 Useable at 5V supplies for higher output power 技术指标: 3.5GHz; 3.3V, Iqtotal=240 mA (typ) 30 dB Gain 23dBm linear Pout (2.5% EVM, 64QAM OFDMA) 24.5dBm linear Pout (2.5% EVM, 64QAM OFDMA) @ Vdd=5V P1dB : 30.5dBm Detector range : 10dB (0.3V – 2.0V) 18 dB switchable gain attenuation Shutdown current : < 20uA 应用: High linearity amplifier for IEEE 802.16 mobile and fixed terminal amplifier WLL amplifier ![]() 图1. ALM-42316内部电路图 ![]() 图2. ALM-42316应用电路图 ![]() 图3. ALM-42316演示板元件布局图 表1.演示板材料清单(B)M): ![]() |
共1条
Avago ALM-42316匹配功率放大方案
关键词: Avago ALM-42316 匹配 功率 放大
共1条
